Question about Maytag Neptune MAH5500B Front Load Washer
Motor Bad I need instructions to change out the motor and mother board
    Master:
  • Maytag Master
  • 676 Answers
Do you have the motor and speed board? I will help contact me Maytag authorized
Posted on Feb 13, 2014
3 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Maytag Neptune MAH4000 Motor Conversion Kit Instructions
I do please post your email here and i will send it to you
Posted on Feb 11, 2008
JULIANFIX
  • 975 Answers
SOURCE: Change motor and motor control board
you mean it doesnt spin , but does it goes thru the wash cycle?? if yes , then its not the main motor thats defective,it could be the DRAIN MOTOR PUMP ,COULD BE CLOGGED
Posted on May 19, 2008
Fix problem on carrier furnace heating blower relay click sparks click again got used mother board does same. Did I just get another bad relay or something else doing it?
It is more likely the motor or the fan causing the problem at this point [or you got a bad used board].
First with the power off try rotating the fan by hand to make sure it turns freely. If it turns hard or is stuck you know the cause. If it has places to oil the bearings, add a couple drops to both ends of the blower shaft and the motor shaft and try spinning again by hand. It could be the blower relay contacts are burned and making bad contact or possibly the motor capacitor or start windings are bad. Without a model number, I can't tell what controls your unit uses. At least Carrier is one of the better companies in providing manuals and wiring diagrams.
Carrier Literature Wiring Diagrams
If you are electrically handy, you might try energizing the motor relay without the control board connected, there should be a wiring diagram on the inside of one of the panels.
Jan 28, 2015 | Carrier Heating & Cooling
My GE GSL25JFTBS Clean steel side by side making a whirring motor type sound every once and a while for about 30-40 minutes at a time. Is there any trouble shooting I can do at home before having a GE tech...
no. now that i said that . you must replace both evaporater fan motor. and the mother board. this happens when the resitors on the mother board go bad . you can just replace the fan motor. but the board can do the same thing again. GE says change both.
Aug 16, 2011 | Refrigerators
I have canon np 6650 it shown E010. i have try to reset, checking the fuse on the dryer paper please help me
if error E010 occure, it means your Main motor not running,
motor or motor drive board or mother board problem,
if show E010 after running the main motor, check motor driver board or mother board,
but 99.9% case of E010, cause of main motor problem so check the main motor first,
Aug 11, 2011 | Canon NP 6650II Copier
Need a wiring diagram for this unit. Its a friends unit,he says that in cooling the outdoor fan stops running with compressor running I suspect a bad relay on defrost board (it want do it while I'm...
the outdoor fan should not stop while compressor is running and I would first suspect that the outdoor motor is bad - I would feel the motor with my hand (after it stops/with all electrical power turned off) and see if it was 'hot' to the touch.
If it is - then the motor is 'electrically breaking down' and will need to be replaced.
There is a slight chance that the fan motor capacitor (small silver/grey device) which is hooked to the motor by electrical wires - is bad - but I doubt it. Even so - if the capacitor has a visible bulge then I would first change the capacitor before the motor.
I would never change one circuit board for another unless it was an exact replacement for the one I was changing and included instructions on how to wire.
I seriously doubt that the problem is in the circuit board.
Aug 05, 2011 | Heating & Cooling
What is an F6 on my duet washer? I already
three things.... could be the motor, could also be the MCU (  motor control unit ), could be the wiring harness .  check the wiring harness between the speed sensor at the motor and the MCU.  i have run into all of those being bad on different machines.
Aug 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore top loading washer. Keep getting f50
check if basket turns freely? if it does i would replace the mother board.
Feb 06, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Turntable doesn't turn
remove bottom panel,< screws along front and tips down > the turntable motor is in the middle. Unplug motor and use multi-meter< insert probes into plug end > run short cycle with something inside of unit," glass of water ", if you have voltage here then the motor is bad and needs replaced. If not then mother board most likely problem.
Apr 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Janitrol gmp125-4, blower shuts off while burners still on,
Sounds like fan motor is bad getting hot and opening the circuit inside the motor and then after couple minutes cools off enough to complete the circuit and runs for little while and does it over and over.
Nov 23, 2008 | Goodman CLJ30AR32 Air Conditioner
Ge side by side model # GSS22JEMD BB
YES see if you have 12 volts dc at the evaperator motor if you do then the motor is bad if you do not then the mother board is bad and ge recomends in this case to also change the fan motor at the same time
Apr 17, 2008 | Nor-Lake Norlake Refrigeration 4' x 6'...
Condensor motor turn very slowly.
I do believe you will find the Mother Board is the cause of your problem. I also believe your original motor was ok. The motor runs on DC voltage. There are 3 wires to the motor. The red wire is a sensor wire. The other 2 wires should provide 12 to 13 or so volts DC to the motor. If it is not the mother board is bad.
I hope I helped. supertechks
Mar 05, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
