Question about Emerson Microwave Ovens
Changing the light bulb in Emerson microwave oven
Where can i get a screw driver that can unscrew the special screws that Emerson microwave oven has in the lower part of the back ??
SOURCE: kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
Posted on Feb 06, 2008
FRANKSFIXIT
  • 72 Answers
SOURCE: Lightbulb in Emerson microwave model MW8115 SS
You have 3 choices to use on removing the safety screw(s) on the MW (microwave or nuker as I call them) cover.
1 - The screw(s) is/are usually a modified TORX T-20 or T-25 bit adapter. Sometimes you can very carefully use a standard T-20/25 bit adapter to get the screw loosened. Sometimes! If that doesn't work then you have option #2.
2 - If #1 doesn't work you can use a small flat blade screwdriver that has been modified with a slot cut into the center of the blade end to bypass the center pin. First find a narrow enough flat blade srewdriver that you don't care about anymore, and make sure it fits rather snugly inside the screw-head just for a loose fit. If the blade is a bit wider - no problem - it can be ground down to fit snugly. Next - using a dremel tool and diamond cutting wheel attachment (or similar) cut a slot into the end of the blade. Make sure that the screwdriver is going to bite the insides of that screw-head first though before wasting a perfectly good screwdriver. You will have to adjust by trial and error until you get the blade to fit perfectly the head of the safety screw. If the screws are really tight use a pair of vice grips to clamp the screwdriver blade for extra leverage.
If neither of these methods work for you or you can't modify a special tool then you will have to do the last option.
3 - Using an easy out of proper size drill out the center pin and then use the proper "easy out" to back out the screw. Discard that/those screw(s) and replace with regular phillips head screws after replacing the light bulb.
Hopefully you will be able to do this repair yourself? Otherwise if your neighbor is Tim the Toolman Taylor I'm sure he'll be able to give you the necessary hand to do it for you.
Hope this helps fix your dilema you are in.
One note here -
Make sure you unplug the nuker first and be VERY CAREFUL as to NOT TOUCH the HIGH VOLTAGE CAPACITOR inside. Otherwise you risk a chance of SEVERE HIGH VOLTAGE SHOCK!!!!!!!!!
BE VERY CAREFUL....
Best regards,
Frank
Posted on Mar 07, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Removing over the range microwave
You can download the installation instructions, which are quite helpful when uninstalling.
We have uploaded them to our site for you here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Oct 20, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Replace light bulb on Whirlpool GMC305PDS07
You'll need to remove the outer cover (wrapper) to get to the bulb.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Mar 06, 2009
How do I change the light bulb in a magic chef microwave?
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker
https://www.hunker.com/13407988/how-to-replace-a-magic-chef-microwave-light-bulb How do change the light bulb in magic chef microwave Google Search
Oct 24, 2017 | Magic Chef Microwave Ovens
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
How to change a light bulb in microwave
Things You'll Need
30-watt incandescent light bulb
Screwdriver
Light
Remove the screw from the light cover located on the left side of the underside of the microwave. The light cover is connected to a hinge and will lower, but cannot be removed from the microwave.
Unscrew the light bulb, then screw in the new light bulb. hope this helps
Oct 08, 2016 | Magic Chef Microwave Ovens
How to change interior light bulb Emersom Microwave
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
Bulbs (or 20A ceramic fuses) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Oct 28, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Blown Light
Jan 27, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
How do i change lite bulb in my microwave
Jan 12, 2009 | Emerson MW8107WA Microwave Oven
Oct 11, 2008 | Magic Chef MCD1311ST Microwave Oven
Emerson microwave light out
There is a way but.... you will have to remove outer cover generally held on with screws at rear and under microwave be sure the oven is unplugged and when you take cover off there is a capacitor in there thats holds a charge stored even when oven is unplugged so dont touch nothing except the light bulb would prefer if you dont have much electrical experience to take to repair shop or have someone do it who has a little electrical knowledge hope this helps
Sep 05, 2008 | Emerson MW8107WA Microwave Oven
Burned out light bulb
can u open the housing?. you can look at the spot where the light is and you can see a bulb holder screwed on the metal housing. it has two wires hooked up to that holder. remove those wires and unscrew the holder of the bulb. look closely at the bulb if it is fiited to the holder like an ordinary light bulb. if its like that then you can unscrew it and replace it. if its not screwed to the holder then you have to buy the whole bulb assembly at the dealer of your microwave. it is considered a special bulb only from the dealer you can get. i hope i was able to solve your problem..
Feb 18, 2008 | Microwave Ovens
Where is the light bulb located?
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
Nov 03, 2006 | LG LRMM1430 Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
