Question about BMW Vehicle Parts & Accessories
I have got a bmw 3.18 E36 and a couple of days ago I did some work and disconnected my battery. When I reconnected the battery and wanted to disable the alarm, my left indicator kept burning. I think it is a relay under my dashboard, but when I tried to check the relay, I saw that the whole system is in a black box and this is sealed. So now I need to know if I need to replace the whole system or if there is another solution.
SOURCE: Car won't start after replacing battery.
CHECK THE MAIN FUSE
Posted on Jan 03, 2009
jpk528
  • 95 Answers
SOURCE: Car alarm won't reset after disconnecting car battery
you should try to hit the unlock button on the remotes and that should disarm it. Try disarming that, that way and if that doesnt work we will go from there
Posted on Feb 22, 2009
  • 87 Answers
SOURCE: 1999 jeep grand cherokee will not start because of alarm
Sounds like the brain quit on you, I would uninstall it or completly disconnect it and have it looked at. Make sure you reconnect the factory wires and start over. Also check the ground for the alarm as it will draw current from what ever wire it can and cause all kinds of things.
Posted on Jun 03, 2009
  • 41 Answers
SOURCE: cant disarm bmw e36 alarm
try putting key in all exterior key cylinders and unlocking them
Posted on Feb 03, 2010
  • 103 Answers
SOURCE: VIPER CE0890 My alarm started going
Turn ignition to the ON position, press and hold the valet switch under the dash. It should turn the LED light on solid
Posted on Aug 21, 2010
Something is draining the battery on our 2002 bmw z3.the battery and alternator checks out good,what is draining the battery??
HELP 2000 Z3 Battery Drain - Bimmerfest - BMW Forums
www.bimmerfest.com > ... > Z Series > E36/7 Z3 (1996-2002)
Feb 18, 2007 - 7 posts - ‎6 authors
HELP 2000 Z3 Battery Drain E36/7 Z3 (1996-2002) ... Something is draining the battery. ... Posts: 55. Mein Auto: 2000 BMW Z3 2.8 Roadster. z3 1.9 battery drain (fuse 31)
Apr 9, 2013
Intermittent car battery drain problem NEED HELP
Jan 29, 2013
Mysterious Battery Drain
Feb 23, 2008
Battery drain....after 2 days sitting dead...
Mar 28, 2006
More results from www.bimmerfest.com
Jan 18, 2016 | 2002 BMW Z3
Bmw 735 li e65 change battery and i get many problem no value to set clock radio not working cd also i disconnect the battery still the same problem
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your BMW service centre and get them to enter this code for you.
Jan 15, 2013 | Cars & Trucks
The airbag light on our 97 bmw came on a couple days ago and won't go out
1st when the airbag light is on the system is disabled, so if u have an accident they will not work, as to the common cause read below.
When the airbag light is on it means a fault has occurred in the system and the airbag diagnostic monitor has disabled the system, the most common problem that turns the light on is a break in the connection to the steering wheel mounted airbag, this is due to a rotating ribbon contact that breaks under the steering wheel that connects the airbag to the wiring harness and the diagnostic monitor, the part is called th clock spring contact, a coiled up ribbon electrical contact that turns with the wheel
Oct 25, 2012 | 1997 BMW Z3 Roadster
Engine wont start, BCM just replaced, inflatable restraint and check engine light on.
need to start with do you have any obd code with key turned on
caddy is more complex system than most , check fully charged battery, and not a jump start, and battery is in very good condition .disconnecting battery would only clear codes leaving you with nothing to go on hopes this is some help to you.
Sep 29, 2012 | 1991 Cadillac DeVille
Looking at the fuze box in a 1996 BMW 328i, the drivers seat adjustment fuse is #40. Where is the #40 fuze located?
Fuse box should look like the one shown on these pages:
Fuse box diagram BMW 3 E36
http://bmw-e36.com/repair/8-bmw-e36-fuse-box-diagram-318i-1996.html
The longer single row of fuses is #31-46 (46 is closest to the double row of fuses).
Hope this helps!
Feb 28, 2018 | 1996 BMW 328i
Bmw e36 325is. I have put stop leak at the radiator couple of months ago no prob. At all. But now coolant is coming out the cap and the car over heats but really slow and never goes more than just over the...
Sounds like a stuck thermostat, if both hoses are warm to the touch evenly, then the thermo is doing ok, possibly sticks once in a while. You might want to flush the system, if you are using stop leak, you have a problem that now needs attention.
Jun 12, 2017 | Cars & Trucks
E36 BMW 318I CENTRAL LOCKING A. I bought a 2nd hand 1995 BMW 318I in South Africa. Good condition. No owner?s manual. Everything worked ok for a few months. Then the batteries of the remote key transmitter...
try locking and unlocking the car with the key 3 times slowly ,other than that i have no idea ?? another trick is to disconnect battery and join the cables together for a few minutes to discharge any capacitors that may be holding a charge in the computer..Only other thing i can think of is the main dealers who have the right connectors and software to re set it all .sorry i havent been of any help
Aug 04, 2009 | BMW 318 Cars & Trucks
Bmw e36 immobilised, iginition lights come on, but the starter wont turn over. how do i start the car to get it to a garage, i dont wont to pay the £70 for recovery truck
BMW E36 immobilizer Hope the following will help. Had similar problems. The transmitter buttons on keys is for central locking and alarm. Inside the key at the front there is a small electronic/magnetic chip that looks like a block. About 8mm long, 2mm deep and 4mm wide, not connected to any pc board. This is the immobilizer. It must match the receiver that is located behind the ignition switch. If it is loose and too far away from the receiver it won?t deactivate it. If you made a spare key it will switch on electrics but won?t start the car. If you don?t have an immobilizer chip any alarm shop will be able to program a new chip or install a new pair for your keys. There is a way to disable the immobilizer but rather have it fix and protect your car. I read an article somewhere (perhaps bmw e36 blog) of people removing this immobilizer. Good luck
Jul 06, 2009 | 1997 BMW 328
Vehicle Parts & Accessories Logo
70 people viewed this question
Top BMW Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
greg benton
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
