Question about Senco Tools & Hardware - Others
Nails failing in mdf
Nails bend when exiting mdf
2 Suggested Answers
  • 142 Answers
SOURCE: Nails don't drive all the way in
I hate to say this, but it is the material you are nailing to, we have trouble with air nailers nailing mdf so I am sure the gun is even more underpowered for the job
Posted on Jul 19, 2009
How to solve the issue when fautly grounding point casuing ADSL ports failed of ADLE board.
1- Service boards found normal, only the ADSL ports are appearing as Failed and found on almost all ADLE boards of the Huawei MA5616.2- Control Board found normal and there is no communication lost alarm between control board and service board.3- There are chances of some exceptional surge from outside coming through MDF towards system causing Huawei ADSL ports failure. Initially we reset the chipset of board to restore the services and move to step 4.4- We check the grounding point of system and MDF, it was not working and test result is as mentioned in snapshoot. The device was installed in switch room, we check the grounding values of MDF and switch room it was not according to standard and resistance values were too high. We also check the grounding point of other room (Transmission Room) in same building where SDH system was installed, its value was 1.31 ohm which is normal.On investigating we found that the grounding supply of MDF and switch room is different from transmission room and grounding supply of MDF and switch room was actually not working. We connect the grounding cable of MDF and switch room to transmission room's grouding plate and issue resolved after that.
Root Cause
1- Service Board faulty.2- Control Board faulty.3- Exceptional surge from outside lines.4- Grounding / Earthing point faulty.
Suggestions
For such kind of issues specially for Huawei Access Network, must check the grounding of the equipment and MDF. The equipment and MDF should be properly grounded and tested regularly the resistance value of grounding must be in the range around 1 to 5 Ohm.
Mar 22, 2017 | The Computers & Internet
My nailer will drive 1 nail then the hammer slides over the top of the next nail bending it and jamming the gun. It was working then this started.
There are many brands of nails that fit into the rail however the angle or gauge my be a little off thus causing miss or jam. One method to check for good angle is to place the strip of nails on the outside of the rails aligned with the top. The first nail should align with the path of the driver. If off alignment do not use them. With pinners or staplers the gauge is important. Remove one pin or staple from the strip and make sure it fits snuggly thru bottom exit. Too tight or too loose will jam. Good luck
Feb 15, 2016 | Air Tools & Compressors
Import damaged SQL MDF file
I would like to suggest you to use of MDF Repair Kit. An exciting new product from Repair Kit, this MS SQL MDF repair tool is an absolutely indispensable tool for anyone who wants to know how to repair MDF files in minutes. The program is based on a powerful analysis core and uses a convenient wizard-driven UI.
For more: http://www.mdf.repair/
Apr 25, 2015 | Microsoft SQL Server 2005 Enterprise...
How to build a sound box by 15 inchess speaker of 600 watts
What sub? And what volume do you need? First off you will want to go get yourself a sheet of 3/4" MDF, nails, resin, etc. You'll also want access to a table saw and drill. Decide how much volume you need and then settle on some dimensions to achieve that volume.
Nov 19, 2009 | Car Audio & Video
Does not seat nails ,no matter how the depth is adjusted. dissembled unit and found nothing amiss looked clean and oiley
sounds odd. What are you shooting into, if its MDF, that is just the nature of the wood
check the pressure from the regulator, should be between 80 and 120 psi
Oct 16, 2009 | Craftsman Nailer Kit, Palm Air Driver
Jul 19, 2009 | Tools & Hardware - Others
When the 2in 18 gauge nail enters the wood it turns in the wood and comes out the side of the wood,
That is actually the nail failing. If you try shooting any 2in. 18ga. nail into something hard like Maple or even red oak, the nail will bend. It will typically follow the grain. So Go to at least a 16 ga. nail for hardwoods.
Jun 28, 2009 | Senco Tools & Hardware - Others
Paslode 5350/90S PM Powermaster Bends nails over
USUALY THIS IS CAUSED BY TO LOW OF AIR PRESSURE(NEED AT LEAST90-100PSI)OR NAILING INTO SEASONED HARD WOOD SUCH AS OAK,OR THE WRONG DEGREE PITCH OF THE COLLIATED NAILSHOPE THIS HELP'S.PLEASE RATE THIS .
May 16, 2009 | Air Tools & Compressors
I am about to put my 6x9 speakers in my car. i would like a little advice if possible. it will not be a tricky job as all the connections have been done (by a car garage). all i need to do is put the...
Typically the best way would be to remove the interior trim piece from the shelf. Then have a friend hold the MDF board up from inside the trunk. Then run either screws or bolts/nuts through from the interior all the way through the MDF. Replace interior trim piece and it should be held in tight.
Another less intrusive way would be to use a strong adhesive, such as "Liquid Nails" to secure the MDF to the bottom of the shelf. You'd need to figure a way to hold the MDF to the bottom of the shelf for quite awhile (8-24 hours) to make sure their is good adhesion.
Jan 31, 2009 | Car Audio & Video
Tools & Hardware - Others Logo
22 people viewed this question
Top Senco Tools & Hardware - Others Experts
John Trevino
yoopertech
John Bowen
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
