Question about Alpine MRA-F350 Car Audio Amplifier
No sound from speakers after mra-f350 connected to alpine w205
I just connected the alpine mra-f350 to my W205 head unit via the AI Net cable, then connected the power and speaker leads to the amp.  The amp powers up, but no sound will come out.   Tried to see if something had to be turned on / set on the head unit by going through the source menus, but nothing worked.   any idea what the problem could be?
  • joenopro Oct 28, 2007
    On the W205, there is a setting under SYSTEM - OPTICAL OUT, which the user guide says is the Digital Output.  It was set to ON.  So i tried to set it to OFF, set ACC to on, then set it back to ON, and repower, but still no sound.   Are you talking about another setting which is external on the unit?   I appreciate your help.
  • 631 Answers
Did you set the digital output to the on position on the bottom of the head unit?
You have to switch the head unit off then back on for it to recognize the position of the switch.
Posted on Oct 27, 2007
  • Perry Babin Oct 28, 2007
    That's the switch I was talking about. Try to find a local Alpine dealer. Even if you didn't buy it from them, they should help.
My w205 screen was cracked and there are no controlling options. is there a way to fix the screen? Is the screen the problem? And does it have a remote control?
The only way to fix both your problems is to mail it into Alpine, the screen is laced in with ribbins and soldered by twelve tips on the circuit board. If you have years of electronic back ground you maybe able to fix the screen, the IR controller the remote maybe bad or the IR sensor is back in the head unit is a 3 pin item that maybe needs to be resoldered or a new one soldered in place of the defective one. I have the same unit and I havent had any problems?? How did you break the screen?
Jul 20, 2012 | Alpine IVA-W205 Car DVD Player
I have my cd changer (alpine) plugged into the input port via ai net cable and I have the output going to the alpine radio (cda 9886) via ai net cable. When I hit the source button everything comes up but...
One thing to verify is that the Ai-Net switch at the bottom of the radio is set to Norm and not the EQ position. And also gray Ai-Net connectors are for audio input and the black Ai-Net connectors are for audio output. It sounds like you have everything connected correctly and at least the Sirius is coming up. And I assume that the CD changer works when connected directly to the reciever so you know that it is working. I would suspect that there might be a problem with the Sirius reciever not allowing the communication signal to connect to the Alpine deck and in that case you would need to get a new reciever. You could check the Alpine radio settings and see if there is something that needs to be changed in order to allow the CD changer to work. If you disconnected the battery connection to the radio then it might have reset the settings to factory default. Otherwise it sounds to me like the problem is with the Sirius reciever.
Jan 09, 2010 | Sirius Satellite Radio Sirius SIR-ALP1...
SURROND SOUND
i would suggest alpines new 5 channel suround amplifier that has dolby 5.1 decoding and you will also have to have a head unit that supports 5.1 surround sound which as far as i could tell are only indash dvd players you will also need to purchase a center channel speaker as well
you can follow this link to the alpine amp
http://www.crutchfield.com/p_500MRAF350/Alpine-MRA-F350.html?tp=115
hope this helps
sincerely
justin
May 17, 2009 | Car Audio & Video
How do you change the time
you have to bypass the parking brake in order to set the clock
Jan 28, 2009 | Initial CDS-160 Car DVD Player
Volume will not go passed 4
The amp requires a compatible Ai-net Alpine head unit to operate it. I bought one too and didnt know this and im still trying to put all of the peices together to create a working stereo system without buying everything all over again.
Nov 25, 2008 | Alpine MRA-F350 Car Audio Amplifier
Inconsistant Switching of Alpine MRA-F350 Amp
try and unplug the audiovox unit and check if problems still exist. and what swithes on what unit are you talking about? this kind of sounds like a wiring problem.
Nov 21, 2008 | Alpine MRA-F350 Car Audio Amplifier
No radio sound from my IVA-D310E
neither of those units use fibre optic cables! but it sounds like you puled out the antenna wire behind the head unit. if you try and search radio stations without the manual tune on and it keeps changing frequency on it and never stops then its the antenna plug.
Nov 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
Hooking the mra-f350 to my highs
You will only need to connect the door speakers to the MRA-F350. In short, the connections will be as follows:
Deck---->MRA-F350 amp---->Door speakers
...................................\---->Sub amp---->Sub(s)
Just make sure you use the optical digital output of the deck to connect to the optical digital input of the MRA-F350 amp, not the RCA preamp connections.
Mar 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
Alpine IVA-W205 XM not displaying in source menu
Alpine IVA W205, Red light on the bottom left of the screen and the radio & cd player does not work?
Jan 06, 2008 | Car Audio & Video
Alpine mra-d-550 car audio amplifier
Sorry man here's what i pulled from the internet- Crutchfield sells these:
Note: The MRA-D550 requires a compatible head unit for setup and control, it cannot be used without one. The current list of compatible head units includes (but is not limited to): IVA-D300, IVA-D310, IVA-D900, IVA-D901, DVA-9860, and DVA-9965.
Oct 22, 2007 | Alpine MRA-D550 Car Audio Amplifier
Alpine MRA-F350 Car Audio Amplifier Logo
234 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
