Samsung wa13v5 Hi, when water flows into machine it flows directly out again at drain pipe? We moved to another house and don't know it machine got damaged?
    Prodigy:
    An expert who has answered 500 questions.
  • Washing Mach... Expert
  • 517 Answers
Try lifting the drain pipe to at least 27 in or 70cm the pipe should not be on the ground
Posted on Feb 12, 2014
Richie_asg1
  • 1036 Answers
SOURCE: over flowing on water discharge
This is not a fault with your machine.
The problem lies aquarely with the outlet pipe in the building plumbing. Very often there is a gradual build-up of grease in this pipe somewhere before the pipe gets larger to the main drain.
The first solution is to use a solid or liquid drain cleaner in that pipe - and leave it to work at least overnight.
Then fill a bowl with very hot water and Soda Crystals - basic washing soda.
Flush the pipe with a full bowlfull of this hot water (may need a large mouthed funnel)
Also a hosepipe from the hot tap to a pipe in the outlet will work.
Once clear - you shouldn't have anymore problems.
If you wish, you can wrap a polythene bag around the machine outlet, then force this into the wall drain pipe - to make a better seal. It's not ideal, but may help with pipes that are slow to drain.
Posted on Feb 01, 2009
aardvarkrepr
  • 62 Answers
SOURCE: washer will not drain or spin with pipe in
Hi.
ok Did you say the drain hose was placed on a spiggot underneath the sink???
the appliance is obviously working as you have tried the drain hose in the sink.
You may find, if you unscrew the drain spiggot, there is a blanking cap. your previous owners put this in place to stop a huge water leak when using the sink
remove cap, refit hose and it should work ok.
Please let me know if I was right?
regards
aardvark Repairs
Posted on Nov 18, 2009
barkencoa
  • 3463 Answers
SOURCE: What size drain stand pipe should be used? Water
The problem is being caused because there is a blockage or restriction in the stand pipe, it needs to be cleaned out.
Posted on Feb 24, 2010
  • 6277 Answers
SOURCE: Hi, I have a gorenje 420 washing machine and I
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and helping for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Meanwhile here are my general guidance notes for checking filters and drain motors which should clarify and assist ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Good luck with both!
John C
Posted on Feb 28, 2011
  • 6277 Answers
SOURCE: I have a Samsung 13kg
To test the pump see near the end ------->
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
Hope the filter is the problem and good luck!
John C
Posted on Mar 16, 2011
Testimonial: "Thank you very helpful."
Our washer drains and overflows... we have had the lines checked and any clogs removed less than 24 hours ago. Doing laundry tonight and it overflowed again. When cleaning up all the water we tipped t
If the drained water is overflowing at the drain in or on the wall, that drain may be too small in diameter for the volume of water being pumped out of the washer. Because it is pumped out, it is generally moving faster than water that would be drained by gravity. ALSO very important is the height of the drain connection. I had that problem and had to extend the drain pipe about a foot vertically. The entry point of the pipe can be too close to the P trap, which slows down the flow as it changes the direction of flow. If there is not sufficient volume above the trap, it can back up and overflow due to slower flow through the trap.
Aug 15, 2014 | Washing Machines
Samsung WA13V5 Fully Automatic Washing Machine. Code error:E4. We bought this machine on 15 August 2012 with Gaurantee of Two Years and a extended Warrantee of 2 years at Game store ILLanga Mall Nelspruit....
when you say water goes out at the same time as going in? have you put the bent in the back of the drain pipe or is the pump pumping it back out ?
Jul 01, 2017 | Washing Machines
Hi, I have the WA13V5 toploader. The machine is 7 months old. Yesterday the machine still worked 100%. This morning the water does not want to flow into the machine. I have checked the water flow and the...
Hi
There is a filter located in the pipe between the connector to the water outlet and the machine, This sometimes gets clogged. If this dos not solve the issue then time to call a tech. Anyway your machine is just 7 months old and it should still be in the warranty period and the service should be free.
Regards.
PLZ. don't forget to rate my suggestion.
Jul 19, 2011 | Samsung Washing Machines
The water won't drain out of the dishwasher.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again. Also check that the valve that controls the directional flow of the water is operating. This too is in the bottom of the machine.
Mar 11, 2011 | GE Profile PDW8400J Built-in Dishwasher
While moving my samsung top washing machine, I think my drain hose pipe has moved down the water level. Now machine is not able to retain the water while washing/soaking. I need to pull the drain hose pipe...
Although a few modern washing machines can operate with the drain pipe at any height, most machines will drain the water as soon as the drain pipe is placed below the machine water level.
The simplest solution for your problem would be to ask somebody with some handy man skills or hire a plumber to add a 2 inch PVC pipe to your drainage pipe which extends to a point behind your washing machine & then points upwards, making sure it is long enough to be at a higher point than your machines fullest water level.
This should be a relatively inexpensive alteration & will ensure that water does not drain unless the machine is on its drain cycle.
Please let me know if you need any further assistance.
Best wishes,
Graeme
Mar 10, 2011 | Samsung SW62ASP Top Load Washer
Washer less than a year old. Top loading. Will
Have you moved recently, or moved the washer for any reason?
Two things can usually cause that.
First, Some part of the drain hose must always be higher than the highest possible water level in the machine. Remember that water flows downhill. If all the hose is lower then the highest possible water level the machine can never fill since water will drain out hose. So, raise the hose higher than the flat top of the washer and try again.
2A, Inserting the drain hose too far into the house drain. or 2B, sealing out ALL air in the drain line by using a hose too tight in the drain pipe or taping the drain pipe tightly with the drain hose in it can both create a vacuum in the drain line which will actually **** out all the water in the tub. This can be tested by pulling the drain all the way out and aiming it into the tub as you try it. Good Luck.
Aug 23, 2009 | Maytag Washing Machines
Over flowing on water discharge
Feb 01, 2009 | Kenmore Washing Machines
Running water
Sounds like your stand-pipe has fell over,located behind machine that the drain hose goes into.This pipe must be vertical,and secure.The top of the washers drain hose loop that goes into the stand-pipe, should be as high as your soap dispenser.If this is not the problem then your water pump must be pumping the water out all the time.Can you hear the pump? If so, some faults can force the washing machine into a constant cycle of filling with cold water and pumping the water away if it thinks the washing machine is overheating (possible faulty thermistor).Hopefully its only your stand-pipe causing the loss of water.Lets know how you get on.Good luck.
Sep 05, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
