Question about Alpine KTP-445 Car Amp
How to install alpine mrv f805?
How to install the amp?
Shuttle83
  • 1139 Answers
SOURCE: MRV-F540 Amp shuts off when turning music up
The amp may have defective components, but it is still salvageable. first of all lets discuss what is happening. The amp is cutting off because of excessive current flow. which means one or some of you components have become thermally sensative. You can find out which components they are by using a can of cool mist or any other component cooling spray. this will allow you to find the problem quickly. Now in addition to this you may have to forego the tricks and do some real troubleshooting. Get a schematic of the device and try to take voltage readings to see which components are at fault.
Posted on Sep 06, 2007
Cerfer39
  • 709 Answers
SOURCE: alpine mrv-t757
Hi Big Nick,
Sounds like you have got almost all the good out of those Subs. You can find the screws you need at almost any hardware store or Auto parts store. The light is becase you are dloading the amp with low OHMS.  You may need use one channel and Run the wiring like written blow to get the power problem to disappear.
S1+ = Kicker comp cvr sub coil 1 positive
A+ = Amplifier Positive output.
A+ to S1+
S1- to S2+
S2- to A-
Posted on Oct 23, 2007
StuartB
  • 807 Answers
SOURCE: blinking protection light on mrv-t757 amp
Could be the power supply or output stage electrolytic capacitors.
Possibly breaking down/drying out inside.
Posted on Mar 17, 2008
  • 631 Answers
SOURCE: ALPine mrv-1507 Need helppp!! powere light flashes red
According to the owner's manual, it means that the battery voltage is low. Page 13:
http://vault.alpine-usa.com/products/documents/OM_MRV-1507.PDF
Posted on Oct 27, 2008
Professor_V
  • 92 Answers
SOURCE: I obtain recently a car amplifier model: mrv-f400
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=MRV-F407
THE ABOVE LINK WILL DOWNLOAD A MANUAL FOR THE SIMILAR MRV-F407 AMPLIFIER. IF YOU WANT TO PURCHASE THE EXACT MANUAL, YOU CAN OBTAIN IT FROM PACIFIC COAST PARTS AT 800-421-5080 PART NUMBER=68P50958W56. IT IS AROUND $5.00 PLUS SHIPPING. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Posted on Jan 06, 2010
Alpine Amplifier Cuts in and out on Passenger side while driving
Make sure wirings are not pinched and try replacing the fuse as well.
May 01, 2008 | Alpine MRV-F345 Car Audio Amplifier
How do I bridge this amp to run a single sub?
  • To bridge 1 sub with a Alpine MRV-100M amp you run the negative and positive wires coming from the speaker to the outside terminals on the AMP respectively.
Regards, Tony
May 22, 2011 | Alpine MRV-100M Car Audio Amplifier
Alpine mrv-f307 amp played for 10 seconds then shut down. Green light still on but no sound. Fuse ok. May have been below 2ohm load.
Contact Eric@ Capita Audio & Electronics Repair in Tallahassee,Fl we repair all name brands & all models 850-339-1130
Mar 14, 2010 | Alpine MRV-F307 Car Audio Amplifier
I obtain recently a car amplifier model: mrv-f400 of alpine, i want information about the correct way to instal thanks
Nov 24, 2009 | Alpine MRV-F540 Car Audio Amplifier
Lost instruction manual mrv-100m v12 car amp
Hello hlanderson,
You can download a copy from Alpine's support vault here.
Hope this helps.
Aug 13, 2009 | Alpine Car Audio & Video
How to convert from 4 ohm to 2 ohm car amplifier
All amplifiers are rated by the manufacturer as to the minimum impedance they can be wired to and still operate effectively (or at all).
All amplifiers are different - and there are some not stable at 2 ohms.
In theory - you are changing the amplifiers LOAD - not the amplifiers ability to withstand a lower impedance.
An amplifier that is wired at a 4 ohm load will have approximately HALF the power of the same one wired at a 2 ohm load.
If you post your amplifier make/model I can tell you the spec's.
If you're wondering what voicecoil wiring configurations will give you a 2 Ohm load... I can help with that as well - Simply post your make/model of the subwoofers.
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Jul 14, 2009 | Car Audio & Video
MRV - 1507 Question ...
The MRV-1507 is a two channel amplifier, below I've pasted important info from the manual:
Battery Lead (Sold Separately)
Be sure to add a 80 amp fuse as close as possible
to the battery’s positive (+) terminal. This fuse will
protect your vehicle’s electrical system in case of a
short circuit. If you need to extend this lead, the wire
gauge should be AWG8 or larger.
MRV-1507 ... 80A amp fuse
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 150W, 0.08% THD
Per channel into 2 ohms .......................... 300W, 0.3% THD
Bridged into 4 ohms ................................ 600W, 0.3% THD
You can find a manual for this amp here:
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=mrv-1507
Jul 07, 2008 | Alpine MRV-1507 Car Audio Amplifier
Blinking protection light on mrv-t757 amp
Mar 17, 2008 | Alpine MRV-T757 Car Audio Amplifier
Alpine KTP-445 Car Amp Logo
50 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
