Question about Milwaukee Electric Tool 5387 20 1/2" Hd Hammer Drill
Milwaukee 5378-20 speed switch is stuck
Won't turn to position 2
How do I trouble shoot an engine that won't start?
Hi, Frank and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping. Good luck and have nice a day.
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
What to do When Your Motorcycle Won Start
Troubleshooting No Start Honda Motorcycle
Motorcycle Won Turn On Solved
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 06, 2016 | Motorcycles
My cordless drill is running at half RPM. Is it the brushes or the motor?
cordless drills have a switch that allows for more torque at lower rpms si in effect it is a 2 speed drill coupled with a variable speed switch that alters the rpms
If the drill is running I would be looking at a speed control problem at this point I would be looking at the torque control switch
Jul 01, 2015 | Milwaukee Hand Trucks Milwaukee Electric...
When I try to start my spyder sts-se5 I turn the switch and nothing happening, its as if their is no power, no light or nothing. Can you help?
Hi, Sarah and the usual suspects are:
For more information about your issue and downloads that you will need please visit the websites below. Good luck and have nice a day.
Spyder won start Can Am Spyder Forums The factor Community
Thread Won Start won turn over
2014 CanAm Spyder RT Series Repair Maintenance Parts Master Collection...
Can Am OEM Parts
http://www.spyderlovers.com/RT/NEW2010RT.pdf
Sep 15, 2013 | CanAm Motorcycles
My sony dvd player won't turn on
Almost all devices might go through something like this. Sometimes, its the cable that get broken or loose. When I say loose, i mean to say that some cables have to be moved to a special position, for example, the head phones I am using now, are placed in a special position because they're like 2 years old. Same thing happens with my play station 2. I have to keep moving the cable to make it work and turn on.
Mar 14, 2013 | Audio Players & Recorders
Car stalle Security light on
Try your spare key.It could be that the primary key you have been using needs to be reprogrammed,which can be done by contacting a dealer.Turn the key to the "On" position in order to reset the pass lock system.Wait for fifteen minutes with the key in the "On" position.If the security light disappears, turn the key to the "Accessories" position and wait for a couple of seconds.Turn the key to the "Off" position and take it out from the lock cylinder. Wait a couple of seconds and turn the car on.--------------------------------------------------------------------------------------
Autel MaxiDAS DS708
Jan 08, 2013 | 2001 Pontiac Grand Am SE
My drill slips under high torque
check clutch adjust,put it in drilling mode
check if speed selector is in right position
after that if it slip aggain,you need a gearbox
Nov 04, 2012 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
Jandy valve won't turn to on position from pilot position.
check to see if turned on then check to see if wires not cut also make sure it is assigned on your remote thant would be intake output or solar
Sep 05, 2012 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
Replace the speed control switch in 3/8 Hole shooter No. 0228-1
Try this link. The speed control is done by what Milwaukee calls the remote.
Wiring diagram
Jul 20, 2012 | Drills
Troubleshooting for laverda motorcycles
Did your bike quit whilst it was running, or is the problem that it won't turn over on the starter when you try to start it?Position 1 of the ignition switch should allow the starter to be operated and the engine to fire up. Position 2 is for parking lights only. The ignition switch can suffer poor internal contacts with age. It may have been replaced with the wrong type of switch if you say it turns over in position 2. Have you checked the fuses? If they are OK, try bypassing the ignition switch completely.If you are running the original ignition, the control box under the tank can fail. Check that there is a spark on all three plugs. THEY ALL MUST BE KEPT EARTHED when turning the engine over to avoid destroying the ignition module.
Apr 10, 2012 | 1974 Laverda 1000 3C
My Sony DCR-TRV240 camcorder won't eject the tape. The power and all camera features work, but it won't eject a tape.
I'm sorry that the Camcorder is not ejecting tape. Please follow the troubleshooting steps provided below and check the operation:
1. Please make sure that the battery is fully charged. 2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder. 2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. 3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the CAMERA position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.
If the issue persists after following all the steps service will be required. You can find repair information and initiate service at:
http://fixya.com/repair
Thank you for using Fixya. Please let me know if you require any clarifications.
Sep 01, 2011 | Cameras
Milwaukee Electric Tool 5387 20 1/2" Hd Hammer Drill Logo
52 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
