Question about Brother MFC-J6710DW Multifunction Printer - MFC-J6710DW
How to set up mfc-j6710dw printer for cardstock
What paper setting do I use? What is diff between BP61 & BP71 paper?Do I need to use the manual feed?
Soulvisitor
  • 1113 Answers
SOURCE: paper jam light won't turn off!
see my post
http://www.fixya.com/support/t262880-paper_light_constantly_flashes
Posted on Dec 07, 2007
SOURCE: Brother MFC-8840 D paper on manual feed jammed!
i want printer driver for winxp
Posted on Apr 14, 2008
Ajkill
  • 2035 Answers
SOURCE: brother laser printer wont print
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Posted on Feb 09, 2009
  • 526 Answers
SOURCE: brother mfc-7420 printer - manual feed instead of automatic
ok, thank you
you probably had a document that was not using 8.5 x 11 paper or the print settings were the printer to use the manual tray.
thanks adi
Posted on Apr 20, 2009
SOURCE: Brother MFC-7420 Laser All-in One Printer won't print.
Dont bother your self, just reinstall the printer again and let me no when done
Kaggwa Mozeh
Posted on Jun 09, 2009
New Computer trying to set up printer scanner to computer
You can download the manual from here:
Brother mfc-j6710dw
  1. Click 'Downloads-Drivers and Manuals' on the left-hand side.
  2. Choose: 'Multi-Function Centers' and 'MFC-J6710dw'
  3. Click 'Search',then 'View Downloads For MFC-J6710DW '
  4. Click the 'Manual' tab,then 'Search.'
  5. Download the guide(s)you need.You'll probably want the 'Quick Setup Guide.'
I have the MFC-J415 4 in1 Multi-Function Center.First,after initial setup,installing tyhe software,etc,I had to hook it up via ethernet,put in the modem/router's security code,to authorize its access to the network,then the computer had to 'find' it on the wireless network.After that,it said to remove the Ethernet Cable.This was last year,so I've kind of forgotten the instructions,but it was something like that.
Anyway,enjoy!
Nov 19, 2012 | Brother "mfc-j6710dw professional series...
What's your problem?brother mfc-j6710dw paper jam
I had problem with Brother MFC-J6710DW complaining about paper jam. Went through whole paper jam procedure a few times with no avail and no visible paper jam anywhere. Found (googled) this to be a common problem for this device. Turn off / on didn't help either.
Finally ... I followed procedure to the letter, bowed possible dust away and ... pushed tray 1 all the way in. (It turned out it was not all the way in when I first started troubleshooting, and was pushed to the same inadequate position subsequently.)
This MFC is low-cost. Meaning it has few sensors, and subsequently is not very precise reporting errors.
Remember: "paper jam" alert may mean something not on exact place it should be, with this otherwise (so far) good value for money MFC.
Mar 26, 2012 | Brother MFCJ6710DW All-In-One InkJet...
How do I use manual feed on the brother mfc 7820N printer/fax/copier?
The manual feed slot located in the front of the machine above the paper tray.
  1. Slide the gray paper guides to fit the size of the paper
  2. Using both hands put the paper (side to be printed, face up) in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the Brother machine feed the paper in a short distance.
  3. You must then go to the application that you want to print to the paper and use that application's paper settings to set the paper size, orientation, font, style, etc
  4. Good luck trying...
May 20, 2010 | Office Equipment & Supplies
Printing
In the print menu, you will see a Settings or Properties where you can set your paper feed as manual or auto. It looks like you have set it up for manual feed. so you have to go back to that settings and change the paper feed to auto.
Hope this will work for you.
Good luck
luciana44
May 04, 2010 | Brother MFC-6890CDW Printer
Cardstock won't feed
You need to hand feed these things.....one at a time. I sometimes find that I have to "help" it a little bit to get it feed by putting just a bit of pressure on the paper to push it into the feeder. Another trick is to make sure the front edge is turned up just a bit. (I usually take about 10-15 pieces of cardstock and roll them, and then feed them one at a time) that seems to work pretty well, too
Jan 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
Brother mfc-7420 printer - manual feed instead of automatic
ok, thank you
thanks adi
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-8440 shows "manual feed" and will not feed from tray
go to your cpu in the printer set up and tell the printer what you want it to do
Dec 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-J6710DW Multifunction Printer - MFC-J6710DW Logo
125 people viewed this question
Top Brother Computers & Internet Experts
Are you a Brother Computer and Internet Expert? Answer questions, earn points and help others
