Question about Dell (Inspiron 531) PC Desktop
When i turn on the pc it beeps and dont power up the monitor
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
Hello Michael, It's most likely that your ram is bad. Power down your tower and UNPLUG it. Open up your tower and see if you have duel channel ram. if so, take one out and restart your computer. if it starts then the stick of ram you took out is probably bad. Do the same with the other if it does not start by putting back the one you took out first. Remember! always unplug your tower and you will be ok. Good Day
Posted on Feb 12, 2014
2 Suggested Answers
mahjid
  • 202 Answers
SOURCE: turn on pc then beeps and nothing on monitor
Have your VGA card check by a hardware specialist and possibly the RAM. good luck
Posted on Jun 25, 2009
Toshiba screen is bleu and now i have a2nd monitor but now i dont see anything only grey light how do i reset it cntrol alt del dosnt work nothing happens
When you turn it on, do you get a series of beeps? These beeps are codes that are related to specific issues, so if video card, memory, etc does not pass the POST (Power On Self Test) then it will generate a beep code and these can be looked up on the web.
See http://www.computerhope.com/beep.htm for more details
Dec 20, 2012 | Toshiba Computers & Internet
My Dell Inspiron does not boot up only the solid amber light on the Motherboard on I try everything and still nothing works please help
Not so sure about this but I hope this will help.
-try to disconnect all the cables from the back (monitor, keyboard, mouse, usb's, power cable, etc.)
-then disconnect all the card (video card, sound card, NIC) if all are integrated then you dont have to.
-connect just the power cable
-try to turn on the computer and check if it beeps
-if it does not beeps need to replace the motherboard but before you do this check if the fan will spin even for a single second if does not spin then you also need to replace the power supply as well
-if it beeps then turn it off again.
-connect the video card and connect the cable of the monitor, keyboard and mouse
-turn on the computer then check if theres any display
-if theres no display check for any beep indication. and right it down on a piece of paper on how many times it beeps and if its long beep or short beep.
kindly provide an email if this things does not work so that I can give you a resolution.
Apr 01, 2011 | Dell Inspiron 530 Desktop Computer
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 06, 2010 | ViewSonic VA1703wb Monitor
Compac presario S5000NX dont start anymore... the pcu is running but see no images
You need to check if the light on the monitor is green on amber.
If its green then you need to turn off the computer, take out the ram, cmos battery, HDD/CD/DVD cables, power cables, and then put them back, this will ensure there is no static.
If still dont work then you need to take the ram out and start the computer, if it beeps then its a video chipset issue. If it will not beep then its you motherboard that has gone bad.
If the light is amber then remove the monitor cable from the computer and see if you get a message on the monitor stating no input signal, if dont then monitor has gone bad, if you get the message, then follow the steps mentioned above.
Regards,
Shrey
Jan 10, 2010 | Computers & Internet
Turn on pc then beeps and nothing on monitor
Jun 25, 2009 | Dell OptiPlex GX260 PC Desktop
Using Non-Dell monitor on Dell system
Have you tried the monitor on another PC, have you checked the cables, or tried another monitor cable, AND Look inside both place the monitor plug goes and look for BENT PINS or broken PINS, not every hole may have a corresponding pin but thats OK, look for bent or broken pins, If those soutions dont work repost error code beeps, and I or someone will help more.
Thanks for the fixya rating, everyone helps me..have a blessed day
Apr 08, 2009 | Computers & Internet
Monitor Shows pixelated colors then flashes no input and turnsoff
Well the fact that your computer beeped tells me that there was a fault in either the motherboard or the video card. I would first replace the video card.
Dec 17, 2008 | Dell Dimension 9200 PC Desktop
Pc wont turn on
removed hard drive, floppys , extra memory all pc cards
everything you can and try it again
Jan 18, 2008 | Antec TruePower Trio 550 (TP3550) 550-Watt...
Audio and monitor problems
if the beep is on the boot up it the power on self test which is a good sign. It sounds like a video problem. Do you have a systems disk? need to boot up with the disk or safe mode to change your video prperties
Dec 02, 2007 | Fosa CY25 Laptop
Dell (Inspiron 531) PC Desktop Logo
22 people viewed this question
Alun Cox
