Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
Does my Maxtor back up my iphotos? - Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
    Master:
  • Apple Master
  • 545 Answers
It depends on how you set it up. You'll have to make sure they're on the disk. Remember that it's only backing up stuff as often as you back it up, so anything you add after the back up isn't on there until the next back up.
Posted on Jul 18, 2014
Could Maxtor be broken?
Load this utility iSkysoft Data Recover, could help!
Sep 08, 2014 | Seagate Maxtor 750GB One Touch 4 Plus...
Run a time machine backup. Then the easiest way would be to find a photo that you are willing to delete in iPhoto.
Jot down the name of the photo file, delete it. Then empty the trash.
Then go into time machine, try to search for that file, when you locate it, restore it. If you can then there is probably a good chance that you time machine backup is good.
To be on the safe side why not create a manual backup.
You'll find the iPhoto Library at:
/Users/username/Pictures
"username" will be your name that appears when you login to the computer.
  1. To get there, double-click the icon for your hard drive to open it, then double-click the Users folder. Double-click your Home folder, which is identified by a house icon and your username, and then double-click the Pictures folder to open it.
        1. Inside the Pictures folder you'll see a file called iPhoto Library. Copy the iPhoto Library file to a location other than your hard drive, such as your Maxtor external hard drive.
Feb 12, 2014 | Apple MacBook Pro Laptop Computer with...
Photos disappear on iPhoto
Hi Linden McNeilly,
In case if you have lost your photos from your iPhoto library. You can recover them back with the help of a photo recovery software. The one which I use is Yodot Mac Photo recovery software to recover iPhoto photos. So if you have any photo loss from your iPhoto library you can use this software.
Jul 14, 2012 | Nikon COOLPIX S9300 16MP 18x Opt Zoom 3.0...
My iphoto icon on deck has a ciricle with a line though it which means no. I can not open iphoto. it states it could be damaged .
Hi there, there is a easy fix to this problem. What you are first wanting to do is to make a backup of your iPhoto library. The default place is User(Your Home Folder) / Pictures/ iPhoto Library. What you are going to want to do is right click the iPhoto library and select duplicate. Then just click and drag that new iPhoto library you just made to the desktop. Now what you want to do is to install iLife again. Just insert the iLife disk and follow the on screen instructions. Once that is done you should be able to open iPhoto again. If for some reason when you open iPhoto and your photos are not there, then close iPhoto and you want to place the new iPhoto Library that we put on the desktop into U ser(Your Home Folder) / Pictures/ Now drop the iPhoto Library and make sure that it is called iPhoto Library and not iPhoto Library Duplicate, if that is the case then right click the file name and click get info, then just rename it iPhoto Library. Now you are done, open iPhoto and you should have all your photos again.
If for some reason this still does not work, then once again close iPhoto, this time we are going to open it agin but while we open it we are going to hold the option key down too. A menu should pop-up asking you what library you would like to use, all you want to do is select the one that says is located in User(Your Home Folder) / Pictures/ iPhoto Library.
I hope this helps you, Justin
Dec 06, 2010 | Apple MacBook Air
Facebook log in problem Error 101 (net::ERR_CONNECTION_RESET): Unknown error.
Thank you for visiting Fixya forums.
There are several reasons you may be getting this error code. Each will be suggested below:
Firewall
Change your firewall settings in the Security Preference Pane to 'Allow all incoming connections'. Check to make sure you don't have a firewall running that has stopped iPhoto from communicating with Facebook.
Cookies
This error code may be an issue with the cookie that Firefox or Safari uses to store the Exporter's login info. You need to delete the Facebook cookie called "isfbe". In Firefox you can do this by going to your preferences, clicking on "Privacy," then find the Show Cookies button. Find the one whose name contains the term "isfbe". Then click Delete Cookie.
For Safari you also go to preferences, but first click on "Security," then click Show Cookies and find the aforementioned cookie and delete it.
