How to replace right front strut assy
Hey John, You will need to get a strut spring compressor. -- use the "loaner tool" program from O'Reilly's or Autozone.. - Jack up the vehicle, place JACK STANDS under the frame..leave the suspension "hanging" with the tire off the ground,, get the spring compressor and start compressing the strut spring...once you have the spring compressed about 1 inch.. its time to loosen the mounting bolts/nuts for the top and bottom shock mounts...make sure you have the spring compressing under control... now remove the nuts and bolts from the strut mounts...now finish compressing the spring..and then remove the strut.... NOW - REVERSE the procedure for installation.
