Question about Car Audio & Video
How do I fix an "overload" issue on my Pioneer 1-440-289-77198
Power it up and "overload" comes up, then shuts down.
Hi
im trying to unlock radio code on my honda accord can u help me?
Posted on Feb 12, 2014
Shut off during loud play
Many receivers have a thermal "overload" switch that will shut down power to protect the rest of the unit if it senses an issue like excessive heat, or if the ohms or impedance gets too high. This is a safety mechanism and you should probably seek a qualified audio repair shop for further troubleshooting.
Nov 19, 2013 | Pioneer VSX-518-K Receiver
Tip
My Pioneer displays Overload
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
on Jun 22, 2009 | Pioneer VSX-D608 Receiver
I have run my surround sound through my Pioneer vsx-d510 receiver for years without a problem. Today it suddenly started shutting down and flashing overload. There is nothing on top of it causing it to...
Just the same, FEEL for heat.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Feb 22, 2011 | Pioneer VSX-D510 Receiver
When i turn my system on it plays a little and says overloaded and shuts down itself.What is the problem
Sounds like heat build-up.
Generally speaking, an amp protects itself from heat, shorts and overloads. Check for loose speaker connections.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 31, 2011 | Pioneer VSX-515 Receiver
My pioneer vsx-816 sshows overload then shuts down,it happends when the volume is around 42 i have wharfedale speakers
Jan 25, 2011 | Pioneer VSX-817-S
Pioneer VSX D710S, I hook everything up and turn the unit on, after about 5-10 seconds it flashes POWER OFF and shuts down.
I wouldn't hold my breath waiting for free detailed circuitry.
A precise make and model might yield more-specific answer.
Jan 24, 2011 | Pioneer VSX-D710S Receiver
I just bought a VSX-820 and it seems to shut down automatically as soon as turn the volume up
Make sure the speaker wires are tight.
http://www.retrevo.com/support/Pioneer-VSX-820-K-Receivers-manual/id/23653ag912/t/2/
Jan 17, 2011 | Pioneer VSX-1016 Receiver
I was playing my ipod thru my Pioneer VSX-518 tuner and noticed that sound was coming trhough only 2 speakers. While playing the music I toggled through the advance surround options. When it came to...
I believe that smell is the death of a semiconductor in the surround power amp. How loud did you have it? As for an inexpensive fix, there will be hours of diagnostic work, and the parts can be VERY hard to find and expensive.
There is also the issue of safety. You should likely take it in for repair. Receivers aren't as dangerous as televisions or microwaves but they often have the two live 110V wires exposed near the primary of their power transformer. If you don't know what that means I strongly recommend you don't fix it yourself. These can also be dangerous even when they're unplugged, due to high value, medium voltage capacitors
Aug 12, 2010 | Pioneer VSX-518-K Receiver
Power overload
That is a good thing, your receiver is going into "protect mode" that means the receiver is shutting down to keep from damaging delicate internal circuitry, it is sensing a speaker bottoming out or some other electrical "short" that could be damaging!
Also could be from over driveing the amp and then it starts to overheat thus going into "protect mode".
If your speakers are "clipping or distorting" turn it down, you are going to ruin your amp. Good luck !
Jan 06, 2010 | Pioneer VSX-516-K
VSX-D608 Overload and shutdown
No more than two 4 Ohms speakers can be connected to the unit, or you will get overload.
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
