Question about Sunbeam King Quilted Heated Mattress Pad With Dual Digital Controllers
Matress heater does not heat
Does not heat
Controller on a heated matress pad shows a backward 3 does not warm up
that heated mattress pad needs to be safety tested by an electrician
faulty thermostat or internal heating wires
or the actual controller
Mar 02, 2014 | Furniture
Can you place a full size matress onto the fullsize bed matress kit without using the box springs? for the vicki
You can call Products America at 800-205-9642 or 800-772-1041. We offer a wide verity of hardware and instructions for many cribs. Our qualified customer service staff is standing by to help you with proper selection, pricing and ordering information. We are open M-F 8am to 6pm CST. We look forward to speaking with you!
Aug 20, 2011 | Sorelle Vicki
Just notice that the matress doesn't set in well... does the crib matress have different sizes maybe??????????????????
Older mattresses are smaller. Make sure you are using the mattress that is listed
on the crib instruction sheet. There is a new standard and all mattresses are made to comply.
Feb 08, 2011 | Graco Lauren Crib
My sunbeam matress heated pad only flashes F1 and will not turn to low or high.
you either have a power issue or the pad will not go to higher levels because of a heating element issue within the pad its best to replace because if it continues or gets worse then you could be looking at a future fire or electric shock please be carefull and take the safe way and replace it!
Dec 27, 2009 | Computers & Internet
Simplicity ellis crib to a bed
If you are changing it to a regular twin-sized bed with the headboard, you need a boxspring WITH a matress. Matresses will break down laying directly on a bed frame. A boxspring gives the frame something hard to help support the matress
May 13, 2008 | Simplicity for Children 4-in-1 Convertible...
Matress height
You might want to check out this site. I bet they will have what you are looking for.
http://www.productsamerica.com/index.html
May 04, 2008 | Simmons Mattress Matino - Natural Maple...
Childesigns carrollton crib
I am not familiar with this crib, but I have been through many cribs and they all (so far) are adjustable to lower the mattress. You can figure it out by removing the mattress and matress board and inspecting the way the board is connected to the frame. Often there is a bar or rung that sits in a clip or groove at each corner of the crib just below the matress board. You may have to crawl underneath and look up at it. Usually you will be able to lower the platform without using tools, but be sure to take the weight off the platform by removing the mattress and board. Good luck.
Nov 14, 2006 | Childesigns Carrollton Crib
Sunbeam King Quilted Heated Mattress Pad With Dual Digital Controllers Logo
Top Sunbeam Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Sunbeam Furniture Expert? Answer questions, earn points and help others
