Question about Dual Ford F250 F350 Crew Cab 04-08 Boss 12" Phantom Sub Box Ce1250m 1250w Amp
Truck will not go in four wheel drive when i turn the switch to fourwheel high or low
The fourwheel lights come on when i first crank it but then go out so i know dash lights are working but last time i got in fourwheel drive a few mounth ago it was hard to get out but now it will not even go in
    Problem Solver:
  • 15 Answers
Hi Brian,
Make sure you put it into 4 wheel drive before you start the car our it will not stay on, also to turn it of you need to switch off the van then turn it back to 4x2. Hope this helps but all 4x4s need to be switch off before alternating between both modes.
Posted on Feb 18, 2014
My 1995 GMC Jimmy won't let me switch into four wheel drive. I had in this morning in 4 wheel low, but when I went to put it into high nothing. Now it feels like the button is stuck, none of the lights...
there is a "modulator " on the transfer case with a 3-4 pin plug that fails often.this may be defective as well as the relay component that turns it on(rwhich is located under the battery)...try cheching/changing these first....the "modulator" is about 30 bucks and the relay is about the same
Dec 16, 2010 | GMC Blazer Cars & Trucks
When drivingtruck in 2 wheel drive the 4 wheel low light will flash and when slow truck down to a stop it will shift into 4 wheel low and will not go back to 2 wheel high
Sometimes the solenoids will stick on the axle neither in 2 or 4 wheel drive, if this problem started when you weren't shifting between two and four wheel drive it is probably the push button switch cluster on your dash going bad
Dec 12, 2010 | 2000 Chevrolet Blazer
I have a used '95 Yukon that I just bought....It has the push buttons for Four Wheel drive........How do I tell if it is in one of the four-wheel modes?
the buttons to the right are the ones to put it in fourwheele drive the top is for four high and the botttom is for four low
Nov 23, 2010 | 1995 GMC Yukon
01 explorer four wheel drive won't engage
check the electric solenoid on the fly which diverts the vacuum to the front wheel to engage the drive shaft.Usually two solenoids located on the radiator panel.Check for broken vacuum hoses or leak
Feb 01, 2010 | 2003 Ford Explorer
2000 montero sport four wheel drive.make wining noise .
Run hot wire from battery stright to bat. side of coil and see what happens.
Dec 30, 2009 | 2000 Mitsubishi Montero Sport
1996 gmc 1500 four wheel drive
Have you checked the switch on the transfer case? Those switches tend to go bad and primarily operated the 4 wheel Hi.
Apr 13, 2009 | 1999 Chevrolet Silverado 1500
I engage the four wheel drive in my 2005 Ford F-150 when we had a snow storm this week.Now when switching out of fourwheel drive the transmission wines until you switch it back to fourwheel drive...
the four wheel drive uses vacuum hub locks. there is a vacuum solenoid on the passenger firewall in front of the battery box. sounds like you need a updated solenoid and possibly one or both hub locks. what happens is the old style solenoid vent allows water to get in and the hub locks freeze or stop working because of the water. the new style has a cover over the vent to prevent water from getting in.
Mar 05, 2009 | 2005 Ford F-150
Dual Ford F250 F350 Crew Cab 04-08 Boss 12" Phantom Sub Box Ce1250m 1250w Amp Logo
35 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
