Question about Brother MFC-8840D All-In-One Laser Printer
Fuser Gear Md No. LJ 7416
Hi Guys.
I was given  this all-in -one unit, "if you can fix it, it's yours" senario. I've pulled appart the fuser and found two problems. The LJ 7416 gear has snaped in three places (need a new one) and the gear that drives this gear is slightly worn on the edges (will this need to be replaced?)
How much for the LJ 7416
Thanks for your time guys.
Daniel
  • Dal B Oct 28, 2007
    Thanks Soulvistor, best advice. I will do that. I also have the HP OJ G85 from new, only problem was scanner failure, after a good clean it's still going strong!
    Thanks again Dal B
  • david85 Dec 07, 2007
    hi,
    I am having the same problem, but i don't know how to open up to get to the fuser, Is there anyway i can get a service manual or some advice. Thank first
  • Brother Master
  • 1,113 Answers
You will need to purchase these gears from a brother dealer but I warn against just changing the gears you mention, fuser driver gear in printer frame will be ok unless chipped, but usally the big gear on the fuser goes as does a little white one next to it, and these are breaking becase the fuser is hard to turn, if you just change the gear, the fault will reappear after a little use, best bet is to replace fuser assy (approx $150)
Posted on Oct 27, 2007
  • Soulvisitor
    Soulvisitor Dec 08, 2007
    David.. face back of printer one screw centre, panel comes off, now door can come off then right and left rear cover screw off, the unswer fuser and unplug.
  • Soulvisitor
    Soulvisitor Dec 16, 2007
    parts LINK
HP LJ PRO M880 FUSER ISSUE
I am not clear as the whether you put the errant fuser in the machine that was working and put the good fuser in the bad one so now you have 2 that don't work. If that is the case it is possible that the bad fuser has taken out the good machine. There are resistance tests that should be run on the fuser to see if it is shorted out. If it does short out, you may need to replace an internal fuse or link on the board.
Oct 23, 2017 | HP Office Equipment & Supplies
I changed fuser unit after which the printer began to show scanner error 22 each time i on it. What is the possible solution?
Hello zeksvc,
The "Printer has an internal Hardware problem!"
To try to fix the 'error', do the following:
Turn-off the "Power" to the Printer.
Next, "Shut-down the computer.
"Unplug the Printer {only} from the 'Wall Outlet'.
"Disconnect the [Cables from the Printer to the Computer]."
Now, 'reconnect the cables'.
*Note: If you are using a "Surge Protector" with the Printer?
Plug the Printer 'directly' into the 'Wall Outlet'.
Turn-on the Computer first!
Next, turn-on the Printer.
"I hope this fix the 'error' problem."
*Note: For more information about your "Printer."
I've given you a "Link" to download a {Service Manual}.
There may be useful infomation to guide you in the future!
If you need help with anything else?
Write a 'comment', I'll be standing by, to assist you!"
"Best Regards"
Click here for "Manual" http://printerschematic.com/wp-content/uploads/hp/HP-LJ-M1120-MFP-Manual.pdf
Jul 26, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Hi there, i have an hp 3500 printer. the fuser was ript appart and needed replacment.(the rol was broken on one side and was not burning the inkt on the paper anymore) i have got a new one, but keep...
50.9 error - Fuser Failure (Abnormally High
Temperature Sub Thermistor)
1. The connector between the fuser and
the printer is not connected properly.
Reseat the fuser. Check the connector J5013
between the fuser and the printer. Replace it
if damaged.
2. Short in the sub thermistor. Turn the
printer off and remove the fuser. Measure the
resistance between the fuser connectors
J5013LA-4 (SUBTH) and J5013LA-3
(+3.3V). If it reads 600 ohms or below (at
ambient temperature), replace the fuser.
3. Faulty DC controller PCB, replace the
DC controller PCB.
I think you've some problems on the connectors, check the connections.
If you are able, replace the broken fuser roller from the old fuser with one from the new fuser.
