Question about ASUS Computers & Internet
How do I dismantle Asus HLB2 cose to gain access to power input circuit
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 68 Answers
Unplug it and use a piece of plastic to pry open the plastic panels exposing screws which you can undo.
Posted on May 06, 2014
3 Suggested Answers
matchbox2022
  • 46 Answers
SOURCE: dismantle to resolder coose power socket
I would either look on youtube or Acer's website to find some kind of service manual which would help you. Make sure to keep track of your screws. :)
Posted on Dec 15, 2008
SOURCE: replace amilo Li1718 laptop cmos battery howto
the battery will see on the back or side of your laptop, press the two together and lock up slowly, ,,,,good luck
Posted on Jul 21, 2009
My Asus lap top will not turn on or charge. There are no charge lights. What can I do?
Look carefully at power plug port. If center pin wobble or loose then order that part for your motherboard and take to any electronics shop to have installed. If power plug port not broken. Then use multimeter to check output of your power block. If you don't have a multimeter, any electronics shop can check for you. If no output, then buy replacement power block. Its a fact, power blocks fail infinitely more frequently than power plug ports which only fail due to forced improperly aligned plugging. If center pin no longer centered, trying to force the plug in only guarantees damage. On laptops, that usually requires total disassembly to gain access to the circuit board, unsolder and remove the defective part and solder in a replacement, then reassemble.
Sep 20, 2015 | ASUS Computers & Internet
Shutter release inoperative
The "button" is actually just a plastic extension for the actual switch on the printed circuit board. You will have to dismantle the camera to gain access to the board and then use a DMM to test the switch contacts.
Oct 04, 2007 | Olympus Camedia C-4000 Zoom Digital Camera
Output transistors
a transistor has 3 leads,[emitter current, collector current, base current, i am going to give you list of options that the transistors can be used for and it depends on the configuration of the circuits.
input resistance, current gain, voltage gain, output resistance, power gain, voltage gain, (input and output power) + [input and output voltage] and {input and output resistance} + input and output power gain.
18 various formulas to a range in groups of 2's
Apr 14, 2014 | Volfenhag ZX-7170 Car Audio Amplifier
Samsung washing machine error code is 6e unable to find this code
The heater isnt getting hot and the heater element is showing as faulty, hence the 6E fault code on the control panel.
There will be no short term cure for this problem either, the cabinet will need to be partially dismantled so you can gain access to the heating element and test it with a multimeter for continuity (Full electrical circuit)
You will most likely have to replace a faulty heater element in this instance. The 6E shows up for this reason. The controller has sent power to the element, but it hasnt heated at all according to the thermostat which measures the temperature (Seperate fault code for thermostat problems)
Sep 25, 2013 | Cell Phones
My netbook EEPC 1610P DC input power pin which is coming from Netbook is broken, unable to charge battery
If you broke the central pin of the power jack in your favorite Asus netbook like my Seashell - don't despond.
You can do something like this:
http://sites.google.com/site/emerghelp/
Oct 23, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Toshiba L300 Case Repair !
Basically the input power socket need to be replaced. To get at this power socket will require the laptop to be completely dismantled to remove the motherboard to gain access to this power socket. If you find this too dificult to DIY then I suggest you get a quote from a computer repairer before you get this job done.
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
Broke the the power pin inside mt ausu31prof laptop can it be fixed ?
Yes the power socket can be replaced, but the laptop needs to be completely dismantled to get access to this socket. If you are not confident in DIY then I suggest you get a quote for this repair.
Dec 28, 2009 | ASUS Computers & Internet
Instructions for dismantling for transportation
The Shoprider Soverign is not really meant to be dismantle for travel. The best you can do is to remove the seat and fold down the handlebars. Also depending on the year it was manufactured there is a pin towards the back of the scooter that connects the front chassis and rear chassis. You must first remove the batteries to gain access to the pin. If you are elderly you might need help. It is heavy.
Apr 09, 2009 | Electric Mobility Shoprider Electric Power...
Dismantle to resolder coose power socket
Nov 01, 2008 | Acer TravelMate 2300 Notebook
PSP intermittent powerup
Dear Fix Ya Team,
Many thanks for your prompt reply to my PSP query. I thought I would let you know that I have located a PSP service manual in my local library which at first glance looks as though it might contain enough information which should enable me to dismantle my PSP and hopefully locate/rectify the problem. If not I might be in touch with you again.
Once again many thanks.
Bob122
Jul 20, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
35 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
