Question about Tunturi T20 Folding Programmable Treadmill
Tunturi T3.5F won't start, incline go up and down by itself
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: treadmill Tunturi T 20 keeps inclining upward by itself
Testing Mode 1. Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then‘SPEED DOWN’ and hold buttons pressed simultaneously 2. LED scanning mode for verifying display functionality 3. Press ‘ENTER’ to scan DATA LINES to verify display functionality 4. Press ‘ENTER’ to scan SACN LINES to verify display functionality 5. Press ‘ENTER’ to scan LED’s to verify display functionality 6. After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) 7. Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ to decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
Posted on May 14, 2010
ercupa190
  • 12223 Answers
SOURCE: My Tunturi j800 is stuck in the incline position. Other than that, it works great! How can I get it down? The screen reads that it's at 0% incline.
RUN THE SOFTWARE CALIBRATION FOR DIAGNOSE, TROUBLESHOOTING AND FIX IT.
2) you can lube the gear, shaft+ adjust the potentiometer+see the relais contact are clean it.
sincerely. God bless you
Posted on May 06, 2012
Regarding my Tunturi j800 stuck in the incline position: thanks Tim for the response. I'd love to manually lower it, but there is no flat head screw on any metal-encased fan. The only fan belon
Dear Sir:You must RUN the software calibration for easy diagnose, troubleshooting, and fix it. After that you need adjust the speed sensor, see the diagram attached, clean, and tight the connector very well. Then you can lube the gear and shaft from elevation motor b) adjust the potentiometer c) test the elevation motor. But first RUN s. callibration.
May 03, 2012 | Tunturi Exercise & Fitness
May 02, 2012 | Tunturi Exercise & Fitness
The machine just goes into auto calibrating on the screen and beeps constantly. does not stop auto calibrating Just seems unable to cope with any programs to do with hill climbs
power off, put in the key, press and hold down the 'stop' button and 'incline up' buttons, power on holding down the buttons for a few seconds - message clears
Feb 17, 2011 | Tunturi T60 Folding Treadmill
T60 treadmill came up with lift motor error so switched off. Now when I switch on it displays autocalibrating but never gets any further. Can you help?
power off, put in the key, press and hold down the stop button and incline up buttons, power on holding down the buttons for a few seconds - message clears
Jun 18, 2010 | Tunturi T60 Folding Treadmill
Has ceased to recoil
It sound like the return assembly cord has broken. If you mechanically incline then I suggest you pull apart your unit, but take pictures every step of the way until you uncover and inspect the return assembly. If you are not mechanically incline and since I don't know where you are located, go to the Tunturi website and locate your distributor they will be able to help you with parts availability, pricing and locate a servicer for you.
May 29, 2010 | Tunturi R30 R30 Series Rower
Proform 350s crosstrainer treadmill; surges 3 MPH to 4MPH
Walking Belt is Worn: The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but for most models, this tests works well upon). Fewer steps indicate high friction. The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem. Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck
May 27, 2010 | Proform CrossTrainer Treadmill
Treadmill Tunturi T 20 keeps inclining upward by itself
May 10, 2010 | Tunturi T20 Folding Programmable Treadmill
Treadmill stops when i incline it
Start your unit without any body on it, then increase incline and see if the unit shuts down if it does not then the first thing I would do is lubricate the deck if no maintenance has ever been done on the unit refer to your owners for the procedure. After lubricating the deck proceed with normal operation of the unit. If this do not take care of the problem you may have a worn belt and deck thus causing too much power to be draw thus shutting it down.
May 02, 2010 | Tunturi T30 Programmable Treadmill
Hi i have a code E7 that show on my upper board in my tunturi t20 treadmill. dealer told me to change electronic lower board . i change the part and nothing change. do you know what is the problem? thanks...
Pull the connector off the incline motor off then connect (usually red and black thick leads) your multi - meter then select ohm X1 you should get a reading about 1.7 ohms. then check if the motor see if it is stuck. Then wrap a peice of cloth around the incline screw and with a pair of vise grip gently apply enough pressure to see if you can unstick that screw, reset your power and if the error code clears up, if not the VR control in the motor can be defective and you must rplace the motor.
If the reading show open I would suspect the motor is bad then again replace of the motor.
Apr 08, 2010 | Tunturi T20 Programmable Treadmill
My Tunturi T20 treadmill stops and cuts the power. This happens when it is stopped with the emergency switch. Then when I try to turn it on again it shows KM 579 and then nothing..no power no screen...
We have the EXACT same problem! Would love to hear a solution to this. It will eventually work again but we have no idea what brings it back to life. I've tried the reset button, unplugging and replugging numerous times and still get the KM and 579 showing up and then no power.
Feb 26, 2010 | Tunturi T20 Folding Programmable Treadmill
Tunturi T20 Folding Programmable Treadmill Logo
Top Tunturi Exercise & Fitness Experts
gbob59
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
