Question about Samsung HCN653W 65" Rear Projection Television
Samsung HCN653W 65 has wavy vertical lines
My samsung has vertical wavy lines across the screen no matter what input it's on but thay go away after awhile (about 20 mins or so) the lines are fant
  • 5 more comments
  • mikeymlf Dec 03, 2007
    I have the same Samsung 65" HCN653WX TV and am experiencing the same wavy, vertical lines. They are more noticeable on dark, solid pictures and less noticeable on bright or mottled images. They make the picture quite fuzzy. I would love to know if there is an easy fix to this.
  • jginsberg Dec 21, 2007
    I have the same wavy vertical line problem. I thought it was interference with my cables. I bought expensive cables, re-routed them and used exact lengths and the problem is still there. For what it's worth, when I switch to my Xbox 360, it is prefectly clear.
  • cwalker6000 Apr 23, 2008
    Sounds like the same problem I'm having. I can unplug everything and still see the lines on the screen. Anyone have any luck fixing this?
  • chrisheadley Jan 30, 2009
    i have wavy vertical lines on my screen no matter what input is on. and i need help knowing what the problem is.
  • nytrowe Feb 17, 2009
    vertical herring bone lines on my tv thats more noticeable on dark screen.
  • El PiPiL Feb 19, 2009
    Same here ya'll but no Solutions... just Sale Sale Sale... call me man for a REadin...
    Anyone else has a valuble answer they can suggest??..
  • Anonymous May 26, 2009
    Have the same wavy lines, have you all found out whats going on?
  • 230 Answers
I can help you,  call me 910-8936663
Posted on Oct 27, 2007
  • 1 more comment
  • Josh Herzberg
    Josh Herzberg Mar 06, 2012
    I'm having the same issue
  • Josh Herzberg
    Josh Herzberg Apr 02, 2012
    I'm having the same issue but they are not going away.
  • mann83 Aug 02, 2014
    it's the board with the inputs & the tuner that go bad on this model
Bulb does not do anything but project white light. Wavy lines are a digital board problem. You should have a tech look at it.
May 20, 2015 | Samsung Televison & Video
Picture has a sag in the middle, blurring the sides of the screen.
okay that sounds like a problem in the horizontal circuit and vertical circuit.the module of those section wants to be replaced.only a tech can do the repair.look for a tech to repair your tv
Sep 25, 2011 | Samsung HCN653W 65" Rear Projection...
My Samsung HCN653W 65-Inch Widescreen Projection HD-Ready TV has a 3d like picture when it has been on a hour it goes back to normal
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
You can get the correct parts, step by step photo instruction guides, and support from or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Jan 05, 2011 | Samsung HCN653W 65" Rear Projection...
All of a sudden my 6 yr old samsung HCN653W has a
your cable box is effecting the component line in 1 or 2 in the back of the tv
Jul 12, 2010 | Samsung HCN653W 65" Rear Projection...
Screen is distorted and has wavy line across.
46" Samsung LCD, screen is distorted and has wavy lines across the screen.
Sep 26, 2008 | Samsung Televison & Video
Please advise if you would be able to guide me as to where i could purchase tv parts...
Hello MMJB,
Here are the link to purchase your parts.
Best regards
Jul 09, 2008 | Samsung HCN653W 65" Rear Projection...
Red lines when watching DVD
Regardless of what inputs you use when the lines appear, that symptom suggests that the Proscan Module Samsung p/n#BP95-00140T is probably defective. That board is a plug and play replacement but there are no short-cuts to testing it to be certain that's the problem or the entire problem. That said, the top of the metal shield lifts off and the board can be pulled with no greater skill than a first year technician. The board is $184.25 plus shipping from Vance Baldwin - so if you're feeling lucky you could try this one yourself... Just be careful. If you have ANY questions drop me a note at and include the model number. Hope this helps Bill Good luck
Jun 05, 2007 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W 65 in.!
My first guess is it kind of sounds like a convergence board problem i know they had some service bulletins on them. hope that helps oh and convergence boards arent exactly cheap and will probably require some soldering
Mar 22, 2007 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
856 people viewed this question
Jerry Greenberg
Jerry Greenberg
