Question about Omega Juicers Juicer 1000 Brand: Omega
Omega 1000 juicer overheats
It turns off after a few minutes of operation, and only starts a few minutes later after resetting.
SOURCE: how to replace latch arm for omega 1000 juicer?
Getting the old one out is the hardest part if the arm was broken off like mine. First locate the rectangular part where the arm attaches to the case. If the old arm, or most of it, is still attached, grasp it and pull firmly away from the case until you hear a click. Then, still pulling it away from the case, push it up toward the top of the case until it slides out. If the arm is broken off you have to pry it from the top until you hear the click. I used a small paring knife. Once you get it this far, wedge something like a toothpick behind it to keep it pulled away from the case. Then you need to push this push this part up. It is pretty tight so you might want to use some type of tool, like the blade of a flat screwdriver. Once you get the old one out, putting the new on in is just the reverse of taking the old one out.
Posted on Apr 26, 2008
  • 356 Answers
SOURCE: Right Arm of Omega Juicer Model 1000 broke off
CALL OMEGA 717 561 1105 THEY HAVE
THE LATCH ARMS. CHEAP. ASK THEM FOR
THERE ARE TO WAYS TO REPLACE THEM.
Posted on Jun 30, 2009
  • 7 Answers
SOURCE: omega 8005 juicer will not start
flip it over and hit the reset button, if there is one. If not, then make sure that it is put together properly, mine will do the same thing if the pulp collector is on wrong. or if you overheat it, then let it set and try to reset it.... hope that helps.
  • 356 Answers
SOURCE: My Omega Juicer 1000 shakes violently and the
Make sure the bottom of the feed chute is not damaged. If it,s chipped or scored, try filing
it down level as best you can. Then with the juicer fully assembled, unlock the set screw
on the center of the bottom and turn it clockwise until the chute contacts the blade, then
back it off a half turn and lock it down. By the way a dull worn blade will produce less
vibration. I'm assuming the lid is plastic.
Posted on Feb 02, 2011
  • 356 Answers
SOURCE: My omega 1000 juicer won't
Make sure it is assembled correctly and the latch arms snap shut completely
without any undue force. Also on the bottom of the juicer there should be a
reset button that might have tripped, just push it in. Other wise give Omega
a call.
Posted on Apr 26, 2011
Omega juicer 1000
Could be a defective breaker. That's what the "reset" is.
Jul 23, 2016 | Omega 1000 Juice Extractor
My omega 1000 juicer won't turn on - I just bought it today.
a call.
Apr 23, 2011 | Omega 1000 Juice Extractor
After juicing a few carrots[some of which were cut on a slant], or several spinach clusters, the machine seems to get off balance and begins shaking violently and making a racket at which point I have to...
There's nothing wrong. These juicers do not eject the pulp and go out of balance very
easily. If you continue to have problems you may have to go for a different type of juicer.
The Hurom or Omega VRT, expensive, look good if you're really into juicing.
Mar 05, 2011 | Omega 1000 Juice Extractor
I have an Omega Juicer Model 1000. When I try to juice citrul fruit. The jicer may only turn for a second or two than stops. When I push down on the citrus it oftentimes will not operate.
If you're talking about the citrus attachment, there may be a
problem with the gearing inside. I have one for my Acme
which I don't use because of it's awkwardness and juice
splattering characteristics. Better off with an inexpensive
citrus juicer and leave the Omega to its carrots and apples.
Feb 08, 2011 | Omega 1000 Juice Extractor
When we juice, it turns and moves across the counter
Both the Omega and Acme juicers vibrate no matter what you do. I found a worn shredder
blade actually produces less vibration. However this involves filing the cutting burrs down
and resetting the blade to chute gap. If you're up to it, take the blade out and file each row
of burrs about halfway down. Then with the juicer fully assembled, unlock the set screw on
the center of the bottom, turn it clockwise until the chute contacts the blade, and back it off
a half turn. The set screw actually raises and lowers the motor spindle. Both companies
would not agree with this, but this solution comes from operating my 21 year old Acme.
I recently replaced the blade and the juicer immediately began tap dancing. Went back to
the old blade.
Jan 16, 2011 | Omega 1000 Juice Extractor
Latch arm broken on my omega 1000 juicer. I have ordered one. How is it attached?
Omega can walk you through it, but have a file handy because the new latch
arms are not a perfect fit for the older juicers. You might want to remove the
4 screws on the bottom to separate the base for better access. If you have
a little mechanical ability it can be done, if not it could get tense.
Aug 26, 2010 | Omega 1000 Juice Extractor
I have an Omega juicer. I need to ajust it because it tremble too much Thank you
THIS IS A NON EJECTION PULP JUICER AND THEY
WILL VIBRATE LIKE MY ACME. BEST FOR HARD
PRODUCE LIKE CARROTS, APPLES, CELERY ETC.
FEED PRODUCE SLOW AND STEADY.
Oct 02, 2009 | Omega Juicers Juicer 1000 Brand: Omega
Omega 8005 juicer will not start
Jun 30, 2009 | Omega 8005 Juicer
Jan 25, 2009 | Omega Juicers Juicer 1000 Brand: Omega
Omega Juicers Juicer 1000 Brand: Omega Logo
Top Omega Juicers Experts
eyecam
Andrew Taylor
Andrew Taylor
Are you an Omega Juicer Expert? Answer questions, earn points and help others
