Question about Fujitsu LifeBook AH530 Pentium Dual-Core P6000 1.86GHz 4GB 320GB DVD?RW 15.6 LED Win7 Home w/Webca... (FPCR33731) PC Notebook
Keyboard does not work after having new screen fitted
Had to fit a new screen watch tutorial on outube, all went well until we went to use keyboard,the secure ribbon clip which goes to a connector with pins was not in properly so he tried again and it snapped in half,is this a minor thing to fix or do we need a whole new mother board, need advice ASAP, not our laptop!!
    Top Expert:
  • Fujitsu Master
  • 21,472 Answers
A replacement motherboard is required unless you can buy a faulty one from flea bay for next to nothing and take the clip from it. In the mean time, use a wireless keyboard. They are very inexpensive.
Posted on Feb 12, 2014
2 Suggested Answers
maxcarson
  • 7627 Answers
SOURCE: Fujitsu LifeBook S710 hard drive cable
Has the Laptop been opened before? Usually a Laptop HDD just plugs into the connection, there are no cable connection connected directly to the HDD? The HDD may be Bad/Failed , remove and test.
Posted on Mar 02, 2013
How do i make picture fit screen? top and bottom of picture is missing
Some receivers have the ability to do this for you, for instance, all ViP and Hopper receivers from DISH can stretch or shrink the screen to fit. Most HDTvs also have this feature, independent of the type of input, using your TV remote find the button that says something along the lines of screen size, picture fit, stretch, aspect, etc. While watching a program that looks unlike the way you want it to, tap the button until the picture changes to the style you most prefer.
Mar 02, 2015 | Evesham Televison & Video
How do I replace keyboard on Gateway EG70
Keyboards are easy to change in most laptops, just be easy when installing the new one... don't press any keys down at an odd angle or the keypads will come off! You will need a precision screw driver set... usually used to service watches and small electronics. Tiger Direct sells them. Nothing fancy, run about $8. The parts manual for your PC or laptop with have the schematic which shows you the parts, study it carefully to determine which screws hold the pieces to remove the bezel that surounds the upper part of the keyboard, just under the screen. There are a few small screws there. The keyboard in then extracted towards the screen and an angle, disconnect the ribbon connector for it as soon as you can get a little access to remove it. It just slides out with a little pressure, don't tug on the ribbon cable or you can break the connector. Put the new one in the reverse order and replace the bezel.
Feb 27, 2015 | Gateway Computers & Internet
The screen for Wii Zumba Fitness is very small and the prompts I can't read. Furthermore, one of the tutorials goes very fast -- it must be a glitch
Hopefully you have gotten this problem solved. If not, go to WII options -> settings -> screen -> widescreen setting -> change from standard to (widescreen (16:9)) and retry. This worked for me.
Dec 12, 2010 | Majesco Zumba Fitness for Nintendo Wii
New battery needed and fitted to a Polar heart rate monitor
This is really easy to do yourself. Get a CR1632 battery, unscrew the four screws on the back (dont tip the watch as there is a small spring in the watch), unclip the metal band holding in the old battery noting the way 'round the battery is in (minus side up), pop in new battery and push clip back down, when re-fitting the back make sure the spring mentioned earlier lines up with the white sticker with a hole in it on the inside of the watch back, screw down the back. After you have re done all your settings you may need to re-aquaint the watch with the strap, to do this put on the watch and strap, set the heart monitoring going, bring the watch up close to the 'Polar' logo on the chest strap until the time is displayed, should now be all set up.
Andy
Oct 28, 2009 | Polar F4 Heart Rate Monitor Watch
I need to buy a replacement key for an acer laptop
It is possible to buy individual keys from Ebay.
But if there is other damage to the keyswitch itself you may be better off getting a whole new keyboard from Ebay.
They are not expensive and are quite easy to fit.
Oct 12, 2009 | Acer NSK8458AN Keyboard
I have a 42" Sony Plasma Model# PFM-42B1 was watching tv when picture went out. Red standby light keeps flashing. Was told to unplug for 5 hours then plug back in & count how many times it blinks,...
There are a number reasons why this might happen:
  • The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  • The panel has died - Need a new panel
  • A cable has worked itself loose or is broken
  • The inverter has gone - Need new inverter
  • The driver board is faulty
Thanks
Oct 01, 2009 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Keyboard ctrl key not working
try another keyboard to check if there is something wrong with your os settings.
1. if it works with the new keyboard , your keyboard is the problem.
2. if it does not work w/ the new keyboard still the same problem, os settings in the keyboard is the problem
Mar 28, 2008 | Computers & Internet
Please help
keep pressing the button called ARC until you get standard...let me know if it worked
Oct 17, 2007 | Bush 5693D 24" TV
Fujitsu LifeBook AH530 Pentium Dual-Core P6000 1.86GHz 4GB 320GB DVD?RW 15.6 LED Win7 Home w/Webca... (FPCR33731) PC Notebook Logo
81 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
