Question about Lenovo Computers & Internet
Skype keeps freezing on my lenova ideapad during use. I can see incoming message, but can not respond. I have a new lenova ideapad s400 touch. THe only way I can seem to fix is to reboot. Is there another way than rebooting entire laptop?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Check if your computer is not updating or some other software are using your netwrk to check that
press ctrl+alt with esc .
After that go to the networking tab please let me know whats the utilization for the network .
After that reinstall the sype
Posted on Apr 19, 2014
SOURCE: Lenovo Y510 keyboard not responding
first try to search a new material with configuration panel ,if you don't find anything replace it at your resseller
Posted on Dec 15, 2008
  • 239 Answers
SOURCE: my hp laptop keeps rebooting
it sounds like your hard drive has failed. you need to replace your hard drive and reinstall the operating system.
hope this helped.
please remember to rate my service.
Posted on Mar 09, 2009
  • 69 Answers
SOURCE: My ASUS X83v laptop wont start up, it keeps rebooting.
Try booting in safe mode...if you are able to get into safe mode without it rebooting then you have a driver problem, Try updating all drivers and see if that works. If you can't even get into safe mode, then it could be either, Bad RAM, Motherboard, Corrupted Hard drive or power supply.
To trouble shoot Ram, if you have more than one piece, take all out except for one and try it, if it works, then try the other piece of RAM in the same slot, then try both in the other slot, this will tell you if it's your RAM or your RAM slot.
Motherboard, not much you can do
Corrupted Hard disk, try booting into safe mode with command Prompt and run chkdsk utility on your drive
Power supply, make sure the battery is charging, if possible try another battery fully charged for the same model, remove battery and plug laptop in, unplug and just use battery..
Hope some of this helps you
Posted on Apr 15, 2009
ebay312
  • 118 Answers
SOURCE: acer aspire 5520 won't load up upon reboot
Looks like you've had a bad day with computers! Let's see if we can take some of this on today...
On the first laptop (these ideas may work for both, but I'll address them the way I would my own, and we'll go from there), it looks like there is too much stuff being loaded into memory during system startup. This is not uncommon, particularly in computers which have teenagers as primary users.
I would restart the computer, and after the manufacturer's splash screen and before the Windows splash screen, hit the F8 key on your keyboard. This should bring you to a startup menu, which will be a black screen with white writing on it. You will be able to make your choice by moving up and down with the arrow keys on your keyboard. Choose SAFE MODE and hit enter.
If you do not see this screen, then you did not time the hitting of F8 corectly. You'll have to restart and try again.
Once in safe mode, click Start, then RUN. With Run open, type this command MSCONFIG and hit enter.
The next screen that opens is the configuration utility, which allows you to change the things that start with your computer. The last tab on the top should be STARTUP. click this.
Because we are shooting in the dark here, and we are not sure what is stopping the startup process, in the lower right corner of the window is a button that says Disable All. Choose this and click APPLY.
When the mouse comes back, click the next tab, which says SERVICES. Under the first window, you will see a small check box next to a line that says Hide All Microsoft Services. Place a checkmark here.
Again, in the lower right corner, click Disable All. Then click OK. When asked to restart, chose yes. This time the computer should start normally.
Now, this should start your pc, but you still have trouble with no AntiVirus software on your computer. The programs are there, they are just turned off. You'll have to open the program from the program files list, and enable it once again.
I'll comment on the other one after I eat dinner with my family.....
Posted on May 28, 2009
  • 138 Answers
SOURCE: My Acer Aspire One keeps rebooting Windows oer and
Hello
It would appear that your computer is having an issue with a device driver and that is causing the netbook to continually reboot. You have two options:
1. Boot the computer to Safe Mode and see if you can find the faulty driver and fix it (all of your data is saved)
2. Restore the entire computer to the factory defaults using the recovery disk (all of your data is erased)
For option 1 - use the following to boot the comuter into Safe Mode
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/boot_failsafe.mspx?mfr=true
Choose network boot if possible so you can connect to the Internet with this system. If you cannot connect, you will need to use the below link on another comptuer and download the drivers for your netbook and install them individually.
http://support.acer.com/supportdocs.aspx
For option 2 - plug the optical drive into the USB port, press F2 when turning the netbook on to enter BIOS. Insert the Acer Recovery Media into the drive and go to BOOT and select USB CDROM. Follow the on-screen prompts to re-image your netbook.
http://netbooks-us.custhelp.com/app/answers/detail/a_id/134/session/L3NpZC9NcXlpdl8tag%3D%3D/sno/0
Posted on May 04, 2010
Cannot find Bluetooth on my ideapad s400
Are you sure it has a bluetooth card installed?
Oct 13, 2014 | Lenovo IdeaPad S400 14" Touchscreen LED...
My touchsreen isn't working anymore
Do you mean the touch function isn't working? Try reloading the lenovo drivers.
Do you mean the screen is dark or non functioning?
The usual cause is the flat cable from the body of the laptop to the screen is broken.
Warranty or repair shop.
Apr 12, 2014 | Lenovo IdeaPad S400 14in. LED Notebook -...
Itunes freezes
Try getting the latest version of iTunes, or reinstall your current version.
Apr 06, 2014 | Lenovo IdeaPad Computers & Internet
In my lenovo ideapad u 160 easy capture camera is not functioning.
webcams do go bad. In my experience when a webcam stops functioning in one way, shape, or form it's usually the actual webcam that's faulty.
Mar 25, 2012 | Lenovo IdeaPad U160 Laptop Computer...
I have a MSI all in one with a Lenova easy camera fitted but the video window is inverted, and solutions
my friend hope it can help you this idea.
First you should press "Fn+F6" to turn on the camera, and then use the MSI software "Easy Face Manager" to display the camera locally or you can use one of the IM software like msn, skype ... to share camera with your friends.
Aug 30, 2011 | Lenovo IdeaPad Y510 Notebook
Video freezing
There is a history of this problem in Skype - have a look at the Logitech forum - I suggest you read from the beginning of the thread on page 1
http://forums.logitech.com/logitech/board/message?board.id=video_clients&thread.id=5511
Aug 30, 2009 | Logitech Quickcam Chat Webcam
Incoming Skype Picture Freezes and/or Jumps
You are not the only one. I have a gorup of 6 people, on Vista, XP, with QuickCamPros and other brands and we communicate daily. We are ALL having the same problem as a result of the last Skype update.
It is NOT your system, it's Skype's issue. Do like we do and in the lower right corner of your screen you can report the quality of the call. Keep doing it over and over and maybe they'll do something about it!
Aug 15, 2009 | Logitech QuickCam® Pro 9000 Personal Web...
Microsoft LifeCam VX-1000 Freezes with Skype
Normal 0 How much memory do you have installed in your computer? It may need to be, increased, as this is likely to be the cause of your computer freezing, rebooting, times out, or shutting down.
Hope this is of some help. Bud
Jan 23, 2008 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
Computers & Internet Logo
44 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
