Question about Coby Kyros MID7014-4G 7" Android 2.3 Gingerbread Tablet w/ 800MHz ARM 11 Processor, 256MB RAM, 4GB Internal Storage, 800 x 480 Resolution, 16:9 Aspect Ratio, Capacitive Multi-Touchscreen, Microphone, Speaker, Headphone Jack & USB 2.0 Port
MID7014 "The device enter fastboot Mode" What do I do now?
2 Suggested Answers
Davethesnake
  • 689 Answers
SOURCE: I have a Coby Internet
these might be the initial stages of the re-flashing process ie:installing the OS or upgrading when you might connect a usb cable,im not familiar with your brand.
Posted on Mar 01, 2011
Asus zenpad10 tablet stuck in fastboot mode
KEEP HOLDING THE POWER BUTTON UNTIL YOUR PHONES SWITCHES OFF OR PULL OUT THE BATTERY DIRECTLY(If Required) to exit the FAST BOOT MODE and then start your phone normally by pressing only the power button.
Also in case you were trying to enter the recovery mode to wipe cache or hard reset then keep holding the power button and volume DOWN button until you get vibration and release the power button and keep holding the volume DOWN button to enter RECOVERY.
Jun 16, 2017 | ASUS Tablets & eReaders
Rca tablet how do i get out of fastboot mode
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
Nov 13, 2016 | Tablets & eReaders
Why is my tablet Stuck on entering DnX mode.Waiting for fast boot command...
my next book tablet is stuck in dnx fastboot mode, it will not unlocked, and it stuck on voice command
May 12, 2016 | Nextbook Premium 8 Se Android
Tablet says, Entering DNX Mode: waiting for Fastboot command...
I would book mark these links. Below.
Copied from :
https://www.kingoapp.com/help/fastboot-mode.htm
What is Fastboot for?
While in fastboot, you can modify the file system images from a computer over a USB connection. Fastboot mode can start on your device even before Android loads, even under the circumstance when Android isn't installed at all. And because of that, fastboot mode is useful for quick-updating the firmware, without having to use a recovery mode. In fact, it's the preferred way to initially install the recovery image. Once you set up, you boot to your phone to fastboot and you can flash image files to the internal memory. Flashing a custom recovery like ClockworkMod is a popular use case. The images you flash don't need to be signed with a particular key, and thus you should use care when flashing. It can also be used for developer operations. Things like erasing partitions and overriding kernel command line options can be done. And all this features make the tool very useful for developing hardware and software solutions, like unlocking the Bootloader of Google' Nexus.
https://www.kingoapp.com/help/fastboot-mode.htm http://forums.androidcentral.com/verizon-droid-dna/252896-how-do-i-turn-off-fast-boot-mode.html
May 11, 2016 | Tablets & eReaders
WHAT DOES FASTBOOT MODE MEAN?
Fastboot is associated when you root Android. Here's a site that helps explain it better in detail: The Easiest Way to Install Android ADB and Fastboot Tools on Any OS
Hope this helps you get a better understanding of what it is.
Jan 17, 2016 | Tablets & eReaders
There is a message (fastboot mode) on the screen and I can't shut the tablet off. what should I try?
Not familiar with fastboot mode but most will turn off when you close the cover. If you don't have a cover try covering the tablet with a piece of paper. After a few seconds check if it's turned off...shows screen saver. If it's still on try a reset. Hold the On button down until it responds...about 20 seconds. It will flash and then come back up.
If you cannot shut it off after that...Log into Amazon. com Just under the address bar you will see "Your account" Place cursor on that and click on "Manage content and devices" Next page should show column heading for content, devices and settings. Click devices and select your device. They have a lot of info and suggestions about your kindle.
If that does not help go back to Your account and click Your account from the list. On right side you will find kindle help home, click and next page on left has Contact Us. click that and fill in info and choice of response, email, phone etc. They will call back as soon as possible and the info has already been given to someone that can help with that problem.
Dec 23, 2015 | Amazon Tablets & eReaders
I'm stuck on the fastboot mode. how to turn this off?
Its under system / developer options settings just untick the fastboot option.
May 12, 2014 | ASUS MeMO Pad HD 7
Fastboot mode
either connect this to a pc/ remove the battery, begin again.
Sep 17, 2012 | Android Coby Kyros Mid7014-4g 7" Tablet
CAN THE COBY KYROS BE REPAIRED?
can the touch of a coby kyros mid7014 be chang and where can we buy it
Jul 13, 2012 | Android Coby Kyros Mid7014-4g 7" Tablet
I have a Coby Internet Tablet MID7105. In the bottom left corner of the screen, it states: "The Deviceee Enter Fastboot Mode Please Connect USB TO PC or Reset Device Waiting..........."
Feb 28, 2011 | Coby Kyros 716829701508 Tablet PC
Coby Kyros MID7014-4G 7" Android 2.3 Gingerbread Tablet w/ 800MHz ARM 11 Processor, 256MB RAM, 4GB Internal Storage, 800 x 480 Resolution, 16:9 Aspect Ratio, Capacitive Multi-Touchscreen, Microphone, Speaker, Headphone Jack & USB 2.0 Port Logo
Top Coby Tablets & eReaders Experts
Fred Block
Fred Block
Martin Murray
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
