Question about Dell (Inspiron 531) PC Desktop
When i turn on power it only beeps what do i need to do
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
Hello Michael, It's most likely that your ram is bad. Power down your tower and UNPLUG it. Open up your tower and see if you have duel channel ram. if so, take one out and restart your computer. if it starts then the stick of ram you took out is probably bad. Do the same with the other if it does not start by putting back the one you took out first. Remember! always unplug your tower and you will be ok. Good Day PS
Posted on Feb 12, 2014
Get 3 long beeps and 2 short beeps when power on
Likely bad ram... but i need the make and model for the beep codes..
http://www.computerhope.com/beep.htm
Mar 11, 2015 | Gateway Computers & Internet
I have a ASUS P8P67 LE motherboard, intel i5 - 2310 processor, kingston DDR3 RAM and ASUS ENGTX560 DC/2DI/1GD5 graphic card. When I turn on the PC i get one long and then three short beeps, and the...
> one long and three short BEEP
Something is wrong with some of your hardware.
Turn the computer off.
Disconnect the AC power.
Remove the graphic card.
Connect the AC power.
Turn the computer on, to see if the pattern of BEEP has changed.
Remove the RAM -- all of it.
Reinsert one stick of RAM.
Reinsert the graphic card.
Jul 16, 2011 | ASUS P8P67 LE LGA 1155 P67 SATA 6 Gbps and...
We had a power outage for about 45 minutes a few days ago. Ever since then the Powerware 3110 has been beeping. I turned it off and left it plugged in overnight and when I turned it back on the beeping...
This could be several things, fortunately the device should actually be helping you to diagnose the issue. There are different beeps for different issues. They are as follows:
1 Beep Every 5 Seconds = Power Outage\Loose Plug Connection\Tripped Circuit Breaker\Power Cord Damage or Failure
2 Beeps Every 5 Seconds = Low Battery Alarm
3 Beeps Every 5 Seconds = Battery Needs Charging\Service\Replacement
3 Beeps Every 5 Minutes = The Battery is discharged and battery power is unavailable (If this continues battery replacement may be necessary)
1 Beep Ever 1/2 Second = Power Requirements exceed the UPS Capacity (remove some equipment to lighten the load on the unit)
Continuous Beep = Short Circuit / Input Voltage out of Range / UPS Fault (Likely replacement of entire unit)
That should help diagnose the actual issue. If it turns out the battery needs to be replaced they can be found online for around $20. A simple google search for Powerware 3110 Battery should return what you're after. Good luck!
May 05, 2011 | Powerware 3110 UPS System
When you turn on the computer it makes a series of stringed beeps for a second also when turning it off, keyboard and mouse does not work
what's the beep pateren it does? here is the basic beep codes:.....
Error Code: Faulty Component:
1 short beep None (Normal Boot)
2 short beeps POST error
Non-stop beep Power supply or system board
1 long beep and 1 short beep System board
1 long beep and 2 short beeps Video card
1 long beep and 3 short beeps Memory
3 long beeps Keyboard
Non-stop short beeps Power supply or system board
(a key on the keyboard might
also be stuck)
None Power supply, system board,
or system case built-in speaker
Oct 01, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
When i turn on my ps3 its the older model not slim it beeps and turns itself off i cant even get my game out of it
Hello, You Will Need to Remove the Power Cord of your Ps3 and then Press the Power Button till u hear 3 Beeps then u need to do it again but this time u need to let go when u hear the 3rd beep and you Restore the Whole Ps3 System
Mar 28, 2010 | Sony Playstation 3 (PS3) Console
My ps3 will not turn on. the light comes on then beeps and turns off
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 28, 2009 | Sony Playstation 3 (PS3) Console
Need tech help!
Oct 21, 2009 | Sony Playstation 3 (PS3) Console
No menu appears when you switch it on only the wave and colour appears also will not turn off have to turn off from main switc
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
Re: Won't turn on
your power cable has a short in it. replace it.
May 16, 2008 | Cobra 4000 GPS Receiver
Constant beeping,won't turn on
What is the beep pattern? beeeeeeeep, beep,beep beeeeeep etc. also what BIOS do you have?
Aug 05, 2006 | Gateway EV 700 17" CRT Monitor
Dell (Inspiron 531) PC Desktop Logo
20 people viewed this question
Alun Cox
