Question about Pool & Spa
Catalina spam We have a Catalina hot tub about 4 or 5 yrs old the heater is not coming on and say freeze caution. What should we do first. Hot tub was found with the breaker blown, turned back on and it is running none stop with no heater.
    Scholar:
  • 94 Answers
Hi, Lori Thanks for the question. It sounds as though your tub froze over and tripped the freeze sensor. If the freeze caution is gone and the tub will not rise to temp, either 1 of the heat sensors or heating element has gone bad. With a bad element or sensor you should have an error code on your topside display. At this point I would recommend contacting a Spa Technician, unless you have some spa repair knowledge or feel comfortable attempting a self repair. I hope I was able to help, Thanks again!
Posted on Feb 18, 2014
djxtreme979
  • 151 Answers
SOURCE: 115 volt 20 amp breaker for hot tub keeps tripping
Is there anything else on the same breaker? Is that the proper amperage for the pump? How long has the pump been in service? It may need to be cleaned as possible obstruction causing too much strain.
Posted on Dec 28, 2008
zeusfaber
  • 247 Answers
SOURCE: no power to hot tub...
In all liklihood, your problem is a breakdown in the insulation of the heating element. The elements tend to be mineral insulated then metal jacketed. Once you get a bit of corrosion on the jacket and a little water gets into the mineral powder, it's insulation properties fall off sharply, shorting out the power supply.
There are two practical ways of testing this:
The pro way of doing it is to borrow a high voltage insulation tester, disconnect the power leads from the element and check the resistance between one of the elements terminals and the jacket. Treat anything less than a megohm as a failure requiring replacement of the element. (nb. This is one of those rare cases where you need to use a proper insulation tester - an ordinary multimeter often fails to find this problem)
The alternative is just to replace the element and see how much difference it makes.
A.
Posted on May 25, 2009
SOURCE: Running a 220 volt 40amp service for my hot tub.
By code, this would require underground cable to a breaker panel with a double pole GFI (maybe that's what you were planning). Then from the breaker panel to outlets, pumps, etc.
40 amp breaker will require 8 AWG cable.
More info, let me know...
Charlie
Posted on Aug 23, 2009
Testimonial: "BY CODE, means it's the law!!! I didn't want to cut thru my black-top driveway. It's about 130 feet around the yard to the hot tub."
  • 8 Answers
SOURCE: this is an old hot tub qca jewel spa that runs all the time
your ozonator may have condensation water in it, try unplugging it and using a hairdryer to dry it out, otherwise you will need a replacement ozonator (i know where to get these at dealer cost if you need one). When replacing ozonator, make sure you request the correct plug type depending on if you have the white plugs or gray plugs that plug into either the side of your spa pack or the circuit board.
Good job on isolating the problem by unplugging each component when a circuit breaker trips. Next, your filter cycle is most likely set on constant filtration, you will need to reset it to 2-4 hours per 12 hour cycle. Don't put it in standby, leave it run in standard mode. Hope this helps,
Spafixer
Posted on Apr 09, 2010
Coastsider
  • 331 Answers
SOURCE: I have an older Catalina spa with acura controls.
These older style controls are easily repaired but require some electrical diagnosis expertise to determine the problem.
1. Check the pressure switch to make sure it is working properly - Use a continuity checker to see if the pressure switch is closed when pump is running. If not then check for proper water flow. Dirty filter, obstruction in plumbing. If flow is good, replace the pressure switch and see if heater works.
2. Check to see if the heater has 220V at the heater terminals when heater circuit is running. If not, then check to see if the heater contactor (relay) is actuating. Check Hi-limit switch, Thermostat and pressure switch for continuity. If heater has voltage, check for current draw, using a clamp style amp meter around on of the heater wires. look for about 20 amps. If voltage is present but no current draw, the heater is bad.
3. The spa light is a completely separate circuit, check the air switch, air line, button and light bulb. Its a 12V AC circuit.
Posted on Apr 16, 2010
Replaced cartridge now only have hot water
You likely took out the anti-scald ring out when you took it apart and then put it in in a different spot preventing the handle from turning far enough. You may also have the cartridge or handle upsidedown.
Nov 25, 2013 | Price Pfister R897EBK Brushed Nickel...
Catalina Desk assembly instructions
I suggest for you to contact Pottery Barn directly either by phone or email and ask them to send you assembly instructions for the catalina desk. Check out this website to get all the contact information: http://www.potterybarnkids.com/customer-service/?cm_type=fnav
Sep 30, 2012 | Pottery Barn Kids Catalina Storage Desk &...
Catalina hot tub runs for ten seconds then trips out no air block or blockage ?
when the air stop's can you still hear it trying to pump air? if so then it may be a blockage and I would drain the entire system. If no then it may be a faulty pump that cut's off when it gets hot
Jul 30, 2012 | Washing Machines
1977 Pontiac Catalina heater problem The core is new, the radiator is new, the heater motor is new, but still no heat.
is the deverter valve opening to let hot water to flow through the heater core. this seams to be the most likely problem. unless the water inlet / outlet going to or from the heater core lines is stopped up.
Dec 29, 2010 | Computers & Internet
I just got a 2001 catalina hot tub and the word flo is on the display panel and the temperature will only get up to 61 degrees. We think that one of the pumps is not working. The pump that is not working...
That code is for a low flow. It may be the pressure switch not sensing the water flowing in the tub. Or the flow is indeed low. You can observe the actual flow yourself.
If the pump is not pushing enough water , then that could be the cause of the code. The pump being very hot suggests that there is an obstruction in the line .. or it is air in the pump.
Please vote !!
Apr 26, 2010 | RTO Pump Volute, Acura, Maverick,No IMP
Older catalina spa with top controls showing two jet speeds but only the low speed jet is working???
Please provide your catalina spa model and year, as well as the spa control system info... You can contact us directly at info@coastsideservices.com. we are a Catalina Service Center and can help you troubleshoot this
Apr 06, 2010 | Pool & Spa
I purchased a Catalina Hot Tub that has a KDC-MP228 installed. The radio works however the CD player does count, recognizing the disc however there is no audio coming from the pop up speakers located on...
It sounds like the stereo has got some faulty circuitry internally. You'll need to replace the unit to be able to listen to CDs in your hot tub. you may want to look into getting a marine radio as a replacement. I'm sure this will be more suited to this application and is probably the kind that should have come with the tub in the first place. I hope this helps and good luck!
Feb 17, 2010 | Kenwood KDC-MP228 CD Player
Can you locate front rotors for a 69 Pontiac Catalina?
Should be drums in the front of the Catalina?
www.rockauto.com sells RAYBESTOS Part # 1270 which are for the front of the 65-70 Catalina, and 68-70 Catalina Ventura.
"IF" you are talking about a conversion kit to run disc brakes on the front that is a different story.
Dec 04, 2009 | Pontiac Catalina Cars & Trucks
My shower is running cold water only, the rest of house has hot water
sounds like you have a single lever shower, in this case the valve stem which mixes the hot and cold has a clogged hot side , you'll need to remove and replace the cartridge or valve stem
Sep 12, 2009 | Price Pfister RT6-E0XC/HHL-ELBC/0X6-040...
Pool & Spa Logo
116 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
