Question about Sanyo Vacuums
Sparking badly at amature - Sanyo Vacuums
Hoover steam vac spin vac making loud noise sparks flying
The only source for electrical sparks is the motor so it must be checked. Bad motor brushes or a broken wire are possible causes. Do not use in this condition.
Aug 29, 2014 | Hoover SteamVac F5914-900 SpinScrub...
There are sparks coming from the underside of my oreck xl vacuum.
You probably need to take that in and have it serviced at a repair shop. They can check the motor to see if it needs to be replaced or just cleaned. The noise could be bad bearings or a fan problem as well.
Feb 21, 2013 | Oreck Vacuums
No spark,no power to ignition module
Do you have power to the fuse? Sometimes fuses look good, but are actually bad. Check with volt-ohm meter. otherwise bad connections and or wire, corrosion causes a lot of bad behaviors, clean to bright metal for all connections and contacts. Again check with volt-ohm meter, or "indicator" light method.
Nov 03, 2012 | Clymer Harley-Davidson Dyna FXD Evolution...
I have only had my chainsaw for 1 month and all of a sudden it will not start. what do I look for.
Pull the spark plug out and while it is still connected, put the plug against the head of the motor and pull the starter. You should be out of bright light while you do this so you can see if it gets spark. And if you are holding on to the plug wire when you pull, you may get a little shock; BUT THAT'S GOOD! That means that the coil is good. If you don't get spark, then the coil is bad. Remember: You must have the ON/OFF Switch ON, (if it has one), when you do this.
If you need more help, let me know.
Jim
Oct 10, 2010 | Vacuums
My kirby legend II started spitting out sparks near the foot plug. How can I fix it please? Thanks Candy
Depends where the sparks are spitting from.Unplug from the wall and try to detach the cord from the vac itself, where it plugs in. If there is a small hole burned in the side you will need to detach the entire cord from the handle where it clamps on and buy a genuine new one from a vac repair shop or Kirby dealer. Cords do wear out. Ther is a slim possibility you could have a bad switch below but generally the switch just dies , no sparking.
If the sparks were shooting out from inside the motor housing, you will likeley need a motor rebuild which should be done by a professional at vac shop.
Oct 04, 2009 | Vacuums
Sparks in the el. motor of Electrolux Canister.
check the wiring it might have gone bad
Jul 07, 2009 | Vacuums
Sparks and smoke
you either have something worn out or the motor inside is going bad. Sounds like the motor in the power head is going bad. Disconnect the the wand from the power head and flip over the head take the plate off. then take the plastic cover off uou should get to the motor then. look at all the parts. I would think you need to replace the brush roll, belt and motor. But this is just a guess
Jun 26, 2008 | Filter Queen Majestic Canister Vacuum
Electrical
PROBLEM: THE KIRBY WILL NOT TURN ON AT ALL
POSSIBLE CAUSES:
Please note......The Kirby has TWO safety switches that need to be engaged before it will operate. One is on the fan case in the front. It is activated by having an attachment attached to the front. (hose, power nozzle, etc.) The other switch is on the side of the Kirby where the cloth bag attaches and is engaged by the little tab that sticks out from the side of the hard plastic cloth bag "boot". The bag boot MUST be completely engaged to activate the safety switch and allow the Kirby to power on. If you are having trouble getting the bag to properly engage, (sometimes they are STUBBORN) simply lubricate the black gasket that the boot fits onto with gasket lubricator, VASELINE, or try a tiny drop of DISHWASHING DETERGENT or HAND CREAM. It doesn't take much, so use the smallest amount possible to get the desired effect. You should hear a slight "pop" when the bag completely engages.
If neither of these things are indicated, it is probably again, either the power cord, switch or the carbon brushes.
If your Kirby is sparking there are a few causes...
PROBABLE CAUSE (MOTOR): Worn out carbon brushes, bad armature or perhaps BOTH
PROBABLE CAUSE (CORD): The cord has a short in it. Replace the power cord
PROBABLE CAUSE (POWER NOZZLE): There is something metallic stuck in the fan or power nozzle
I think you have a problem with the carbon brushes and amature because of where you describe seeing the sparks. I would suggest taking it to an authorized dealer for repair if it is the motor that is going bad.
Apr 01, 2008 | Kirby Ultimate G Bagged Upright Vacuum
84 kawasaki voyager bike has sat up for 2 years. has low spark & fuel but will not start once in awhile it will pop or back fire.
fuel problem :
first try starting fluid spray can. if runs very short time, then carburetors are gummed up...need re-jetting or remove and buy a gallon of carb solvent and soak carbs for a day then shake out vigorously then air blow dry with compressor then retry
low spark...could be dirty plugs-clean them- or worse may be bad spark unit...try removing spark unit and pull away from chassis then re-attach wires and try....if ok spark, then unit is grounding out to chassis on rear mounting surface...look at back for small cracks in black plastic on unit.
Mar 21, 2008 | Vacuums
Will not start again.
If the cord sparked, then it is bad and needs replaement. If it sparked at the plug end, then replace the plug.
Feb 23, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Vacuums Logo
13 people viewed this question
Top Sanyo Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Thatvacguy.com
Are you a Sanyo Vacuum Expert? Answer questions, earn points and help others
