Question about Enermax Computers & Internet
How to install a enermax power supply - Enermax Computers & Internet
What fuse is in a Enermax EG495P-VE Noisetaker 485W Power Supply
Just buy a new power supply. If you touch the wrong thing inside that psu you will die. Seriously.
Aug 15, 2012 | Enermax (by Coolergiant) EG495P-VE SFMA...
How can I test voltages on the Enermax Galaxy EGA1000EWL 1000-Watt Power Supply unit out of the computer.
Most motherboards will give tell you all of the voltages being provided by the power supply in the bios under hardware or health monitoring section. Otherwise you will need a multimeter to test the different voltages. You would want to set the multimeter to the 20v or similar setting. Depending on what voltage you would want to test would determine the color of wire you would check. You would connect the black/negative/ground lead of the multimeter to one of the ground wires coming from the power supply normally a black wire. The 12v is normally a yellow wire, the 5v is normally a red wire and the 3.3v is normally an orange wire. The wires may be different colors so you may want to look up the ATX pinouts to find the exact voltages you want to measure.
Feb 23, 2011 | Enermax Galaxy EGA1000EWL 1000-Watt Power...
Both fans stopped working which overheats the PSU. Can this perhaps be a fuse?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Jan 17, 2011 | Enermax Noisetaker EG425P-VE...
My computer will not power up at all been looking for another compatible power supply since this one is discontinued need help immediately.. enermax eg425p-ve
I'd check into a DiabloTek PHD650 650-Watt Power Supply. It's a higher voltage module, but has similar features to your Enermax power supply. If you can't find it locally, check out TigerDirect.com (my fave) or NewEgg.com. These two sites are likely to have these, and are competitively priced.
Aug 31, 2010 | Enermax Noisetaker EG425P-VE...
WHICH POWER IS COMPATIBLE WITH THE CACT05UW CASE
ANY good power supply will fit.
Go for a good make 80+ rated supply
Try
seasonic
silverstone
ocz
enermax
Or just google 80+ psu
Aug 19, 2010 | Computers & Internet
My enermax power pack sparked out of the fan in the back and now my computer wont turn on. Not sure if it's the power pack or the board is fried... Any help would be appreciated thanks =)
if it sparked then something inside the power supply malfunctioned and that is the reason it wont work. You will need to replace it. Unlikely that it fried your board in the process. You can test this by swapping the power supply with one that you know works.
May 20, 2010 | Enermax EG301P-VB (eg301vb) Power Supply
What power supply is the best
OCZ, Corsair, Thermaltake, CoolerMaster, Antec (voted 'most reliable power supply' by pcworld france), Enermax, Zalman. Any of these brands should do fine.
Don't buy a cheap one. Expect top ay between $60 and $150 in the US for a power supply)
Also, buy one that has a bit more power than the one you're replacing
Mar 27, 2010 | Dell (PS-5251-2DS) (M0148) 250-Watt Power...
Power supply , small plug hook up?
That plug is for the fan RPM monitor, it is not needed for normal operation.
Mar 06, 2009 | Enermax (by Coolergiant) EG495P-VE SFMA...
Psu shut down
99% TIME IT IS A FAULTY FAN GOING OUT.
REPLACING THE FAN INSIDE THE POWER SUPPLY WILL RESOLVE THE PROBLEM.
P/S ARE CHEAP, JUST BUY A NEW ONE OOR REPLACE WITH ONE YOU HAVE ON HAND
CANDYMANGANDY
Jan 27, 2009 | Antec Solution SL400 Power Supply
Power supply
I personally use an Enermax.
Enermax FMA 350W would be good. I've been running a 461 for 8 years now without any problems and I have yet to build something that it can't power.
Apr 25, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
Top Enermax Computers & Internet Experts
David Payne
David Payne
Are you an Enermax Computer and Internet Expert? Answer questions, earn points and help others
