Question about Aiwa Televison & Video
A/V INPUT FONT AND BACK NOT WORKING
My aiwa tv sx2150 A/V 1 AND 2 INPUT NOT WORKING,MEANS I CONNCT TABLET THROUGH RCA CABLE NOT COME SOUND IN SPEAKER.SOUND/VIDEO ALSO COME IN TV MODE PLS ANY ADVICE?
    Problem Solver:
  • 11 Answers
Check for poor solder connection
Posted on Feb 13, 2014
3 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: I have an old RCA XS TV and cannot figure out how
Alot of the older RCA chassis required you to press 00, 91, or 92 to get to the external video input.
Posted on Oct 03, 2009
SOURCE: Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Posted on Sep 06, 2010
Rca 10" tablet need to connect to my phillips tv.Plug up nothing happens,Took a hdmi/rca cable from camera, hooked tablet to tv that made my tablets screen go black until unpluged from the tablet.
Screen going black usually means it is connected to another screen. Is there a setting on the tablet to enable output settings and a setting on the TV to enable input settings.
Jul 19, 2015 | Tablets & eReaders
A/V INPUT NOT WORKING
To me in my experience with those set if no loose connection which need to be solder, then that is your EEprom
Feb 12, 2014 | Aiwa Televison & Video
I want to play my music from my itouch on my Aiwa NSX-TR77 system (because of the speakers) but do not know how to, or if this is even possible to do so?
It is in fact possible... you can play whatever source to whatever sound system with the correct cable... you need a cable with at one end a headphone output connector (compatible with your Itouch) to an input of your choice on the Aiwa system... usually RCA input (RED & WHITE RCA type connectors) at the other end of the cable...
Cheers!
Aug 31, 2011 | Audio Players & Recorders
I have a aiwa cx-na77, how do I connect it to a tv so that I hear the tv sound on the aiwa speakers
If it has an "AUX" input or any other type of RCA jacks for an input, you can connect the TV RCA audio jacks output to the input RCA jacks of the Aiwa.
That's what you would need.
RCA audio outputs on the TV
RCA audio input on the Aiwa
Just look at the back of each unit and see if it has them. RCA audio jacks are the small circular red and white jacks. They will be labed on each unit what they are for. You need output jacks on the TV and input jacks (but not for phono) on the Aiwa.
Aug 08, 2008 | Aiwa Audio Players & Recorders
SURROUD SOUND2
The video/aux connectors in the back are inputs. You plug the lines from your tv or auxillary components "output" in to them then you can listen to it on your stereo unit.
Jan 19, 2008 | Aiwa NSX-A115 Shelf System
SURROUND SOUND
does sterio system have aux in tv has rca outs use rca cable from tv outto aux in on sterio system ok the selct aux input on sterio turn it up
cheak tv settings for outout options ok
Aiwa HT-DV1
cuse u need to go back form the tvs out to the dvds input thers no way it knows cuse u have no signal form tv bakc to it or form cable bocx rca out puts to the awia ins rca on input 2 ok or aux in
Jan 10, 2008 | Aiwa HT-DV1 System
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
AIWA AV-D58 RECEIVER
On 5.1 receivers, some inputs can be switched to Digital/Optical/Coaxial instead of Analog (RCA cables) - look for an Input Mode button. If this doesn't help, turn the unit off, then power it on. If you don't hear a click 3 to 7 seconds after turning it on, it may be in Protect mode, and simply be a coincedence that it failed after installing the new cables. This can be caused by several things, most of which require in-shop service.
Jul 11, 2006 | Aiwa AV-D58 Receiver
Televison & Video Logo
Top Aiwa Televison & Video Experts
romy sibug
romy sibug
 Grubhead
Grubhead
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
