Question about Proform 730 Folding Treadmill Model PFTL71104 - !
Pro-form 730 SI E2
Treadmill will turn on - incline works, but when I try to get it moving I hear a slight sound coming from the motor but nothing happens and then I get the E2 Error
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
  • 43 Answers
SOURCE: treadmill not working properly. Incline keeps slipping.
there is a plastic spacer at the rack area on the incline mtr- this white plastic spacer has broken, only recourse u have is to unplug the white wire on incline mtr, and never have a incline, or replace incline mtr when you find out how much the mtr is you might want to walk with out incline- if you was in my area, I have them cheaper
Posted on Jan 08, 2010
SOURCE: My treadmill will not incline. when you press the
Wondering if you found a solution to this problem yet? I seem to have the same situation with my 730cs treadmill. It is inclined and will not move up or down...thanks.
Posted on Mar 08, 2010
maxtreadmill
  • 832 Answers
SOURCE: Treadmill will not level out and motor sounds all the time
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Posted on Jun 27, 2010
ercupa190
  • 12223 Answers
SOURCE: incline stopped working on pro-form 490cx
I will give you a combo of Videos +Tip:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
After you make this adjustment: you can conclude strong: 1) If the inclination Motor is faulty
2) or Main Controller Motor Board.3) Transformer is faulty
Posted on Nov 22, 2011
Why won't my treadmill incline or decline?
Hi there, checked both upper and lower bolted connections, and check that lift motor hasn't cracked and frame is intact with no blockages to a possible scissor arm-lift assembly underneath the unit ? If this all checks out, maybe a small gearbox on the lift motor failed internally. Good luck.
Feb 02, 2015 | Proform Excellent Condition Pro-form 400e...
Jun 27, 2010 | Proform 575 Crosstrainer Treadmill
My treadmill is stuck in the max incline position
Jun 11, 2010 | Nordic Track Exercise & Fitness
Proform 2500 treadmill stuck in incline position
Under the motor shroud their is a instruction mini manual it will have a how to calibrate the incline motor, if that does not fix it then you may have to manually adjust the incline motor and sometimes it will take awhile to realign . If that does not work replacing the motor maybe the only option
May 02, 2010 | Exercise & Fitness
Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Apr 28, 2010 | Life Fitness 9000 Next Generation...
Mar 02, 2010 | Proform 730 Folding Treadmill Model...
Treadmill not working properly. Incline keeps slipping.
Jan 07, 2010 | Proform Quick Burn Pro Treadmill with 12...
Ifit treadmill will not incline but everything else works, how do I fix the incline
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
Nov 23, 2009 | Proform Quick Burn Pro Treadmill with 12...
E2 error codes shows on my Pro Form 730 si treadmill
Did you find a solution for this issue? I have a similar situation
Sep 28, 2009 | Exercise & Fitness
Proform 730 Folding Treadmill Model PFTL71104 - ! Logo
21 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
