Question about Kwikset UltraMax Powerbolt 1000
Lock jammed lock fault
Safety device been activated. baby lock elegant 2
When a safety issue has been activated, it generally means that it should be taken to a technician. In other words, the machine has a fault that prevents it from functioning for the safety of the user.
Dec 26, 2016 | Baby Lock Sewing Machines
When pumps stops shaft locks up and won't restart (faults)?
looks to me like a 3 phase pump, 1. can you turn the shaft with the pump turned off if the answer is yes, when you turn it on runs then locks up / stalls motor, as a ex maintenance engineer i think you have something in the pump that's loose floating about and when the pump starts it getting jammed in the blades of the pump , or you have a scale build up in the pump jamming it when you try to start it
especially if it's got hot water running through it
good luck
Sep 22, 2016 | Plumbing
Error code E07 on my Hoover WDYN 854 DB results in me not being able to open door after a wash cycle any ideas how to open door
Switch off and for Door lock fault or Motor fault .
Check both are ok and make sure nothing is jammed or restricting the operation as it is according to which main board is fitted to the machine.
Feb 02, 2015 | Hoover Washing Machines
Steering is locking up when turning to the right could this be cv joints or ball joints
I suggest that it is neither but the problem is in the steering box or rack. Terminology is important when trying to describe a fault.. By locking up do you mean that the steering wheel will not turn any further ---the wheels lock up --or the steering circle is not the same as turning to the other way. CV joints will not jam in a particular angle on one side and ball joints will be loose. but if you have a problem in the box the fault will occur at the same point all the time.
Dec 24, 2013 | 2007 Chrysler Sebring
Door will not lock
Possible that the door lock is jammed or there is no trigger from the door switch or lock. Also this can be due to fault in the control panel, check the input/outputs from the controller unit.
Click this link: door lock
Jan 21, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
What does the F-9 code for a Ge oven mean
An F9 error code on a General Electric (GE) oven indicates that the oven's electronic control system has detected a problem with the automatic door lock. The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode. The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
Jun 17, 2011 | GE Ovens
Door will not close all way, goes up and down ok I cant see any adjustment
Possible fault in the door lock assembly where the reset switch is also placed. So if this switch is jammed or the lock has not opened then the door may not close.
So remove power connection and open top lid to look into this section.
Apr 02, 2011 | Microwave Ovens
My Megane Expression 1.6 2003 (03) does not lock the boot when i click the lock button on the card it locks the doors but not the boot Can someone help.
either the wires in the rubber boot from the door to the door frame are damaged or their is a wiring plug off in the tailgate door itself or the lock has gone ,its a strip and play job to find the fault
Dec 29, 2010 | 2003 Renault 181
Parked my land rover 2003, went back in 2 hours used remote key to unlock the car, but steering wheel would not unlock, could not start the car, could not even turn the steering wheel, help.
sounds like
  1. your key has been damaged
  2. or locking pin the the steering lock meck has jammed or
  3. the mech at the back of the lock with the wires has jamme
, have you a spare key ? if still has the fault try forcing the wheel left and right while trying key see if that frees it, remove the wire connector from back of lock, try again if not then the barrel may be at fault the it will need cutting off there are 2 "shear bolts" which need cutting in to and then unscrewing to release the barrel , best doing all this with battery disconnected
Jan 03, 2010 | 2003 Land Rover Discovery
Tried to feed envelope. Jammed. Printed two regular sheets that day after jam. Now, next time I turn on. Makes loud noise during warmup when rollers usually test their rolling. Same noise when I send print...
Beside you is broken drive seizing roller, here fault of the **** of the grapping or gear or electro relay. Persuasively - a repair for service this typical fault. Thank you
Sep 28, 2009 | Samsung ML 2010 Laser Printer
Kwikset UltraMax Powerbolt 1000 Logo
37 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
marty morrison
marty morrison
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
