Question about Euro-Pro Shark Mini Mechanical Sewing Machine
Quantum 5430: how to thread the machine
I am having trouble with the tension but I think the problem is the top thread. How do I thread the machine?
3 Suggested Answers
SOURCE: Yet another stitch tension problem...
Thank you, thank you! I just tightened the screw on my bobbin case and that instantly fixed my thread tension problem. How on earth are you supposed to know about the little screw?! I thank you so much for the tip!
Posted on Dec 14, 2007
Mongo32
  • 111 Answers
SOURCE: Can't get thread tension right on my Euro-Pro 7130
the top seam is actually the bobbin thread. dots on the underside means that the top tension is too tight. you may have a piece of thread or something gummy caught between the upper tension disks.
Posted on Jun 11, 2009
Tighten tension on top of singer quantum future? Thread makes loose loops on top of fabric.
from what I can see with limited pictures you just pull the thread deeper into the upper tension disks .
Feb 16, 2015 | Singer CE-200 Quantum Futura Computerized...
Why stitches on top are great but bottom are loose and loopy?
Check your upper threading. Make sure it's between your tension discs. Remember loops on bottom, something is wrong with upper threading/tension. Loops on top something is wrong in the bobbin area (like the bobbin being in upside down or a loose bobbin tension spring)
start by rethreading the top thread with the presser foot UP.
Jun 11, 2014 | Singer Quantum 9910 Computerized Sewing...
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
Needle keeps jamming, won't thread
Good day!
Good day!
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I have the error message that there is a mechanical problem and the guide says that the machine is stuck??? How would this be repaired?
Good day!
Good day!
Jun 05, 2011 | Feiyue FY100 Computerized Sewing Machine
The bobbin tension too tight on my Singer Quantum 9240. I believe there is a tension adjustment I can make on the bobbin case, but I have not been able to find my manual since we moved 2 months ago.
I am having this problem also; the thread catches in the **** in the bobbin. I am thinking maybe I am not threading the machine correctly--the bobbin area, not the top thread. I will try this & see if it fixes the problem. You may be doing the same as I am.
Jul 15, 2010 | Singer Quantum 9920 Computerized Sewing...
Loopy thread during stitching
if loops appear on underside of fabric, make sure machine is threaded correctly (check instruction manual for threading). when presser foot is resting on feed dogs, needle thread should be quite tight when pulled through needle (needle should bend a little). if thread does not feel tight, check threading again and ensure thread is between tension discs (presser foot should be up for threading and then down to check tension). if threading is good and tension seting is at 5 but still not tight enough check no htread is caught in tension assembly. if tension assembly is clear try tightening needle thread tension to 6,7 or 8 and see if that helps.
if the above is correct check for damage to the needle hole in the needle plate and polish with fine emery tape if necessary.
if you still have trouble best see a technician for possible repair to bobbin case or hook/shuttle mechanism which you may damage trying to fix yourself.
scott.
Jul 23, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Won't stitch properly
it sounds like you might need a new bobbin case to me try that and see if the issues you are having stop hope this helps
Sep 20, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Euro-Pro Shark Mini Mechanical Sewing Machine Logo
49 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
