Question about Ruud RGTC07ERBGS N/A Achiever 75000 BTU Single Stage Downflow or Horiz
My achieve r oil furnace fires,runs for about 2 minutes and than the burner cuts out . it refires on the 1st or 2nd try and continues to finish the cycle. this started out inteermittantly but lately it does it on almost every cycle of heat
Check your filters. If the sensor detects an air flow problem, it will short cycle.
Posted on Aug 31, 2014
My furnace fires up run for about five minutes then fire box shuts off and the fan runs until my furnace runs through its cycles but the fan runs almost continually runs it only shuts done for a few...
On a conventional furnace of today, your furnace may have a flame sensor which is typically located in front of an end burner opposite the ignitor. It is connected by 1 wire. This metal rod needs to be removed by 1/4'' screw in most cases and cleaned. Clean with steel wool or even a clean greenie scrubber will work. Wipe clean and re install. Many problems can cause these symptoms, but this is a very common one.
Mar 02, 2015 | Heating & Cooling
Two weeks ago my base board system oil burner shut off and would not restart.
guessing the thermacouple may be failing as this part tells the fuel metering system if the burner is hot enough to maintain safe combustion
Dec 09, 2017 | Heating & Cooling
How do you know the temperature heater is running at when set on light orange 1st or 2nd square
The only way to tell is to use a thermometer as the outlet heat is based upon the surounding air temperature.
Aug 02, 2014 | Rinnai EnergySaver ES38 Gas Fired Direct...
After one heat cycle, the blower motor keeps running, even after cool down is complete. The furnace will not refire until i turn off the power and wait about 20 minutes for a reset.
your limit switch is opening up, that causes constant fan. Check for flashing codes after flame shuts off and fan continues. Check airflow, filters, lack on return air for possible hi temp limit problems.
Nov 17, 2011 | Goodman Heating & Cooling
My Ruud furnace used to regulate 1 deg +\- the set temp. Now it regulates right at the set temp and the fan cuts off while the burner continues to fire for a minute or so then the fan kicks back on for...
It appears to be the fan limiter switch. It comes on at a certain temp when heating up and shuts off on the high end of its setting. Once the burners are shut down, the fan continues for a few minutes to cool down the burners. The limiter switch is adjustable but it sounds to me to be defective and should be replaced. Good luck and stay warm, :-)
Mar 15, 2011 | Ruud Heating & Cooling
Have a Fridgidaire GR6C-080C-16 furnace that runs for a few minutes then gas supply is cut-off. Furnace will then re-start and the run through it's pre-cycle, just as if the thermostat just called for...
It sounds to me like you have problems with the gas valve as you have eliminated pretty much everything else. I would check all wiring to valve,check for any breaks on the insulation and clean all connections.
When the burner goes out is the blower still running or does it quit then the burner go off? If that is the case I would think the thermal overload on motor was tripping. It makes me more inclined to suspect the gas valve due to the lack of any diagnostic code.
One other thing I would try is to check power to gas valve when burner is firing and see what it does when it cuts out.If it maintains power when gas shuts off then I would replace gas valve. Good luck and thank you.
Feb 14, 2011 | Heating & Cooling
The furnace will kick on and the burners will keep going out the process will continue unless i shut the power to the furnace off for five minutes then cut it back onit will run good but the problem will...
check your air filter, a very dirty filter will cause the unit to over heat "180'" The burners turn off the unit cools itself with the blower and then relights.
Jan 24, 2011 | Goodman Heating & Cooling
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
Ruud RGTC07ERBGS N/A Achiever 75000 BTU Single Stage Downflow or Horiz Logo
184 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
