Question about Infiniti Vehicle Parts & Accessories
1995 q45 security light flashing and injector not firing
I have a 2003 Nissan Sentra 1.8 black guy has no injector pulse no ignition fire what would the problem be and how can I fix it
Being it is two separate areas in the computer. Check and see if the security is set. Light would stay on or flashing. Check fuses. then check for power at the injectors and coil pack/s
May 15, 2016 | Nissan Cars & Trucks
Security light on and won,t turn over engine to start . rolled car on to the roof on black ice. physically car looks ok
Car Won't Start Because of Anti-Theft System ... - RepairPal
repairpal.com > Problems > Oldsmobile > 88
Car Won't Start and Security Light is On on Oldsmobile 88 ... key turns over enginebut fails to start some times..security system keeps the fuel injectors from ...
repairpal.com > Problems > Buick > LeSabre
Car Won't Start and Security Light is On on Buick LeSabre. Problems with the ... 1998 Buick LeSabreVisitor. Turn key on every thing come on but won't turn over.
repairpal.com > Problems > Pontiac > Bonneville
Replaced trans, engine, PCM and bcm, now starter diabled- theft flashes on service ...1995 Bonneville car turns over but wont fire an security light is flashing car ...
GM Passlock Security Light Issues - RepairPal
Dec 26, 2015 | Cars & Trucks
1995 3.8 liter park avenue won't start has spark and power at injectors and fuel pressure
I think i know what the issue is. Ive had the same one in my impala. It is very common in GM cars. It has to do with the security system failing. I found a module that will bypass your issue all together. I used it in mine more than 5 years ago and i havent had a problem since. The part is also guaranteed and you can do it yourslef . Check it out they have really good customer service so if u have any questions feel free to email them. Good luck Do It Yourself GM Security bypass
Jun 20, 2015 | 1995 Buick Park Avenue
1995 Chevy 3500 not getting gas I'm getting gas all the way to throttle body. I have tried 3 sets of used injector same response
Is the pressure regulator operating? You need at least 30 lbs to fire an injector and make sure the check valve it it maintains 30 lbs with the engine off.
Sep 24, 2014 | 1995-1997 Chevy 3500 Truck Ignition...
Injector issues.
Well, if you have a ground signal on one injector and not the other, the ECM is not grounding it.
If the plugs are firing on those cylinders, it may be the driver in the computer. The computer uses the same signal from the distributor that fires the plugs to pulse the injectors.
If those cylinders are not firing, it could be the pickup coil in the distributor or the module.
Sep 03, 2012 | 1995 Chevrolet K1500
No fire to fuel pump key faul light stay on
If the key fault light is on, it is most likely the anti theft security shutting off your fuel to the injectors. If this is the case, you can bypass this system to get around that anti theft. http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jun 15, 2011 | 1995 Chevrolet Caprice Classic
Fuel injectures wont fire in my 95 chevy 1500
Do you have fuel pressure? Buy or borrow a noid light, it plugs in to the injector plug and lets you see if the injector is getting the electrical pulse it needs to work. If the noid light flashes you need to look at fuel pressure, bad pump, clogged filter etc. If it doesent flash look at the ecu or distributor pick up
Mar 13, 2010 | 1995 Chevrolet K1500
I have a 2500 chev truck 5.7 ldr engine does not fire on rt bank i put new injectors in still same problem
You mean no fire/spark. replace your distributor cap and rotor. If your injectors are not pulsing, then it may be computer related.
Feb 16, 2010 | 1995-1997 Chevy 3500 Truck Ignition...
Vehicle Parts & Accessories Logo
23 people viewed this question
Top Infiniti Vehicle Parts & Accessories Experts
advance tire and...
Level 1 Expert
Rigger
George Agios
George Agios
Are you an Infiniti Vehicle Part and Accessory Expert? Answer questions, earn points and help others
