Question about Canon ImageRUNNER 3570 Copier/Printer
Need to reset Error code 0000805-000 on canon ir 3530
Copier sometimes shows Error E000002-001 But this time every time you a copy E000805-000 comes up, please help Eric
SOURCE: canon ir6000 error codes E000061-0001..
error E061 poblem
Posted on Dec 02, 2008
SOURCE: Canon iR-2016 System erro E007
hi how do solve this problem system error E007
Posted on Apr 09, 2009
SOURCE: Error code E20 in Canon NP 6241 copier
Check this code - does it read E020 ? if so this is usually a result of toner starvation possibly caused by a faulty toner sensor in dev or hopper unit.I have also found the toner hopper supply motor can fail with the same result. In either case it is an engineers job to rectify. Good luck !
Posted on May 19, 2009
SOURCE: Canon IR3300 showing the error code E000602-0003
ERROR CODE E000602-0003 what i do
Posted on Feb 08, 2010
canontech
  • 1219 Answers
SOURCE: canon ir 3530
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Posted on May 04, 2010
I have IR Canon 2420 copier machine it shows E000007-0000 please help me what is the problem Thank yoyu
as the error codes are cannon specific I suggest that you contact a canon service dealer and ask them what the codes mean
Sep 03, 2015 | Canon Office Equipment & Supplies
Sir i have cannon ir 3530 xerox machine that shows 002 my cell no 9833273003
fuser temperature not rising....try to reset in service mode * 28 *, function, clear,err
Dec 12, 2013 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
My canon ir 3225 is giving me e000805-0003,where is the problem?
A E000805-003 is a error code for a fan that is not working correctly
Dec 19, 2012 | Canon imageRUNNER 3225 Black and White...
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Cannon ir 3530 all error code and solution
Code Error name/description
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
CANON IR4570 e000805-0000 AND e000110-001
on ir5570 error ,,E000110-001,,is polygon motor
Apr 05, 2010 | Canon ImageRunner 4570 | IR4570 |
E000805-0000 E000110-001
FIXING EXAS FAN ,,, IN RIGHT SIDE DOOR
Feb 06, 2018 | Canon Office Equipment & Supplies
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Mar 15, 2008 | Office Equipment & Supplies
47 people viewed this question
old marine
old marine
