Managemylife com sears
I have a Craftsman air compressor Model 919.165300. The regulator will only adjust to 50psi output. Inside the regulator is a metal stud that has lh threads on one end and a square shape on the opposite end. The stud has a hex nut assembled on the thd. end. Where should the nut be positioned on the threads? My thoughts are this is the adjustment to increase or decrease the output psi. thanks for any help.
  • 114 Answers
SOURCE: converted a ge gas to lp. the oven and broiler has too much flame
You must close the gas valve orifice. There is a gas valve (silver or grey colored rectangular shaped piece which feeds the burner(s)) that has a brass or gold-colored hex nut. This nut (1/2 inch) needs to be tighten down clockwise to the stop point. This will regulate the flame.
Posted on Dec 21, 2008
  • 4088 Answers
SOURCE: I have a model FP209501 Air Compressor 2 Gallon,
The spray gun consumes more air volume than the compressor can deliver. You can pause painting periodically to allow the compressor to 'catch-up' or buy a larger delivered-volume compressor. The compressor that you have was intended to supply air for pneumatic nailers and staplers in an intermittent fashion. Hope this helps!
Posted on Jan 18, 2010
SOURCE: Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
Posted on Feb 15, 2010
SOURCE: Propane Regulator Adjustment
Remove the plastic cover on the center of the regulator. To increase pressure setting, turn the plastic disk beneath with a screw driver. 1 turn clockwise increases the pressure 1/2" water column.
Posted on May 24, 2010
  • 324 Answers
SOURCE: porter cable compressor regulator output reads 0.
sounds like it was turned too far back, its just a spring and a screw in there see if you can t turn it to the positive enough times to make it come back if not you might have to replace the regulator, i wouldn't recommend trying to dismantle it and fix it, it could cause serious injury or damage to tools, also the plastic knob may be striped out on top
Posted on Oct 17, 2010
Testimonial: "Thanks for the suggestion."
Air compressor model no. 921.153101 blowing air trough air cleaner
Sounds to me like bad (or dirty) reed valves. Carbon buildup on the reed valves can cause poor seating of the valves. Sears has an Owner's Manual available at http://www.managemylife.com/mmh/owner_manuals/15651/CRAFTSMAN-Air-compressor-L0512094?brand_name_search=921.153101 that has a parts listing for the unit.
Oct 03, 2012 | Craftsman Air Tools & Compressors
I have an older Sears Craftsman air compressor 1hp, 100 psi twin cyl Model 106.154541. on the cyl base there is an oil fill directly across from this on the opposite side of the cyl base there is another...
The pump used on your compressor was incorporated into different designs thus needed access to oil fill from one side or the other. Part number for oil plug was std-220 or 27642, but you can use just regular standard pipe thread plug with square head. If the oil plug fits the other hole. Buy plumbing parts at Lowes. Good Luck
Mar 25, 2011 | Craftsman Air Tools & Compressors
CRAFTSMAN Air compressor Model: 919167450. IT'S GOT A LEAK" SO FAR SEEMS LIKE AIR ESCAPING AT CONNECTION OF COMPRESSOR TO TANK. THE COMPRESSOR THEREFORE DOESN'T SHUT OFF COZ PRESSURE LIMIT(PSI) IS...
Manual:
http://www.managemylife.com/mmh/owner_manuals/8336/CRAFTSMAN-Air-compressor-L0809089
Schematics:
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fP0040151-00001.png
Parts ordering:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Air-compressor-Parts/Model-919167450/0247/0703000/P0040151/00001?blt=06&prst=&shdMod=
Jan 08, 2011 | Craftsman Air Tools & Compressors
Low air pressure
This sounds like it is either the pump is leaking from the piston or more commonly, the rubber seal that seals the outlet tube to the cylinder head blew out like mine. Let me guess, it got a lot louder than it was originally? The seals are readily available from sears parts direct, its like 3 bucks but shipping is around $8. Hope this helped
May 23, 2010 | Craftsman Air Tools & Compressors
Will only produec 20lb of pressure
I have the same make/model. Connect a device to your air line (impact, blow gun, doesn't matter anything that will use air). Operate the device and note if the pressure on your output gauge falls, and then rises back to 20# when you let off of the device. If it does, this indicates that your regulator is either defective, or it is adjusted too low. Try adjusting the regulator knob, operating it in both directions, and note the pressure on the output gauge. If you can get it to rise, you're home free!
Regards, --W/D--
Jul 16, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Pressure regulator gauge wont work on my 3 gal. air compressor how do i fix it or where do i get a new one (craftsman) i also lost my book , how often do i change the oil ?
If the regulator is inline you need de-energize the compressor to remove the regulator.
Sears parts and service:
http://www.sears.com/shc/s/c_10153_12605_Home+Services_Repair+%26+Maintenance?adCell=W4
Compressor Information:
http://www.sears.com/shc/s/c_10153_12605_Tools_Compressors+%26+Air+Tools
Wiki Buying Guide for Craftsman Regulators:
http://www.shopwiki.com/search/Craftsman+Regulator+with+Gauge
Sears / Craftsman Forum & Repair Information:
http://www.sears.com/shc/s/nb_10153_12605_NB_CSHome
3rd Party Regulator Retailer:
http://www.controlair.com/
If you feel that your problem is too serious for you to repairyourself, please contact a licensed/certified technician.
If you wish,you can call Sears HomeCentral at 1-800-4-MY-HOME tomake an appointment for a technician to visit. (There is a charge forthis service.)
Mar 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Computers & Internet Logo
David Payne
David Payne
