Question about Sunbeam Heating & Cooling
Heating pad does not heat - Sunbeam Heating & Cooling
    Champion:
    Habit-Forming:
  • 210 Answers
I would guess that the wires in the pad have been damaged. The weakest point is right where the cord connects into the pad - it is easily twisted and bent. This may be worn down, and if that is the case you may be able to realign the wire for an easy fix. It the cord is undamaged then the problem is in the pad itself. If that is the case, there isn't much you can do without taking the whole thing apart.
Elisa Jed ' http://nwsundanceservices.com/portland-heating-services/
Posted on Feb 19, 2014
Depress heat heating pad flashing won't go on
Hello, Linda -
Do you perhaps mean an Xpress Heat heating pad? If so . . .
http://feelpainrelief.com/does-sunbeam-xpressheat-heating-pad-extra-large-deserve-its-best-seller-spot-on-amazon/
(Quote)
How to Use the Heating Pad
When you get your package, the cord and the heating pad are not connected. Before plugging the cord into the outlet, make sure that the cord and the heating pad are connected. Yes, the control/cord must be connected to the heating pad before plugging it in. If not done in this order, it might cause a blinking F in the display and the pad will not heat up.
(End quote)
More . . .
Flashing F
Some users experience a flashing F (meaning failure), in the display. Make sure that the cord with the display is connected to the heating pad BEFORE plugging it into the electric socket. The flashing F can be avoided by doing this. If you still get a Flashing F, disconnect from the electric socket, make sure the cord is tightly connected to the heating pad, wait 2 minutes and then plug it back in.
(End quote)
More . . .
Customer Support and Warranty
This heat pad comes with a 5-year limited warranty. This means that for 5 years it should be:
Free from defects in material and workmanship. If there is any problem with the above after normal use, they will repair or replace this product or any component of the product found to be defective during the warranty period.
What you need to do is keep the original sales receipt/order and call the following number:
  • In the U.S.A. - please call 1-800-435-1250
  • In Canada, -please call 1-800-667-8623
They will help you out if you run into problems.
(End quote)
Best wishes.
Mar 04, 2018 | Miscellaneous
How to turn on heat with controller on my heating pad model cat92. It shows F-1
Hello, Martha -
I hope I am correct in thinking your heating pad is a Sunbeam.
If you have not yet checked the connection for the electric cord into the heating pad to make sure it is connected fully and properly, I suggest you do so.
Jan 11, 2018 | Heating & Cooling
Sunbeam heating pad flashing F
Unfortunately I bought this heating pad three months ago and it too has an F in the display which I think means 'failure' but I do not know why. Also this is brand new and has worked fine for three months. Now what?
Does anyone out there have a comment to help me and this original person asking this question?
Jan 04, 2014 | Sunbeam Xpress Heat Heating Pad 2013-912
MY DRIVER'S SEAT ONLY HEATS THE BACK PORTION AND PASSENGER SEAT ONLY HEATS THE BOTTOM... ANY SUGGESTIONS... FUSE OR REPLACE HEATERS...
-The passanger seat only heat the bottom of the seat. It does not have a heat pad in the back portion.
-For the driver seat, it sound like the bottom heat pad had burn out and need to be replace. The back portion and bottom share the same fuse. It takes time and the right tool to replace this heat pad, trust me I know.
Jan 20, 2011 | 2004 Honda Accord
Have heating pad model 818-7. blinking red light for high when connected- but no heat. what to do. I love this soft, terry cloth hour glass heating pad controller model number: SW204. e12107 is also on...
I had this problem with a heating pad too. I tried turning it off, unplugging it, then plug it back in and see if the light is still blinking. If it's not, set it to the temp you want. My heating pad was very temperamental that way, it didn't want to be set before it was plugged in. I hope this works for you.
Dec 16, 2009 | Sunbeam 805810 HeatSense Heating Pad...
New heating pad not working
have same problem with heating pad . reset control by unplugging unit for 1 minute , while holding down power button plugged unit back in . sometimes this takes 3 or 4 tries.
Apr 26, 2008 | Sunbeam 805810 HeatSense Heating Pad...
Sunbeam Heating pad will not reset
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
Mar 21, 2008 | Heating & Cooling
Heating & Cooling Logo
143 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