After this, just go back to the Facebook Exporter in iPhoto and login again, this time you will have no connection problem.
iPhoto
iPhoto, a problem lies in a conflict with the latest point update for iPhoto '08, version 7.1.3. Maybe it will work if you reinstall iPhoto, update to 7.1.2, copy the iPhoto application and rename it "iPhoto old," and then run Software Update and bring it up to date to get the bug fixes in the latest update for your main copy of iPhoto.
Note: I don't know if it will change the library format at all with 7.1.3.
The FAQ/support page for the Facebook Exporter for iPhoto is here: <http://www.facebook.com/help.php?page=718>
Login
1. Log out of Facebook through your web browser.
2. Go to Facebook Exporter for iPhoto, click Login.
3. This will open a Facebook login page in your web browser.
4. Log in but do not check "Save my login info..."
5. Go back to iPhoto, hit continue, and export your photos.
Sometimes an error message may still occur while uploading the photos, but retry and eventually it should work.
LittleSnitch
If you have Little Snatch running on your computer it may be blocking iPhoto from access port 80.
For some reason with the Facebook export it doesn't pop up and prompt you to allow access. Allow access in LittleSnitch my Facebook plugin for iPhoto may allow you to start connecting properly.
FULL Reset of Safari
You can remove all history, cache, cookies, etc.
Firefox History
If your browser is Firefox, clear history.
Jan 28, 2010 | Computers & Internet
My previous hp computer crashed due to spyware infection. I manually back up my maxtor performed 3-4 days prior to infection. Will the Maxtor files be safe to download into my new computer?
Well since you've said that you computer crashed due to a spyware infection and that you backed up your maxtor some days to the infection, there is every likelihood that the maxtor will also be infected. My advice to you will be to first of all scan the maxtor file with a very strong anti virus before sending it to your new computer or else you will end up loosing your new computer if the maxtor file also contain the spyware infection.
Jan 14, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Lost iphoto back catalog after an import, is there anyway to recover these photos?
the back catalog of your images are not gone. Since the pictures you have uploaded form your camera to iPhoto all those files are still there. All you need to do is re-load the images into the library of iPhoto.
1) Start iPhoto, then in the menu goto File / Add to library..
2) Then a file browsing window will open, all you need to do is locate the folder in which u had specified to iPhoto. (Default location for iPhoto is located at MainHD / Users / Username / Pictures / iPhoto Library
3) Once you have located the folder or folders you wish to add to your library or catalog just press import. And all the images should show in the catalog.
4) if you have more pictures saved in another folder, then repeat steps 1 to 3 again. but in step 2 locate the folder or drive you wish to import from.
Jul 07, 2009 | Apple Computers & Internet
I backed up my old Dell laptop last year. I bought a new Dell laptop. I want to access the backup on my Maxtor and cannot do it. I want to load it onto my new laptop. How do I do this? I want to back up...
Very Simple. Just connect the Maxtor External Hard drive to your new laptop. Open Windows Explorer and you will see the Maxtor appearing as a Drive. Access the files from the explorer.
My advice is that create a new folder on the maxtor and then do a backup of your new laptop on to this new folder.
DO the same for your office PC.
Apr 03, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My iphoto on my macbook pro will not open.
I think you might need to reinstall iPhoto (http://support.apple.com/kb/HT1561?viewlocale=en_US).  You should back up your computer, including any photos, before doing this.
Dec 31, 2008 | Apple iLife 03
Maxtor OneTouch II 300Gb can't recover data after a system restore
I had the same problem a few weeks ago.
The way I solved my problem was to make sure when I restored Windows to the default settings that I did it up to the same support packs and hot fixes then when backing up the system with the Maxtor HD. It took me many days to figure this out... was written it the Maxtor HD documentation and it works fine.
Hope this helps.
Chris
Jan 15, 2008 | Maxtor OneTouch II external hard drive...
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
