Question about Coffee Makers & Espresso Machines
Reassemble nespresso U - two plastic parts
I have a nespresso U machine. A capsule got stuck and this seemed to put the parts out of line and the water was flowing into the capsule container instead of through the spout. I had and look two of the parts easily dropped out (nothing broken) I am now struggling to reassemble them correctly. The parts are a funnel and the inner spout. I would love to find a manual so I know how they are supposed to be positioned. Many thanks
  • 3 Answers
SOURCE: Nespresso D300 says "Fill Water" even after I have filled container.
Even if you fill the tank with water, the machine will display this message when it is empty inside (the pipes, heating element, etc.) You need to prime it: run some water through it by running the steamer/hot water wand.  That should take care of it.
Posted on Oct 24, 2007
  • 5 Answers
SOURCE: nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Posted on Aug 30, 2009
SOURCE: Nespresso Essenza C100 leaks all the water out
I have a nespresso type D90 which does exactly the same thing so it is probably not just yours
Posted on Feb 09, 2010
  • 21 Answers
SOURCE: Nespresso Essenza - water is not coming out of the spout
Try...Hit the start button then Lift the lever and push back as far as possible and hold for 3 seconds. hit stop button, then close lever. this should restart machine.
Posted on May 08, 2010
SOURCE: Nespresso machine does not punch hole on the capsules after close
This problem is most likely being caused by air being trapped in the system. To fix this, please follow the following steps: -
- Turn on the Machine, ensuring there is water in the tank
- Wait until the light stops flashing and the machine is ready for use
- Lift the silver lever on top of the machine into the upright position
- Press the coffee button on your machine
- Push the silver lever back, away from you, and hold it in this position for 3 seconds
- Press the coffee button again to stop the water flow
This procedure releases the air blockage in the system and your machine should function normally again.
(from
Nespresso Club)
Posted on Jun 09, 2010
Coffee pod stuck in machine
These machines are designed to use only Nespresso capsules. The UMilk, particularly, is susceptible to jamming if so-called "compatible" capsules are used, as the capsule is pierced electroncally, not manually as in most of the Nespresso range of machines.
Hope this helps, Rob.
Apr 11, 2015 | Nespresso U D50 Espresso Machine Color:...
My nespresso c190 makes coffee watery
Have you decalcified the machine? They need descaling about once every year - 18 months, and one MUST use the Nespresso Descaling Pack, which is designed for all Nespresso machines. I can't understand why the capsule holder is tight, unless you have used so-called "Nespresso Compatible" capsules, which can cause this. The machines are designed for use only with genuine Nespresso capsules.
Feb 28, 2015 | Nespresso C190 Espresso Machine
Magimix M190 CITZ
Are you using genuine nespresso capsules? Are they seating properly. Open the slot where you put the capsule in and check its very clean and nothing is stuck in there.
Have you tried resetting to factory settings?
Apr 03, 2014 | Nespresso D300 Espresso Machine
DeLonghi Nespresso U not puncturing capsule
Not a fan of nespresso, a lot of cheap plastic. I am guessing the pivot for the capsule puncture arm has worn out allowing some play in it, which is keeping it from closing all the way just a guess, but it is an issue I have fixed before.
May 02, 2013 | DeLonghi Coffee Makers & Espresso Machines
My nespresso u machine capsule slot wont open
Turn the machine off and unplug it from the wall for 10 seconds. It may just have a capsule stuck inside. Doing this will get the machine to eject any capsules when it is turned back on.
Feb 03, 2013 | Nespresso C100B Essenza Single-Serve...
Slider is stuck in Nespresso U can't get it to come back. If I place a new capsule it falls right into garbage
Go on line with the manufacturer, Nespresso and request a complete parts list with drawing. It will show you all the parts and you can figure how it works from that. There may be a bad part in it that you will now have the exact part number to order. Good Luck...
Dec 15, 2012 | Coffee Makers & Espresso Machines
My Nespresso Magimix Citiz does not pierce the capsules every time. I use only Nespresso capsules. I have tried to pass them through a second or third time when this happens but I have thrown too many...
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Mar 02, 2011 | Nespresso C100/T-US-AERO Espresso Machine
With our nespresso machine, when you place the capsule inside & press the button the water runs through the inside of the machine where the plexiglass basket for the empty capsules are
Feb 04, 2011 | Nespresso Citizmilk D120
The capsule lock system does not make holes in the capsule
Oct 09, 2009 | Nespresso Le Cube
Nespresso essenza problem
Jul 30, 2009 | Nespresso Essenza C100 Espresso...
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
