Question about Radio Shack Computers & Internet
Sync my jabar with my phone - Radio Shack Computers & Internet
Can't get my jabra blue tooth to pair with my
which jabar, which phone. Typically, you set your phone to find devices (may say scan or search). The jabar will need to be in pairing mode. Typically, you press the button that turns it on and hole it until the blue light comes on and then blinks. Blue light should maybe blink slowly. Then phone should now show the jabar device. You need to select the device line item on the phone. It may or may not ask for a code. code should be four zeros ... 0000. That should do it!
Oct 04, 2014 | Radio Communications
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 | Cell Phones
My htc desire will no longer sync with my PC it asks to insert disk into drive E
Your solution
Setting up HTC Sync to recognize your phone
After installing, set up HTC Sync to recognize your phone.
1. From the Home screen, press MENU, and then tap Settings > Accounts & sync.
2. On the Connect to PC screen on your phone, tap HTC Sync and then tap Done. Your phone attempts to find HTC Sync on your computer. Wait for a few seconds for the process to finish.
3. If your phone displays a message indicating that it's unable to find HTC Sync, try disconnecting and reconnecting the USB cable, and then repeat step 2.
4. When the Phone Connection Wizard is displayed on your computer, click Next.
Enter the name you want for your phone, and then click Finish.
Check the HTC Sync icon at the bottom-right side of your computer screen. If it appears green in color, that means your phone has successfully connected with your computer and HTC Sync recognizes your phone
If still no go try this .
Unplug the phone from the PC, restart both the phone and the PC. When the PC is done booting, plug your phone in and see if the autorun box pops up.
still if nogo try this .
you have to select disk drive (when plugged in via notification area) to be able to view the drive in windows and htc sync to use htc sync.
May 27, 2011 | HTC Desire Cell Phone
New biss key for ptv k feed please send or thanks
plz ptv biss key plzzzzzzzzzzzz 03023286020
Mar 13, 2011 | Computers & Internet
Sync to my laptop
There is no syncing software for Android phones and your laptop. Android based phones sync with google and the gmail account you created. You can use google calendar sync to sync your calendar FROM google to your outloook, you can also export contacts to a CSV and import them to google to get them on your phone.
The best way to do it is to use exchange through intermedia or another service and have wireless sync that way, but there's no syncing option to go from your computer to the phone like the blackberry has.
Feb 12, 2011 | HTC Desire Cell Phone
How to set up my iphone 3gs after downloading itunes onto my computer
Connect your phone to your computer.
iTunes should open automatically, if it doesn't start iTunes.
iTunes will recognize your phone and sync.
On the left side of the iTunes windows, click and highlight your phone
Next, click on the "music" tab and choose the option for downloading song (sync entire music library, sync selected songs, etc).
Click the 'sync' button on the lower right to sync the songs to your phone.
After syncing, click the small arrow next to your phone's name to eject your phone...it is now safe to unplug your phone from your computer.
Dec 31, 2010 | Apple iPhone 3GS Black (16 GB)
Sir I lost my mob details below pl help
1.Once stolen you just have to mail this 15 digit IMEI no. to cop@vsnl.net
2.Your Mobile will be traced within next 24 hrs via a complex system of GPRS and internet...
3.You will find where your hand set is being operated even in case your number is being changed.
Sep 02, 2009 | Nokia 1100
Reset pairing mode to attach to different phone
With headset off... turn on bluetooth search from the phone.
Hold on button on headset until light turns solid blue. Then search for connection from phone. (code is 0000 (4zeros))
http://www.jabra.com/Sites/Jabra/ap-en/headsetsupport/pages/Knowledgebase.aspx?kbid=ee68a9ea-df26-4882-a7f8-a6cbcc42345c
Mar 07, 2009 | Jabra BT350 Bluetooth Headset Headset
Computers & Internet Logo
13 people viewed this question
Top Radio Shack Computers & Internet Experts
Mark Gough
micky dee
Mike
Are you a Radio Shack Computer and Internet Expert? Answer questions, earn points and help others
