Question about Radio Shack Computers & Internet
Sync jabar bluetooth with my phone
Sync bluetooth
How to sync car to I phone
Tand. I have not had to do it. You can try the attached links they tell how to link I Phone to auto.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://owner.ford.com/how-tos/sync-technology/myford-touch/phone/how-to-pair-your-phone-with-sync-with-myford-touch.html
How to Sync iPhone to Car Bluetooth
Syncing Your Bluetooth Device to Your Car
iPhone 5 Bluetooth Pairing to Your Car
Apr 20, 2016 | Cell Phones
Can't get my jabra blue tooth to pair with my
which jabar, which phone. Typically, you set your phone to find devices (may say scan or search). The jabar will need to be in pairing mode. Typically, you press the button that turns it on and hole it until the blue light comes on and then blinks. Blue light should maybe blink slowly. Then phone should now show the jabar device. You need to select the device line item on the phone. It may or may not ask for a code. code should be four zeros ... 0000. That should do it!
Oct 04, 2014 | Radio Communications
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 | Cell Phones
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Nokia Lumia 520 Smartphone - Wireless LAN...
Bluetooth pairing problem
if your phone does not pair with your jawbone then you might want check you phone's bluetooth visibility which can stop your phone from syncing even if your bluetooth is turned on. You can find it in bluetooth setting
Mar 17, 2009 | Cell Phones
Reset pairing mode to attach to different phone
With headset off... turn on bluetooth search from the phone.
Hold on button on headset until light turns solid blue. Then search for connection from phone. (code is 0000 (4zeros))
http://www.jabra.com/Sites/Jabra/ap-en/headsetsupport/pages/Knowledgebase.aspx?kbid=ee68a9ea-df26-4882-a7f8-a6cbcc42345c
Mar 07, 2009 | Jabra BT350 Bluetooth Headset Headset
Syncing blooetooth
Headsets don't be synchronised, as syncing means to update to devices with each other.
Bluetooth headsets are paired. Pairing means that both Bluetooth devices recognize each other and trust each other, so you do not need to provide any type of confirmation.
So, follow the phone's manual to see how to switch on the Bluetooth and make it visible. Now, there must be an option like make a new paired device. Consult your manual for this. The phone will search for a deivce and they will be paired.
You can even pair a PC and phone, phone and phone and every kind of Bluetooth enabled devices.
Jan 30, 2009 | Motorola Mobility H700 Wireless Headset
H350 bluetooth headset can't connect to laptop any solution connect to a motorola bluetooth headset how do I get my Motorola H350 bluetooth earpiece to work with my laptop?
Do you have the Jabra bluetooth part that goes into your computer? You have to go to your phone settings under bluetooth and make it sync up. Your phone will sync, not your headset. You are trying to sync the wrong thing.
May 04, 2008 | HP Pavilion dv6000z Notebook
How do i share music through the blue tooth
On the sync you have to find the phone you wan tto send to First. Go to bluetooth and search for devices find your desired bluetooth device and then go to you music click the options click send, move, copy on of them and click bluetooth find the device you paired with and it will send Bluetooth on teh Sync is rather fast too
Sep 23, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Computers & Internet Logo
15 people viewed this question
Top Radio Shack Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Radio Shack Computer and Internet Expert? Answer questions, earn points and help others
