Question about Wyndham House Thermoelectric Wine Cooler
Wine cooler model sc-12B lower section temp display continuosly reads 50 degrees
Wine cooler model sc-12B lower section temp display continuously reads 50 degrees no matter what the desired temp is set to
Why does wine freeze?
Check for corrosion on the temp probe. The digital displays use thermistors to determine the temp so if the probe has dust on it it will change the resistance reading and tell the cooler that it is warmer than it is. All you can do is clean the probe, and if that doesn't solve the problem then the control or probe are faulty as they are usually one piece you will have to change it out. If you are mechanically inclined you can change out the temp control with an a19 abc24c remote bulb temp control from Johnson controls and that will last of the rest of your life.
Sep 05, 2014 | Danby DWC283BLS Wine Cooler
I have a Haier BC112G. It is not cooling at all. Temp panel works, so I can set the thermostat up or down, but nothing happens and it just goes back to room temp after that.
Our magic chef wine cooler (mcwc50dbt) when temp is set on digital panel at 45-50 it jumps immediately back to 70 degrees constantly
Sep 25, 2013 | Haier BC112G Wine Cooler
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Aug 10, 2013 | Haier BC112G Wine Cooler
Wine cooler not cool
Take a look at: https://edgestar.zendesk.com/hc/en-us/articles/200604529-My-beverage-cooler-is-not-cooling-below-50-degrees-How-do-I-get-the-temperature-lower-
May 11, 2013 | EdgeStar TWR181ES
My wine cooler stopped cooling and running
What model # do you have? Is there anything working at all like lights, fans, or displays?
Sep 07, 2010 | Emerson (025806803716) Wine Cooler
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
What is the temperature setting for normal wine cooling?
It's between 55 and 65 degrees fahrenheit. If you're storing a lighter red wine, you'd want to keep it on the lower end (55 degrees). And for the darker (deep) red, you'd want to keep it on the higher end (65 degrees). All white wines should be on the lower end, and below. You can drop down to 50 degrees if you'd like. I hope this helps. Good Luck!
Mar 29, 2010 | Emerson (025806803716) Wine Cooler
Haier Wine Fridge problem
Hello bano24
Welcome to Fixya
My name is Huum,
You have a faulty cold control (temperature control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
Check the control for continuity.
And or need a hands on service tech to diagnose this fault
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 30, 2008 | Haier BC112G Wine Cooler
Temp too high
lamgrimes9,
Welcome to Fizya.,
You said, your Oster wine refrig won't lower its temperature below 76 degrees. I have it for about 5 months, and it worked fine all this time with a setting of 50 degrees. Now it refuses to lower its temp. It reverts back to 76 everytime. Can someone give me any ideas about what is wrong? FYI Mine did not come with an owner's manual.
Sounds like the Thermostat is bad.
http://www.oster.com/CustService.aspx?content=manual
The tel # in your Oster Manual is a recording and will not help you!
But New appliances are under Factory warranty and are fixed or replaced no cost to the customer!you are under
http://www.oster.com/CustService.aspx?content=center
Let me know how it goes.
Huuum
Please leave a rating.
Oct 05, 2008 | Oster 12-Bottle Wine Cellar - Black
Wyndham House Thermoelectric Wine Cooler Logo
41 people viewed this question
Top Wyndham House Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Wyndham House Furniture Expert? Answer questions, earn points and help others
