Question about Tablets & eReaders
Battery not holding charge imedia blaze - Tablets & eReaders
Samsung tab 3 10.1 CE0168 Wont charge or come on ?
have you tried a hard reset?, take battery out and disconnect from power supply then hold power button for thirty second then replace battery and try to power up else hold power button and volume down for 30 secs need to keep battery in for this one, if they dont work you need to contact samsung to get it repaired.
Feb 06, 2017 | Samsung Tablets & eReaders
Why will my ellipsis 7 no longer hold a charge ?
All rechargeable batteries will eventually fail to take and/or hold a charge. In some cases it is due to being worn out, in others it is due to what is called "battery memory". Battery Memory occurs when a battery is charged often, but is not allowed to fully discharge between chargings. It was really bad with the old Ni-Cad type batteries, but all batteries can have some affects.
Oct 01, 2016 | Tablets & eReaders
My kindle will not hold a charge for more than one day even after it has been fully charged
your battery is gone need new one when u charge your battery then it dies and this happens a bunch of time it is fryed cause when it is charging it heats up if it is holding for a day all may not be lost my kid leaning over my shoulder and hitting my last nerve just told me if u can get the battery out safely to put in the freezer for about ten mins make sure it fully charged and ONLY THE BATTERY gos in the freezer that battery will last a bit longer but its not a perment fix it gives u time for pay check or whatever reason to get it fixed oohhh my child has one more input to air out NEVER play on it or anything like it when it is charging that makes it heat up more and faster to killing a battery and never over charge does same thing good luck
Aug 11, 2015 | Amazon Kindle Fire HD
Battery will not charge
Your battery may be defective and cant hold a charge. Make sure the unit is receiving power and if so replace the battery.
Dec 15, 2014 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
My tablet will not hold a charge
u have change the battery as the battery is dead...
Apr 12, 2014 | Visual Land Connect 7" Tablet
Resetting imedia blaze 7
hi my kids have been pLAYING WITH MY TABLET AND SET A PASSWORD I DNO HOW CAN I GET RID OF THIS
Mar 05, 2014 | Tablets & eReaders
How to change the battery in an iview 754TPC? The battery will not hold a charge.
If the battery isnt holding the charge then you may need to buy a new battery and you can easily order a replacment battery online to make it work.
Nov 04, 2013 | Gateway M275 Tablet PC
How do you run a battery recalibration
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced
May 26, 2010 | Panasonic Toughbook-19 Tablet PC
Tablets & eReaders Logo
127 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
