Question about Kenmore Refrigerators
Need to know size
Model 363.78282891
Need to know model scope is. serial #09-0801149
I'd call the company. We have no way to find out the size from just the serial number.
Apr 18, 2014 | Centerpoint Technologies Center Point...
Need thread size for Husqvarna decompresion valve
dont know off the top of my head however you can get a thread identifier tool for 5 bucks, or if you have a tap and die set you can see which one fits then read the number off the side
Dec 17, 2013 | Husqvarna Chain Saw Models 51, 55
Freeze Plug size
When you buy one from a parts store or from the dealer, they will know the size you need, based on year, make, model and the particular engine size that is in your vehicle.
Jul 28, 2013 | 2005 Kia Spectra EX
Whats the size of power steering belt 96 rav 4
I know this doesn't give you the answer now, but know one will know exactly what size, unless you call the auto parts place, and give them the year, model and make, size of engine... they will have the parts look up you need, price, and you can be sure you get the right one.
Nov 14, 2012 | Cars & Trucks
Would like to replace need to know size of unit and age.
this unit is a 3 1/2 unit...the 42 the model number...possible its a 89 or 97 model...this is a 42,000 btus unit...hope this helps...michael 843-384-8474..
Mar 27, 2010 | Heating & Cooling
Need to know the exact size of rims for a 2008 323i sedan BMW
2008 BMW 323i 4 door sedan - factory wheel rim size
Rim size (standard factory spec):
16 inch by 7 inches wide.
Front and rear are the same size.
(It is possible to fit 17 or 18 inch rims to the car if you wish together with an appropriate lower profile tyre ).
(please note that different models in the 2008 3 series BMW have different size rims. For example, the 328 and higher level models runs larger rim sizes).
Hope this helps. Cheers
Dec 08, 2009 | 2008 BMW 3 Series
Need to know breaker and wire size to run from panel
Compressor 12/3 with 20 amp dual pole breaker. 220 VAC
Freezer 12/3 with 20 amp single pole breaker 120 VAC
May 24, 2009 | Nor-Lake Freezer Walk In Freezer 6ft x...
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
I need to know the type or size(tons) air handler
3 and a half ton S3642C6AA
42 is the unit size then you divide that number by 12
May 05, 2009 | Heating & Cooling
Refrigerators Logo
20 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