Jun 09, 2011 | HP Color LaserJet 3500 Printer
What are the procedures to replace the fuser on a LJ 2727 MFP?
The fuser might be very hot. After turning off the printer power, allow the fuser to cool for atleast 30 minutes.
1. Remove the rear output bin.
  • Open the rear output bin.
  • Squeeze the hinge pin out of its mounting hole.
  • Rotate the output bin away from the printer until the right hinge pin is released, and then remove the output bin.
  • NOTE: if you have duplexer installed, lift it up slightly and pull it away from the printer to remove it.
2.Squeeze the blue fuser-release tabs.
3.Pull the fuser straight back and out of the printer.
Regards
Rizwan.
Feb 12, 2010 | HP Laserjet M2727nf Multifunction Printer
My four year old (not heavily used) HP Laserjet has developed a fault in that on each piece of printed paper I am getting 5 indents on the left hand side of the paper and on the right hand side the paper...
yep, know exactly what it is, your machine needs a new fuser unit, non simply change, requires the machine to be totally pulled appart to get the fuser out, these I normally quote 2Hrs labour to do, and thats after you have done them a few times, the fuser itself will have the coating falling off the ends, causing your creasing and smudging...
There are only two things it can be pretty good chance like 90% its the fuser, but just check it aint the cartridge, try with another one, or look behind the drum sheild on its base and inspect drum for damage...
This I doubt, the fuser has a mark/scratch on it, and the coating is torn..possible outside chance that its drum but that dont cause creasing, only fuser does, maybe you have both problems
If you take a look at the fuser with a torch, thats the hot bit where paper comes out.... you will see the upper pressure rollers coating is worn and tearing, Fuser wear out on all laser printers cost of fuser itself would be approx Aus$250, no simple fix for you I'm sorry....these were a good unit but I wouldn't fix it, I find that normally this is a sign that time has come for this unit, fix this and in 6months you'll be fixin something else on it, I know, it doesn't get used much, but 2 or 3 years in office equipment these days is good, four is exceptional, welcome to our modern world design to break....
hope this helps
cheers
Soulvisitor
Nov 22, 2009 | HP LaserJet 3030 All-In-One Printer
Black toner flakes on paper
This could be a couple of things, easiest thing to try first is to put a different toner cartridge in, something that has already been opened because it would save you from opening a new one. Another thing you can try is sending a cleaning page through the printer to clean off excess toner from the fuser unit. What happens is over time toner builds up on the lower pressure roller of the fuser unit and after being heated and cooled so much the toner starts to flake off on your print outs. Follow these steps to try to clean the lower pressure roller:
To run the cleaning page manually
1.If a duplexer is installed, open the rear output bin.
2.Press check mark(SELECT button) or the MENU button to open the menus.
3.Use (UP ARROW button) or (DOWN ARROW button) to scroll to CONFIGURE DEVICE, and then press
4.Use or to scroll to PRINT QUALITY, and then press the check button
5.Use (UP ARROW button) or (DOWN ARROW button) to scroll to CREATE CLEANING PAGE for the(LJ 4200/4300) or PROCESS CLEANING PAGE if you printer is a(LJ 4250/4350) then press the check mark
6.Follow the instructions on the cleaning page to complete the cleaning process (LJ 4200/4300
only).
7.If a duplexer is installed, close the rear output bin.
This should help clear some of the flaking toner, if not you might have to replace the fuser unit.
Jul 31, 2009 | HP LaserJet 4300n Printer
Not fusing
Make sure the two blue levers are in the down position on the fuser. If the problem persist try another fuser .
Apr 03, 2009 | HP LaserJet 9050 Printer
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2 http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
Hp lj 8150 error 50.1fuser error
Unless someone else replies with the identical fault and remedy, my best suggestion is to get a copy of the service manual. There may be a fee but you will be sure of following the correct diagnostic procedure. It sounds like you are capable of this. Good luck.
Sep 22, 2007 | HP Color LaserJet 3500 Printer
Brother MFC-8840D All-In-One Laser Printer Logo
616 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
