Question about Samsung UN Televison & Video
Picture settings for samsung tv ue46f6500sb - UN Samsung Televison & Video
My Samsung model ue46f6500sb keeps switching on and off can't use the remote to do anything
I don't know if this is a tv or some other unit. You need to give us a little more info. If it is a tv or radio then unplug it from the wall for at least 5 minutes then plug it back in and start from there. Also change the batteries in your remote. If it doesn't change anything on your unit, it's because the the remote has a bad battery(ies) or it is broken. You can get new or used remotes on eBay for real cheap.
Aug 17, 2017 | Samsung Televison & Video
Samsung 5 Series, 32 inch LCD tv shows double image and picture flickering.
You don't have to take your set to a technician its in the TV settings which you put your self,so use the remote go to TV menu then picture settings you will see that feature then and disable it thanks.
Nov 22, 2016 | Samsung Televison & Video
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 01, 2016 | Samsung Televison & Video
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
Tv picture too big
You can probably change the picture in picture setting with your tv and that should help
Jan 01, 2012 | Samsung CLS55 Televison & Video
I have a 550 series plasma Samsung Tv 54''.. I cannot get the picture to pick up for example the football score at the top of the screen, nor the NASCAR readout at the top. I get a piece of it but can't...
The problem may be not in your TV but in your receiver, if you use a cable or satellite receiver. Sometimes those also have similar settings for picture mode - it's rare, but I've seen it.
If not, then it must be tv's zoom mode is just set to something other than "standard".
Nov 17, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Best tv settings for samsung LE40A457
Best is kind of subjective since each person's eyes are different. If you are looking for a bright and vivid picture, you can go to the picture mode and change it to that setting. Usually it is called something like "Vivid" or "Dynamic." Besides that, it is all user preference. Most people prefer to just use the factory default settings.
Nov 09, 2009 | Samsung LE40M91B 40 in. LCD TV
Problems with the picture mode on my samsung 46''
Your TV is in DEMO-STORE MODE.
Go to menu, find Plug & Play option, start it, and when asked, select Home Mode, than Enter and than just Exit.
Enjoy Your TV!
Jan 09, 2009 | Samsung LN46A550 LCD TV
Televison & Video Logo
29 people viewed this question
Henry  Thomas
Henry Thomas
