Question about GE Spacemaker GTUN275EMWW
Spin and lid lock lights flashing - GE Spacemaker GTUN275EMWW
How do I fix a microwave oven, display flashes and keys pressed are ignored. It happened after 40 minutes working in convection mode.
It sounds like the electronics are overheating. Be sure all the ventlation is clear and operating.
Dec 04, 2014 | Microwave Ovens
Oven light jvm1540dn1ww
# 1 Unplug the microwave from its electrical outlet. Never service an electrical appliance while it's plugged in.# 2 Remove the screws that hold the outer shell onto the microwave chassis. Often the screws are on the bottom or back of the microwave. Use a Phillips screwdriver or Torx driver to remove the screws.# 3 Lift the outer shell off the microwave chassis and locate the box that houses the halogen lightbulb. In most cases, the box is metal. It may or may not have a lid on it. If it has a lid, loosen the tabs and pull off the lid.# 4 Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage.# 5 Place the cover back onto the box if necessary and place the shell over the microwave chassis.# 6 Secure the shell to the chassis with the original screws and the screwdriver or torx driver.
Regards.
Jan 28, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Door will not close all way, goes up and down ok I cant see any adjustment
Possible fault in the door lock assembly where the reset switch is also placed. So if this switch is jammed or the lock has not opened then the door may not close.
So remove power connection and open top lid to look into this section.
Apr 02, 2011 | Microwave Ovens
My blender won't power on, the lights don't turn on. I've had the blender for 1 year and have never had any problems with it. In the past month it would only work intermittently, and now it doesn't work...
sometimes something (food etc) gets "stuck" in the lock mechanism, preventing it from turning. unplug the blender and give the locking mechanism a cleaning with a bottle brush or rinsing it under very hot water. also the lock could be broken/chipped, also preventing it from turning.
i must admit that I broke my locking mechanism 5 years ago by not "seating" it correctly and forcing it. my hubby somehow removed! the locking mechanism but now it goes on - turns - as soon as I plug my blender in (because the stop/lock doesn't exist anymore). so I must be very careful to always have the lid on before I plug it in. but it's a braun blender and I love it. so i've kept it all this time.
Oct 06, 2010 | Microwave Ovens
I have bought a dome presto keeper for my bread, when I lock the lid down and press vacuum the red light comes on and it makes a loud noise, how should I be ...
Hi We have one too
They are supposed to switch off automatically after about 2 mins but ours doesn't We just switch it off manually It seems to work well Just make sure you don't block the air outlet inside the unit
Sep 21, 2010 | Microwave Ovens
The "ON' light keeps flashing, which I have never seen before, and nothing will happen. Tried unplugging, readjusting on the lock position- but nothing works. Still pretty new, maybe used like 20 time,...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 08, 2010 | Microwave Ovens
Microwave just quit working
Hi , Open the cover unsscrew it , be sure to unplug power ,if you have continuety tester , test the fuse if open replace it , is also availble in appliance parts center near you.
Feb 13, 2008 | Kenmore 62702 Microwave Oven
GE Spacemaker GTUN275EMWW Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
