Question about Hotpoint RB757 Electric Kitchen Range
Oven shuts off after closing door
I accidently left the oven on on my Hotpoint electric range and now the heating element will not stay on when I shut the oven door. It will stay on if I keep the door open, and the broiling element at the top will work whether the door is open or not. What's wrong and how much will it cost to fix? Thanks!
  • Hotpoint Master
  • 3,904 Answers
Have you put a thermometer in the oven to make sure it is not heating. They will not always glow red if the oven is at temp.
Posted on Feb 12, 2014
SOURCE: Hotpoint RGB745 Gas Kitchen Range
I eventually replaced the oven ignitor. That has solved the problem.
Posted on Aug 29, 2007
Tech007
  • 63 Answers
SOURCE: Electric Oven very slow to heat
cheak for 240 volts coming out of your wall if it reads 120 volts it is your house breaker
Master_Tech
  • 770 Answers
SOURCE: oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Posted on Jul 09, 2008
  • 3 Answers
SOURCE: Oven top element does not come on when baking
the top element is for broil only. if you have convection mode try that
Posted on Nov 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: Hotpoint oven out, stovetop works fine
Reolace the electronic oven control.
Posted on Mar 09, 2009
Oven door will not fully close allowing heat to escape and light stays on
Is the door locked? if it is it won't close all the way if it was in the locked position before it was closed. like if it was programmed for "self clean" without the door being closed, the lock would be engaged still.
Jun 09, 2012 | Electrolux EW30ES65GS 30" Slide-in...
I put a metal dish strainer with a plastic silverware holder in my Hotpoint/GE RB758DPWW electric oven to get it out of the way and forgot about it - it resulted in a small fire with lots of black smoke...
Cleaning off the element and the liner will not cause a problem. Turning on the element will cause smoke till all residue is gone but will cause no problem. Turn it on to self clean after getting off the large pieces will get rid of everything left. Again no problem.
Oct 16, 2010 | Hotpoint 30Inch Freestanding Electric...
I have a GE Hotpoint flat top stove model # RB787WC1WW and the oven will sometimes shut off by itself. Is there a sensor that shuts it down when it reaches desired heat. It will sometimes turn on if you...
That is what the oven elements are suppose to do. When it gets to temp the thermostat cuts the elements off and as it cools they will heat back up. if it cuts off and wont heat back up its probably the thermostat
Mar 08, 2010 | Hotpoint RB787 Electric Kitchen Range
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Oven door does not close properly
replacing hinges on this oven. Take a look.
Dec 14, 2008 | Hotpoint RB787 Electric Kitchen Range
Hotpoint sy36 oven
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
Jun 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
DCS gas oven locked
I let the door stay open, hold the switch closed with my finger, activated self clean. Let it run for a minute then hit cancel, the stove heating element shut off and the locked door blinked for 5 seconds then finally stopped. Back to normal.
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
HOTPOINT ELECTRIC STOVE
two things---when you open the oven door do you see a button on the right or left side?if so thats a door switch and if its bad you will get no voltage to the element.the next thing is your hi limit is bad.this is a sensor that monitors the temp of the oven and if its bad you wont get any heat.some hi limits reset themselves others you have to manually reset them.let me know.
Jul 30, 2007 | GE JKP15 Electric Single Oven
Hotpoint RB757 Electric Kitchen Range Logo
107 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
