Question about Sony Dav-dz340k 5.1 Channel DVD Home Theatre System 110/240v
How to connect speakers
I want to connect the system with T.V
    New Friend:
  • 87 Answers
Each speaker has a colored jack coresponds with a jack in the dvd, match colors.
you can connect tv with hdmi or composite.
Posted on Mar 20, 2014
My panasonic says f61 when i switch it on wat do i do
An F61 error occurs on a Panasonic home theater system when the speaker cable wire connections are wrong. This situation is likely to happen if you just purchased your unit or moved the system and try to reconnect the speakers again. Polarity is key in a successful setup. The positive and negative ends of the cable wires must match the input of the main unit. Retrace your speaker wire connections to clear error F61.
Step 1 Attach the speaker labels to the speaker wires for easier identification, if they're not already labeled. At minimum, labels for front left (L), front right (R) and center speakers should be included in the packaging contents that came with your system.
Step 2 Verify that the white ends of each speaker cable are connected to the corresponding "+" positive inputs for each speaker.
Step 3 Verify that the blue ends of each speaker cable are connected to the corresponding "-" negative inputs for each speaker.
Step 4 Push the plastic ends of the speaker wires on each speaker to verify that each is locked into place.
Step 5 Connect the remaining end of the "Front (L)" speaker wire to the white terminal/connector on the main unit.
Step 6 Connect the remaining end of the "Front (R)" speaker wire to the red terminal/connector on the main unit.
Step 7 Connect the remaining end of the "Center" speaker wire to the green terminal/connector on the main unit.
Step 8 Connect the remaining end of the "Subwoofer" wire to the purple terminal/connector on the main unit.
Step 9 Connect the remaining ends of the "Surround (R)" and "Surround (L)" speakers to the wireless system.
Sep 11, 2016 | Panasonic Audio Players & Recorders
To connect speaker wires to unit there are blue wires and black wires. where do I attach them to the unit
hi,
connecting right speaker.
1.connet the speaker cord with the plug to the speaker high freq right (R) terminal
2. connect the speaker cord with white strip to the speaker low freq right (L) + terminal and its black cord to the -- terminal
do the same for connecting the left speaker to the speaker high freq left (L) and speaker low freq left (L) terminals
ok
Jan 05, 2011 | Aiwa Z-L700 Shelf System
I'm considering buying the 180636 "surround sound bar speaker system." My question is, is this JUST a speaker system, which needs to be connected to a separate amplifier or "home theater...
The bar speaker system needs to be connected to an amplifier. What the bar speaker does is replicate a five speaker home theater system using just an amplifier.
The only thing that will give you a better sound quality is some type of amplifier/speaker set-up, wether you choose to have an amp and two speakers or and amp with five speakers and a subwoofer is up to you.
Nov 30, 2010 | Audio Players & Recorders
I have had a set of Polk Audio SDA1 speakers that I had attached to an old but great Pioneer SPEC-1 pre-amp and SPEC-2 power amp. The old speakers had one connection for the right speaker positive and...
bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
Jun 21, 2009 | Polk Audio RTi A7 Main / Stereo Speaker
Does this system have traditional speaker wire connections
Yes.
Connect the appropriate wire(s) from the DVD-958 speaker connection(s) on the back of the unit to the wall connection(s). You should match the impediance of the speaker to the unit.
Feb 24, 2009 | Coby DVD-958 Theater System
Speakers
If I understand you right, you have 7 speakers on 7 different channels.
When you have just 1 speaker connected it sounds fine, but any time you add more speakers it shuts down, or does it sound fine until you have all 7 of the speakers connected.
Bare with me, and we will figure this out. It is a very diificult job trying to troubleshoot something that is not in front of you.
After this post, it will be about an hour or so before you will hear from me again, I will be on my way home from work.
Is this a 5.1 surround system or is it listed as 7.1?
Do have have any speaker outputs with more than 1 speaker connected to it.
If this is a 5.1 system, do you have speakers connected to the "A and "B" speaker jacks?
What kind of speakers are they, and do they say on the back where you connect the speaker wire what ohm rating they are. Most speakers for your home are 8 ohms.
in case you were wondering what a 5.1 and a 7.1 system is:
the 5.1 system has front right, front left, center, rear right, rear left and the .1 is for the sub-woofer that is normally a RCA jack output on the back of the receiver
The 7.1 has all those same speaker outputs plus it has a surround back with right and left channel.
I will get back to you in about an hour or so.
Jun 23, 2008 | Audio Players & Recorders
Out door speakers
Salutations pspk,
Because there are special speaker connections on your unit it may make this harder to do. It may be possible to connect extra speaker wires directly to the end of your existing speaker wires. These wires could then be connected to a wireless transmitter or extender to feed sound to your speakers.
I will warn you this may cause sound quality issues as you would be basically splitting the power levels to your existing speakers.
I hope this helps.
Jon
Go Ahead. Use Us.
Jun 04, 2008 | Sony DAV-DX150 System
Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Feb 11, 2008 | Logitech X-540 Computer Speakers
Am setting up a bose GSX 3-2-1 home theater
Need to know the TV connections. On newer TV's there RCA jack connection or ext speaker connections. Usually the external TV speaker connections hook to the woofer and the rest of the speakers are connected to the woofer. The woofer acts as the sound system for the rest of the speakers. With this method you need to mute the internal TV speakers by a swiich on the TV or internal TV setup menus and select ext speakers.
Jan 26, 2008 | Bose Cinemate Digital Home Theater System...
Speakers not working
Double check to make sure they are getting power. Make sure, the system is not on mute mode. Double check the connections from the back of the system to the speakers. The speakers should connect to the line-out jack.. Try to replace the speakers with any others to figure out if the problem is in the system or in the speakers. Sorry i cant help u more.
Dec 29, 2005 | LGDVT418 System
Sony Dav-dz340k 5.1 Channel DVD Home Theatre System 110/240v Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
