Question about Whirlpool Refrigerators
Moisture in refrigerator
Water running down back of inside
  • 3 Answers
SOURCE: Refrigerator
there is a drain hole at back of your fridge on the inside which is probely blocked take out the shelfs you should see a channel in the middel that where the drian hole is situated unblock the drain hole[DO NOT USE A SHAPE INSTRUMENT ]hope helps
Posted on Sep 20, 2007
  • 92 Answers
SOURCE: refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Posted on Feb 10, 2008
Sea Breeze
  • 4654 Answers
SOURCE: water is dripping inside refrigerator
This ia a common problem that indicates the drain from freezer is clogged or blocked. I will send you to another link to help explain how to resolve this, Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
Posted on Apr 27, 2009
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
woodchuck789
  • 4070 Answers
SOURCE: My Kenmore refrigerator coldspot #70192001 is not
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 01, 2009
Water is collecting at the bottom of the fridge under the salad trays constantly
Whenever that happens on our fridge we find that the drain out the back is blocked. Have a look inside the fridge on the back wall, you may see some guttering that guides the inside moisture to a hole. That hole drains to a pan on top of the motor. Heat from the motor evaporates the water. I have always managed to clear ours by poking a bit of flexible wire down the hole. It's not a frequent occurrence, probably 7 or 8 years between blockages.
Aug 11, 2015 | Refrigerators
Amana refrigerator model TX18QW excessive moisture , bottom of refrigerator fills up with water
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
If this was helpfu please VOTE FOR ME.
IMUFO2
Leo Ponder
imufo2@sbcglobal.net
Jul 26, 2011 | Amana Refrigerators
My refrigerator has a leak behind the drawers on the inside . I have since had to put a towel at the bottom of the drawers or it will start leaking down the front and onto the floor every couple of days....
Moisture condenses out of the cold air inside the fridge. Many refrigerators have a drain tube in the bottom to allow the condensate to run into a drip tray under the refrigerator (behind the trim panel on the bottom) where it evaporates. Over time this tube can get clogged by food particles and the water backs up, eventually running over the bottom edge onto the floor. You can use a straightened out coat hanger or other stiff wire to clear it out. This should get the water back into the tray where it belongs.
Jan 21, 2011 | Microwave Ovens
Defrost pan checked where is it
That defrost system begins behind the rear wall of freezer and ends in what some call defrost pan. After defrost the water melts in freezer and drains down to the defrost evaporation pan where the heat from the compressor and condenser fan blow warm air over the water to return the moisture back to the air inside your home. The pan is located below your refrigerator, Thanks, Sea Breeze
Dec 23, 2009 | Maytag MSD2756G Side by Side Refrigerator
Why is the frost free refrigerator sometimes running water down the inside of the fridge.
its when it finds out there is too much ice in the freezer box so it
de-frost's its self, smart "A" but it should have a drain at the back to let that water run out into a container on top of the compresor the heat from that dryes it out, pull it out and have a look at the back if the pipe is blocked clear it out and the problem's solved
Oct 22, 2009 | Refrigerators
Water in bottom of refrigerator
there should be a tray that guides water from freezer to a drain located in the fridge section normally held with one screw . take it off and unclog drain ( use a vacuum to **** out sludge) clean tray/guide and mount back on. make sure all moisture is cleaned out after drain is cleared.
Jul 07, 2009 | Refrigerators
Water build up
Yes the water will drain after turning the refrigerator on. As the freezer freezes it will collect the moisture and drain the water down to the bottom of the refrigerator and be evaporated back into to home. This should not be a problem after about 1 day of operating. Thanks, Sea Breeze
Feb 26, 2009 | Whirlpool Refrigerators
Water inside of refrigerator running down into bottom, right draw
tHE MOST COMMON PROBLEM IS THAT THE DEFROST DRAIN BLOCKS UP AND CAUSES THE DERFOST MOISTURE TO OVERFLOW INTO THE REF SECTION. TO REMEDY THE PROBLEM YOU COULD LEAVE THE UNIT OFF FOR 24 HOURS AND THE ICE WILL MELT OUT AND FREE THE DRAIN, OR YOU COULD TAKE THE COVERS OFF AND REMOVE THE ICE AND TRY TO FORCE SOME VERY HOT WATER DOWN THE DRAIN WIT HA TURKEY BASTER. THE DRASIN IS LOCATED BEHIND THE EVAP COVER. OR YOU COULD CALL A SERVICE PERSON
Dec 02, 2008 | Whirlpool Refrigerators
Water inside chefmate refrigerator
Moisture inside the 'fridge condenses on the coolest parts. Most are designed so that the moisture runs down into a channel and is directed out through a small tube somewhere at the back of the compartment, near the bottom.
I would guess that the tube is blocked near the top.
Try finding the tube and carefully inserting something flexible down it to clear the blockage. Don't use anything too rigid, or anything metallic, as these may damage the tube and cause more serious problems. I have done this before using a pipe cleaner.
Jun 06, 2008 | Refrigerators
Kssp42qhwoo(7 yrs old)
Check and make sure you defrost drain in the freezer isn't frozen. The water may be coming from the bottom of the freezer inside. When the heater comes on to defrost the evaporator, the water drips in to a small hole in the back bottom of the freezer inside. If the drain freezes, the water runs out into the freezer on the bottom and eventually onto the floor in front of the freezer door. It will eventually create a gap and let moisture into the freezer and may show up in the refrigerator section as condensation. Remove the ice build up including the alluminum drain pan area where the drain is located. Pour hot water into the drain to defrost it. You may have to remove the back of the freezer wall on the bottom to get better access. If the water goes down the drain, its clear. If you need a part for your refrigerator, please email me on ebay under user name themackshack. Good luck! , Mack
Jan 06, 2008 | KitchenAid KSSP42QKS Side by Side...
Refrigerators Logo
12 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
