Question about Maytag PYE2300AY Electric Dryer
When replacing coils how do I know I'm getting the right size
Code says bad heater
  • Maytag Master
  • 932 Answers
Best thing to do is have both your model number and serial number with you when you order or buy the heating coil. If you are buying from a store they should be able to look it up and make sure it is the right one. Most online places you have to put in your model number and then they will bring up a diagram of your unit and a list of parts and then you just scroll down and find the part you need.
Posted on Feb 19, 2014
I get a p0141 fault code . could this be caused by a coolant problem
no engine options (size) stated so... bad answers happen.......????
p0141 (federal code) is
P0141 Jeep - O2 Sensor 1/2 Heater Performance http://engine-codes.com/p0141_jeep.html
in bar stool , answer:
the heater is toast, (pun intended)
the heater burned up and open or is shorted.
Or as techs know>
bank 1 sensor 2 , rear , is bad or the wires cut or shorted there.
the Computer ONLY knows that test fails, NEVER why
and is never wrong.
the current is wrong. (amps)
Feb 15, 2014 | 2004 Jeep Wrangler
Trouble code PO 032
Trouble Code: P0032
O2 (B1 S1) Heater Circuit High
Possible Causes:
O2 heater element is damaged or the heater has failed.O2 heater control circuit is open or it is shorted to power.O2 heater ground circuit is open.PCM has failed .Hi Suzanne,here's a link to your firing order,your oxygen sensor in cylinder one,which is the exhaust manifold is bad.Need more help,I'm here.I took a guess at your engine size,if I'm wrong let me know and I will send you the right one.
Feb 03, 2013 | 2007 Dodge Ram Truck
Replaced:plugs,wiresdistributor,fuel pump.truck wouldn't start before but now it starts but i am getting po135,po141,po147.po300 codes
P0135 means 0xygen heater circuit malfunction, P0141 mean 02 heater circuit bank1 sensor 2 (this is catalytic monitor) P0147 means 02 heater sensor circuit bank 1 sensor 3, P0300 is random misfire. You will get all the 02 code because of the misfire correct the misfire and the 02 should correct.We will start with the plug wire and make sure the firing order is correct 1996 chevy blazer that will make it a 4.3 engine size check the firing order firing order is 165432 also check the coil (it has a tendency to short you will know if it is) cansmo_181.gifcansmo_182.gifmake sure the distributor rotation is check
Sep 09, 2011 | 1996 Chevrolet Blazer
I have a Kenmore model# 253.73754300. The problem I'm having is the freezer works but when it goes into the heater/defrost mode, it won't shut off the heater . The freezer compartment will get completely...
It sounds like the Termination Thermostat is bad , it's job is to turn off the defrost elements.You can get to it from the front inside the freezer. It's a small disk about the size of a quarter and about one inch tall. It will be attached to the evaporator coils. Be careful when taking it out not to damage the coils.Take it with you the parts store so that you get the right replacement.Be sure to unplug the refrig. before starting!!!!!
Mar 13, 2011 | Kenmore Refrigerators
I have a miss fire code on 1 and 4. They are saying that the coil pack is bad. How hard is it to change.
not bad. it may help to let us know what year, make, model, and engine size you have. I would recommend replacing the spark plugs, wires and coil pack.
Nov 16, 2010 | Chrysler PT Cruiser Cars & Trucks
04' Ram 1500, bad mis-fire. cust repl s/plugs. no help. Codes for coils #7 & 8 w/mis-fire. replaced coils & wire set. Better, but still P0300. Compression good
You still have random misfires (PO300)
You most likely replaced those coils that set a code, and those were not the one bad offender,spiking the computer module.
Take a new coil and put in a cylinder,no change, replace old coil and move new one to next cylinder. You can do that once or twice a day, if you have nothing else to do. You need a 90 degree day, to really get that solved,unless you have an ignition oscilloscope.
Never had a bad spark plug in 45 years.
Sep 18, 2010 | 2004 Dodge Ram 1500
Need to replace heater raidator under dash.anyone done one
The heater "coil" almost always requires removal of the entire dashboard and it's not much fun. You shouldn't even think about it without at least a Chilton's (or other) manual unless you're pretty used to disassembling and reassembling complex components. If it's leaking antifreeze, you can bypass the heater for now (brrrr) by splicing the heater coil's inlet and outlet hoses together. In the engine compartment look for two hoses, same sized, that are leading into your firewall. They'll be right next to each other, usually one above, rather than beside the other. They'll be the only hoses with anti freeze that attach to the firewall. Pull both hoses from the firewall and insert a splice, connecting these hoses. Secure with hose clamps. This will seal the coolant system and bypass the heater. The car will be perfectly safe to drive now until you replace the heater coil.
Nov 26, 2009 | 1999 Daewoo Lanos
Bad heater coil or prong
Assuming you have all wires disconnected from heater and only 2 terminals remain near the bottom of the heater can. A reading of "open" has to be the heater. You should be able to see a break in the coil when you remove heater.
Aug 22, 2009 | Kenmore 63942 Dryer
1999 dodge dakota p1762 code
dont know lots about this witout engine size but some have 1 coil per cylender possible coil is bad or plug 02 sensor will cause some problems but a miss fire will cause it to run like trash
Oct 08, 2008 | 1999 Dodge Dakota
Refer
Most likely the heater is bad. It is located under the evaporator inside the freezer rear wall . Look for a long glass tube about half inch in diameter with a long coil of wire inside. That is the heater . It can be unplugged easily.
Jan 21, 2008 | Maytag PTB2154G Top Freezer Refrigerator
Maytag PYE2300AY Electric Dryer Logo
29 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
