Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Can we use gas stove when electric power is off?
Electric power is off? Will range burners and/or over work?
  • 146 Answers
SOURCE: electric start gas range
You either have a short in your electronic ignition or the ignition board is defective. Check the wiring to the ignition board for shorts. also check and make sure you ignitors are well grounded.
Posted on Dec 21, 2007
appldoctom
  • 311 Answers
SOURCE: One of the burner does not work on my electric Kenmore stove.
the eazy answer is its the burner.i only say that because on most service calls with your complaint it dose indeed end up being the burner.but before i come to that conclusion i do check the out put of that burners switch.if has 220 volt output then its the burner,even tho if you look at the wiring diagram it will show a limiter before it gets to the burner but that part is built in to the switch and is not replacable on its own.so then use volt meter take a look at your wiring diagram .look on that diagram and decide which wires are leaving the questioned switch that controls your bad burner .place your probes on those wires again if reads 220 volts replace the burner. i hope this helps .God bless ,tom
Posted on Jan 07, 2009
erpaalai
  • 999 Answers
SOURCE: kenmore elite gas range clicking sound
If unplugging it for a couple minutes and plugging back in does not rectify then it sounds like a bad spark module or a shorted wire inside. All 4 should spark at the same time when any burner is used. (Does trying to light a burner make the other 2 spark too?)
Eric
Posted on Jun 20, 2009
EllaWatson25
  • 725 Answers
SOURCE: I have a Kenmore electric ceramic top range. While
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Posted on Mar 11, 2010
Testimonial: "Sorry about not putting in the model number, etc. I bought a used burner switch for 10 bucks and the burner seems to be working...we'll see. Thanks "
SOURCE: When I use my gas range it smells like lighter
I am having the same problem with our stove in our new house. We just moved in and everytime I turn a burner on it smells like charcoal lighter fluid. Anyone know what this is?
Posted on Sep 14, 2010
I have no electric power (i.e., clock, oven don't work) but the gas works fine.
Older stoves didn't have electric start so pilot stays lit on burners when power goes therefore burner will still light. Oven won't work since it probably needs electric power or has electric starter.
Feb 15, 2016 | Kitchen Ranges
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Dec 15, 2015 | Kitchen Ranges
2 hobs on my electric cooker are not working
? 2:34
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
? 6:52
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Brown gas range auto ignition not working
If the problem is with all the burners then the igniter module may be defective. If this is happening only with some burners then the cable to the ignition point has become loose or is shorting with the body.
I am assuming the model number is correct but I am not finding any details for this 24 inch freestanding gas range. If the oven is electric and if it is running that means at least the electric power is reaching the unit.
Brown Stove Works INC
The oven parts are available here
Brown Range Stove Oven Parts
Sep 03, 2014 | Brown Stove Works TM110-3 Gas Kitchen...
Problem with Kitchenaid Electric Range Stove Top Burner
there may be a loose connection in either the pipe or on the burner rings on the surface. Some stoves have a safety cutoff if gas supply is interrupted to avoid prolonged gas supply.
May 12, 2012 | KitchenAid KERA807P Electric Kitchen Range
Can you light the burner if you have no electric
if its an electric stove no it will not light without electric if its a gas stove make sure the pilots are lit under the panel where the burners are
Jan 31, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Hi, Have purchased stove below and just need to know how to connect to 12 volt power supply to get ignition for lighting gas burners. I cannot find any connections to hook up 12 vott power to, hope you...
Cliff,
Your ad says you have an Electric Range and I googled the model number and it says electric,
Why are you putting Gas into a electric range.
You would have to rewire the whole range because of the heat that gas makes. Wires have a certain grade when working with electricity only, and a certain grade when using both. Electric Range usually stay Electric, Gas ranges for Gas.
Let sleeping Dogs lye
Aug 05, 2010 | Stoves Newhome ECH600MXa Electric Kitchen...
The electric panel on my smooth top stove just went out with a popping sound rendering the oven unusable but the stove top burners are working.............what could have happened and is it worth it to get...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 21, 2010 | Kenmore 95423 Stainless Steel Electric...
GE profile stove, Gas-electric
All oven elements are 115/130 VAC. Stoves use 220/240 so that you can use both the burners and Oven at the same time. Since the burners are Gas, then 220/240 VAC isn't needed.
(Note: 220 is simply dual 110 hot leads with a common ground)
Aug 31, 2008 | Tappan MEF500 Electric Kitchen Range
Electric starter for Electric stove
I think you mean you have a gas range with electric ignition. When you turn a burner to light, all burners should spark. The most common problem is boil overs have happened on those two burners. Take the burner head off for sealed burner ranges and clean them out. For non sealed burners, the little holes toward the center side of the burners need to be cleaned. You don't have a model listed, so I can't be real specific.
Aug 15, 2008 | GE Spectra JBP78 Electric Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
13 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
