Question about Tools & Hardware - Others
NO NAIL IS COMING OUT WEN YOU PRES THE TRIKER
  • 42 Answers
I presume the gun fires but no nail is ejected. A possibility is jammed nails in the magazine. Do you see a mark in your work piece of the driver blade? If yes then it is most likely jammed nails. If not could be a broken driver blade. If gun does not fire could be gas problem. (check in date, yes it does have a use by date), another cause of not firing is a broken wire particularly around trigger switch (switch is on trigger and hence the wires are flexing every time trigger is pressed). Another cause of not firing is a brass spring clip in handle assy if this breaks it stops the gun firing. Recently I have had more broken wires than anything else on these guns. Worth noting is that the Stanley Bostitch nail guns suffer the very same faults. Also note they are the same gun just different colours so you can fit Hitachi parts to the Bostitch and they are cheaper.
Posted on Mar 11, 2014
My paslode IM350 nail gun wont spark but wen i remove the fan cover and unplug the fan it sparks nothing is loose and everything is connected but cant see what the problem is can anyone help thanks
With gun assembled but gas cell REMOVED look at LED on handle, with battery fitted LED will flash. Now press it against work piece, LED will stay lit whilst still watching LED press trigger. LED should blink off (it may blink red) this indicates that the spark unit has sent the spark. If this works it sounds like either the spark lead has been damaged and spark could be shorting across back of cylinder head or you actually have a gas problem. Check cylinder head O ring, use by date on bottom of gas cell. Depending on age of gun it may have another O ring on the sleeve (pre 2006). Check sleeve is clean do not add oil to working parts (except a smear when cleaning sleeve and around O rings when reassembling gun)
Mar 21, 2014 | Air Tools & Compressors
My 94 toyota pikup los power wen you pres gas
Sounds like you have a Blocked Fuel Filter or a Pump going bad
Apr 05, 2013 | 1994 Toyota Pickup
How to handle the walk man wen the sighn of hold again and again comes and we are un able to pres any button
to deactivate the HOLD function is usually possible by a key switching to off state. There are cases when the function is managed a certain key combination which has to be described in your manual.
If you can not solve the problem you should write the exact type of your item
Bye, gylacz
Feb 01, 2011 | Audio Players & Recorders
Not shore on number to pres to reset
reset what? if your trying to reset your pc back to original factory setting then wen the manufactuer screen comes up press f8 a few times and choose form the slection menu
i hope this helps
Vague
Dec 25, 2010 | Computers & Internet
I forgot the unlock code of my nokia 6680pls help me
yea i now a great reset code
torn of the phone and take out the memory card just in case to don't format.
step 2:hold the grean boton,and tape 3,and * all 3 togheder and pres on to the phone pt don't let this 3 boton's enliss wen apear wich town you'r living and then you can release the boton's and that's all great reset and fresh new 6680 phone fabrication reset.TNK's and i hope is helpfful for you all with nokia 6680.yahoo id:soni_djjoe2000 ad me and i help
May 29, 2010 | Nokia 6680 Handheld
Air coming out behind trigger.will sink nail
there is a split o ring on the trigger assembly that needs replaced or the whole trigger valve assembly needs replaced.
May 22, 2010 | Stanley Bostitch N86S 1 Factory...
I got this far with out a book but now I need specs.
Hello Triker.
Here are the specs on the head bolts.
Using a 10 mm bi-hexagon wrench, install and uniformly tighten the 10 cylinder head bolts and plate washers, in several passes, in the sequence shown. Torque 58 lbft.
Then mark each head bolt and turn each one an additional 90 degrees.
(new head bolts are a good idea to install here)
There you are Triker. Hope your repair goes well for you.
Take care.
KL
Mar 06, 2010 | 2002 Toyota Camry
Error code 001. On/off switch trips off after 10 seconds
when you open the front door you,ll find under the disply a smal hole put eny nail in it a doller sign will apeer in the upper left corner of the disply pres
star , 4,star you will see another disply press the right arrow till you find error word press on it and then press star (astresk. the disply will turn off and on again theis error might be from the heater lamp if
it comes again change the hamps
May 08, 2009 | Canon NP 6545 Copier
Tools & Hardware - Others Logo
302 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
